PowerBox Royale SRS - sequencer alternative uses?
If I already have a retract and door sequencer installed, could I use the sequencer in the Royal SRS to sequence an opening canopy or a drag chute system?
Cheers,
Jan
Cheers,
Jan
Hello,
Would be good to ask this in our forum, as I donīt look all the time in this forum.
You can use this sequencer for any movements. Only the assistant defines ready movements. But with manual setup- you are totally free.
