Discarding last season's kero ?
Hey Folks,
Firstly,
What do you guys do with the left over turbine fuel from last season?
Chime in if you have a recommendation. As of yet, I have not figured out who in my area will take this off my hands.
Secondly,
Is there any one out there currently building the Jet-Mart large scale A-6 Intruder?
If so, could you please share your pro/cons in reference to the build. I have been considering this for my next large jet, however, there is very little in the way of success story with regard to this behemoth of a kit.
Of course this build would certainly take the better part of a year to complete, as such I envision the power of two Simjet nexus 3000's. A great scale rendition of the landing gear, perhaps by our friends at the Sierra gear company. By the looks of them, they seem to share similar design to the F-14 Tomcat. And naturally, a full complimentary cockpit with working back-lit instrumentation for the pilot and weapons system officer. And the external stores that made the A-6 a real workhorse for the Navy and Marines Corp.
Thats it folks, quite the request, but hey, I need to get craking on a new jet soon.
Happy Holidays and a safe and healthy new year.
Frank and family.
Firstly,
Secondly,
Frank and family.
AB, CANADA
RE: Discarding last season's kero ?
Firstly,
FL
I'm storing mine in the garage to keep it from geting too cold. Raise it off the concrete floor on a 2"x4" platform, and use it next year.
It should be good to go.
Harley Condra
BVM REP
JetCat REP
Harley Condra
BVM REP
JetCat REP
AB, CANADA
I don't know..I went through this last year and it was suggested to keep it off the concrete. Seemed reasonable and easy to do, so why not? It got to 30 below in my unheated garage last winter...I don't know if it turned solid or not.... I didn't waste any time getting from the warm house to the heated car t ocheck on it....
I'll 2nd Wayne's comments. I've had a mixed fuel / oil jug last a very long time with no discoloration. The key is keeping it in a sealed container. I made a machined aluminum cap with o-ring seal and Festo bulkhead fittings just for this reason. Seems to do the trick.... The fuel's longevity may also have something to do with the kero jug not being clear, as the blue plastic likely has some UV / visible light blocking ability that may be beneficial. I don't know if keeping it off a concrete floor helps or not, but after reading this I'm goinna move my jug since its a pretty easy fix.
Happy Holidays,
Kelly
Happy Holidays,
Kelly
ORIGINAL: Harley Condra
I'm storing mine in the garage to keep it from getting too cold. Raise it off the concrete floor on a 2"x4" platform, and use it next year.
Harley Condra
BVM REP
JetCat REP
Harley Condra
BVM REP
JetCat REP
I think that the only issues with "old" fuel would be moisture intrusion and then the subsequent algae growth. I use Jet-A that has additives in it to curtail the algae growth. So keep the container sealed and out of the direct sunlight and it should be fine........"Last Year's Fuel"....not an issue in AZ anyway!
Happy Holidays,
John
FL
Too cold!!!!
The Airbus probably uses Jet-A1, which contains additives to allow it to flow at -36C.
I use Jet-A, which has no anti-freeze additives like Jet-A1.
Right now the OAT is 22.6 degrees F. in Kalispell, Mt. We're having a heat wave! It was 15 degrees this morning.
The condensation is the only problem with the low temperature, and since I don't use additives, I keep it above the dew point, as the algae grows in the water at the separation point.
The photo does't show the additional 6" of snowfall that we have now. I leave it in my 20 foot trailer when the weather is a little warmer.
Harley Condra
BVm REP
JetCat REP
Harley Condra
BVm REP
JetCat REP
My Feedback: (12)
FL
Nope, Airbus regular Jet-A. The -36C is a limitation because colder than that the fuel begins to crystalize. -36C is pretty much the normal limitation for other aircraft also that I know about. Rare to get to that -36C but have been there before. Needing to go faster to heat it up after a long transcon in super cool winter air (I think it was -72C that day at altitude) but had to give in and go lower trying to warm it up.
Frank
You can always get rid of it on a nasty neighbors lawn you don't like
BC
Frank
BC
FL
Mel Santmyers?
Howya doing, old friend? Long time no see.
I'm retired up here living the good life! What are you up to?
Frank,
Does the Airbus have fuel heater/oil cooler engine oil coolers that double as fuel heaters? I have some P&W experience with them in years gone bye. (P&W T-34P-9W's on JP-4.)
I checked some of the jet fuel technical info websites, (MSDS's and such) and found that the freeze point of Jet-A is -40 degrees C, and Jet-A1 is -47 degrees C. The anti-icing inhibitor package in Jet-A1 is to just to keep the ever present water in the fuel from freezing.
Harley Condra
BVM REP
JetCat REP
Frank,
Harley Condra
BVM REP
JetCat REP
My Feedback: (12)
FL
Harley, I think that was for me. Yes fuel /oil heat exchangers installed but they can only do so much in those conditions. You are right on the -40. Most limit it to -36 so you never get to -40.
Now I'm getting cold! have to get some more adult beverage/antifreeze in me LOL Yea I know its 78 outside but just thinking brrr cold.
Holiday Cheers to all,
BC
BC
ORIGINAL: Frank Alvarez
Hey Folks,
Firstly,
Secondly,
Frank and family.
Hey Folks,
Firstly,
Secondly,
Frank and family.
http://home.earthlink.net/~matrixmt/id8.html
Do what I did,
Go to home depot and buy one of those steel round gardening tubs, about 10 or 20 gallons or so and dump it in there and have a nice fire in your back yard. It makes for a REAL NICE campfire in the cold weather... you just have to keep moving to keep out of the smoke when the wind changes direction. I burned like 2 gallons at once and it was a handful.
FL
Jet Jocks,
I have decided to do the jet community a public service. At the end of each flying season send me all your unused Jet-A or K-1 with or without turbine oil for proper disposal. I will personally see to it that it is disposed of properly. Our service will follow all the applicable rules and code requirements concerning disposal of hazardous materials. There will be no charge for this public service.
Don't risk damaging your engine next spring with that old fuel! Fuel must be shipped or delivered to Stuart, Florida.
Jetboy
Jetboy
