RC Fuels Nitromethane, Castor Oil, Synthetic, heli fuel, 4 stroke, etc...Fuel Q&A is here!
Single or Multiple Fuel Pumps?
Old 04-24-2013, 10:37 AM
Default Single or Multiple Fuel Pumps?
I have Nitro Heli's and recently also got a Nitro plane that I want to get up in the air soon.
I run Byron's Rotor Rage 30% Nitro in my Nitro Heli's
I am going to run Cool Power 10% Nitro in my planes
Should I use separate fuel pump &amp; setups for each, or can I just use one pump? If I use one, any suggestions to clean when switching between the fuels?<br type="_moz" />
Old 04-24-2013, 11:37 AM
1QwkSport2.5r's Avatar
Default RE: Single or Multiple Fuel Pumps?
I use 3 or 4 different fuel mixes for my different engines and I use just one pump. I just switch the jug on my field box. I have a Hobbico field box and electric pump and all I do is reverse the pump to empty the lines of fuel back to the jug and switch jugs. However, I don't think it would be necessary to void the lines of one fuel to switch to another as the small amount of fuel in the lines won't change the nitro/oil content of the new fuel being pumped by anything really measurable unless your fill line from the pump is 6 feet long.
Old 04-26-2013, 11:13 AM
Sport_Pilot's Avatar
Just pump the fuel pump in reverse while pulling the fuel pick up from the jug to void the fuel from the line. IMO I agre with 1QwkSport2.5r, its really not enough fuel to worry about.
Old 01-30-2014, 03:37 PM
Three
Old 02-02-2014, 08:44 AM
I use just one. I crank the pump in reverse to remove fuel in the lines before switching bottles. That works well with my Dave Brown pump. Not sure if other pumps work in reverse.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
