the OFFICIAL R-40 thread !
#1302
CT
RE: the OFFICIAL R-40 thread !
I was thinking of going with the 05 hara, but I dislike the availability for the parts and the price. I'm sticking with my first gen R40 kit with minimal upgrades and make my way around the track quite well. I have the oneway now and 4 bevel gear diff to try...engine will be in very soon.
#1304
All the parts for hara edition are available online at towerhobbies(80%) and the rest is available at horizonhobby.com. I havent found a part for this kit that is not available online.
Come on, just get one.
#1307
CT
Yeah I'mma try to. I'm in the process of moving slowly, but surely to Stratford, CT. I still need to get more parts for my 8th onroad, more tires and setup system for the R40, bodies, digi servo, and then hmm..not sure what else, but gotta pay memberships and transponder. Right now I got more important stuff to spend $$ on and I basically work most of the sundays. I'll still run this R40 for the moment.
#1308
PA
ah, figured out my steering binding issue... the servo horn on my steering servo is the one that came with my JR servoes. it was flexing everytime i turned it. so it caused the ball cup to get stuck underneath the upper deck. any one know what kinda servo horn fits on the JR ones cuz the ones that came with the r40 dont. thanks.
#1309
CT
The R40 comes with several horns to fit different servos. Otherwise just get a new servo horn.
D- Just got my oneway and 4gear diff in. car is rollin a lot much smoother than b4 and I can't wait to test it.
#1310
NY
Sounds good, but it's pretty much impossible to be running two classes at the same time, you should take a break from one an focus on the other. Any expert will tell you that. [:-]
#1311
CT
I'm used to switching from class to class. Setting up the cars to my liking really doesn't take long either. I drove the 8th one day and swapped to the R40 in seconds running at bpt track. I've had mainly more experience with sedan, but 8th I've mastered in no time. I have enough $$ to support both cars and will probably start one class first then the next. I'd like to do 8th probably since my friend is dying to try my setup that has me glued to the track. Then maybe I'll turn to the R40.
#1312
As far as the R40 Hara Ed, How does it handle on the track? What are the benefits of the Hara Ed carbon radio deck and the Hara Ed fuel tank? With all of the available upgrades (lightened chassis, alum shocks, carbon towers, one way diff, etc.), can't one modify a stock R40 into a car that is just as good as the Hara Ed?
#1313
CT
See the 05 Hara as completely different upper deck and chassis. It also comes with a lower gear ratio for the big tracks. For the most part I'm running a slightly upgraded original R40 with no issue. It comes down to preference and setup. Though yes if you compare price of a NIB o1st gen R40 and upgradt to the new Hara it's definately not worth it. Shop around for an original R40 with gear for cheap or one of the 04 or 05 kits.
#1314
CA
hey d-nicest.... i jast wana know, wat kind of wheel do u use in ur r40? coz i saw ur pic, the color of ur wheel is yelloe green.. i like that,. plz.. tell me wat kind? wats the name? plzzzz
#1315
CT
Those are Ellegis. ATS makes the same style rim with red or yellow/green rims. www.brooklynhobbies.com has them for real cheap.
#1316
NY
Former ellegi, now jaco makes the exact same ones but with their own rubber, ats are similar but a little bit cheaper looking, and there foam does not have the quality that jaco has. Reason why is because they're inconsistent, one run they feel good then the next they're not. Sab whats up with the racing scene for you, makes me wonder if your ever going to be out there.
#1320
CT
D- I'm in Stratford, CT. For now I'm trying to establish living in the new place and working of stuff for my mom. I've also have to balance my budget and currently find a new job since traveling to my old town for the month will cost me $450+ ..just for gas. My current job doesn't pay for that either so I'll find something local. I'll definately be down for some races or practice depending on this new job's hours. I hope I get weekends off.
#1321
NY
Sounds like you got a lot of stuff going on. As of now for me, I'm trying to figure out if someone stole my R40 from my job or if it is hidden somewhere. [:@] but I'm pissed off, because the only way it would have gotten stolen is by someone putting it on the counter leaving there just for someone to come and take it without notice. I guy gave me 200 dollars down for that thing, I ahve to find it. Unless he took it.[][>:][:@]
#1323
ORIGINAL: Saboteur10573
#1324
NJ
One of the best ways to make it lighter is to use a 5cell AAA receiver hump pack. The hara chassis makes it lighter, the lw 2 speed and shafts also make a good difference. If you switch to a hara and get the lw parts it will put you at the roar limit of 1725 grams for racing.
#1325
CT
Hey I finished building my r40 hara (thanks to you guys helping me) but i have a problem withe the centax clutch.[:@] When i screw in the clutch screw to hold the bell on, the tighter i go the harder it is to turn the clutch bell (and not the flywheel)... i dont know what the problem is. What are your guy's set ups for the clutch.[:-] For example, like "I have ball bearing "B029" before the clutch bell and 3 spacers after the clutch bell..." sumpin like that
thanks
thanks
