bulk deans plugs?
does anyone happen to kno where i might find some bulk deans plugs or a good price on about 10 sets? thanks for all your help before hand links would be great
![](/forum/images/badges/premium_member.png)
ON, CANADA
SK, CANADA
In case this matters to you....
The product that handswithout linked to are not genuine Deans Ultra connectors.
Deans doesn't offer bulk Ultra connectors. The closest they come is a 4x pack of female Ultras (for when you have one ESC and four batteries). You might be able to find a company that'll make you a deal if you call them up and offer to buy 15 pairs.
ON, CANADA
ORIGINAL: Takedown
Plus what handw/oshadows the plugs are siler pronged the original deans are gold.
![Big Grin](https://www.rcuniverse.com/forum/images/smilies/biggrin.gif)
thanks guys i got my whole family into r/cs and now i am changing my plugs cuz now i have a mamba so i am buying a bunch so we can all change over together
IL
As a suggestion, you could always go powerpoles - easier on the soldering...so if you have 10 pairs to changeover, that might be a good option!
IL
ORIGINAL: Mark_M
powerpoles? Could you give more detail?
Thanks.
Thanks.
Hmm, a link from Tower of one example (not sure if these are the best, if other styles are out there, etc):
http://www2.towerhobbies.com/cgi-bin...?&I=LXD175&P=7
I'm a fan of Power Poles. They are a universal male/female design. You can use them to connect 1 wire or more. I use them because 2 can be coupled together for battery to ESC, and 3 can be coupled together for ESC to brushless motor. They can be turned so and keyed any way you want. You can make it impossible to hook up your brushless motor backwards. They come in like a dozen colors for color coding. The plastic casing that houses the contact is the same for 15,30, and 45 amp contacts. They can be crimped and/or soldered(I reccomend if you crimp to buy one of the crimpers made for it..you can find them for like $50. They are bigger, they can be cut down some however. But I like the flexability the most so thats why I use them.
link
http://www.powerwerx.com/category.asp?CtgID=1001
link
I just got off the phone with deans. I was curious with a few things.
the manufacturer, DEANS, distributes in bulk, in a bag of two that we buy from Tower Hobbies for example. This is due to corrosive effects of the air, in general, everywhere. So much for my 100+ quantity buy from digikey! It doesn’t exist.
the red became “off white” when materials became scarce and as of March 2024, black is the color.
up and coming! They have ec-5 replacements to combat the “I use deans for smaller… but use ec-5 for larger…”. Vids are on YouTube.
if you don’t know the authenticity of deans, it’s the quality. The knock-off connectors melt and the blades/tabs will sag, move and open the connection. Deans won’t. It’s on a whole nother level. The red ones would transfer 60A at design limit. I have some catching up to do for the new and bigger ones!
I suppose the trick now is to find battery manufacturers who use REAL DEANS for their plugs.
I’ll be honest, I have a 100qty bag from eBay (and ran out which is why I’m here)… but I don’t want to mess with it when demand gets high. Charge connectors are about all that the cheap ones are good for.
andy
andy
Just joined the forum due to this post!
I went with Amass T plugs as they have a housing that's a bit easier on old slightly arthritic fingers and are available in packs of 10 from Amazon. Whether they are any good or not is up for debate, I've not had any issues in the year or so I've been using them but I only run 2S in crawlers and a 2WD Rustler.
Now on to the Power Poles. I use them extensively in my ham radio gear and like them for all the above mentioned reasons. They are an almost universally used connector in the ham world, many new pieces of gear come with them from the factory. They are available in different colors so a brushless motor can be color coded or you could color code your batteries by size/cell count. In the 15,30, and 45 amp sizes, the difference is the size of wire the contact can accept. The actual contact and housing is the same for each of the current ratings. This means you can mix and match wire gauge without compromising the crimp. A proper crimp is necessary to make sure the contact will fit into the housing. I have wondered if they get used in the RC world, now I know.
Michael
Michael
