Paint Gun Advice
Paint Gun Advice
I was able to finally use some “real” paint.
My local Napa Auto Parts will put automotive type paint in a spray can and all the paints (except for the last base coat!) were awesome to work with! Quick dry, super hard and easy to mask! Waaayyy better than rustoleum.
I have been reluctant to buy a paint gun because I HATE cleaning paint and I will not paint indoors, too much nastiness to breath in.
I was using the paint cans thinking they would be more reliable than rustoleum paint cans, well that was a pipe dream. As I applied the last color, the can started sputtering and spitting after only a few seconds! Uh! What a pain.
Sorry for the rant! Tell me, what do you guys/gals think about this gun? Is it an appropriate gun to paint our models?
https://www.eastwood.com/eastwood-co...inum-case.html
Hey man. Hope you have been well.. That gun should be fine for you..Have a look, disposable liner system. makes the clean up sooo much better and faster. and always use the little water traps.
https://www.eastwood.com/3m-pps-larg...-pk-of-25.html
https://www.eastwood.com/eastwood-ai...ir-filter.html
Jeff
Jeff
My Feedback: (22)
We spend thousands of dollars on these jets and then buy cheap crap to finish them. I've never understood that. No a good gun wont make you a good painter but a cheap gun almost promises a crappy paint finish.
I've done a couple of articles on guns here over the years.
http://www.rcuniverse.com/forum/rc-jets-120/10519362-advice-paint-guns.html
Post 15 in this one
http://www.rcuniverse.com/forum/rc-jets-120/11158944-paint-gun-recomendation.html
Post 15 in this one
My Feedback: (23)
http://www.rcuniverse.com/forum/rc-j...aint-guns.html
Post 15 in this one
http://www.rcuniverse.com/forum/rc-j...mendation.html
Post 15 in this one
So well said ! Pay cheap = pay double ...plus repainting a model=disaster. For me only SATA mini jet HVLP . And yes price does reflect end painting result .
I strongly suggest you buy the electronic versions of the JetPower Magazine with the articles of Ralf Schneider "how to paint" . An amazing source of know-how.
my2c
My Feedback: (23)
I use a McDonald’s straw with a siphon attachment and a Walmart cheap 12volt tire inflator. I also visit Starbucks and take the wooden stirring sticks and use them to mix my Michael’s water based paints. I clear my projects with an egg tempura type top coat. Worked great for the masters for over 200-300 years. Save thousands omitting automotive paints, sprayers etc.
Bwahahahahahahaha!!!
And I bow to the power Jeremy! I know you KNOW your stuff. I will get a good gun (likely what you recommend) and I’ll talk to local body shop suppliers to make sure I have local support.
Thank you everyone for your advice!! This is why I love RCU!
my2c
my2c
My Feedback: (71)
If you want a good system doesn't break your wallet get the 3M gun you can even dispose the tips after paint if you want or clean and reuse this is what i used and comes with all the tips you will need I have a $800 Sata and this will paint as good
3M 16580 Accuspray Spray Gun System with Standard PPS
My Feedback: (15)
Talk about a "GREAT" painter, LGM Graphix is a fabulous painter. Had him repair and paint a clear canopy for a jet model.. He lives in Canada, I live in Alexandria, VA and it turned out to be the best money I spent on that jet. Wish he lived south of the northern border. I have a complete jet for him to paint. Chic
Don't forget you also need to have a decent compressor and make sure you have a filter to eliminate water and oil. I have a 30 gallon one, seems to be reasonably adequate. I've shot paint with smaller ones, you can do it but, you're constantly stopping your work and waiting for the tank to fill.
Thank you to Jeremy for sending me his Sata. I’m just awaiting a part to be able to use it.
My local place sold me a gun with a 1.8 tip (not a Sata) for $150. Apparently the 1.8 tip is good for primer and clears. Also, this gun should be good enough to start practicing with.
And OMG am I glad I did. I bought a gun mounted pressure regulator and water trap and some paints to get my feet wet, sort to speak.
You painters have reached a whole new level of respect, AGAIN!
I initially put lacquer thinner in the cup and started messing around just spraying stuff. And talk about flash back to tuning a 2 stroke engine with a low, mid and high needle setting!
I had to adjust every thing that I could adjust (pressure, paint supply, other needles that I don’t know the name of) to try to make some spray come out in a decent pattern. Ugh.
I thought I’d just put all the adjustments in their middle ranges and I’d get close, I mean RIGHT?!
Not even close!! I had to adjust every parameter to get a spray pattern that would lay down decent paint, ie not too thick, not too thin.
Finally, I just put water in the cup and adjusted to my heart’s content.
About 30 minutes in, I was pretty happy. Time for more thinner and then paint.
After a little more adjustment, I was throwing paint. So far so good. Hold for results.
Again, learning how to paint is WAY cool and much respect to painters.
Hey Raf.. You are definitely approaching it the right way now. Like you, I started with aerosols, and then cheapie guns with no filters or proper regulators. Ended up with a Sata Minijet!
The clean up is not so bad. You just have to factor it in before you start. You get quick at it after a few cycles.
Looking forward to seeing what you can do to the A-10
