Landing gear C-ARF eurosport?
Hello guy's!
At the moment I am rebuilding a damaged Eurosport. (wing damage) maybe some good tips???
I bought the eurosport second hand without the gear. What is the best way to go here?
Robart 635? or jet 1A? behotec?
Any input is more than welcome!
Thanks in advanche Henk Visser
RE: Landing gear C-ARF eurosport?
I say the Robart 635 set with Intairco wheels.
I have this setup on my Euro and after 3 years and hudreds of flights, i've had no problems and they are still good as new. No leaks and the units are still tight. I have had to touch a screw since new, just cleaned and lubed the axles a few times.
You can get this kit with wheels at www.dreamworksrc.com Great service!
I also use the Robart gear with BVM wheels and I'm very satisfied.
Our grass field is pretty rough but that is no problem at all for the Robart gear.
I first have used the standard gear from c-arf but that was not a succes.
Dick
Dick
thanks for the info on the gear!
Wolfhounds i sented you a pm!
John the wingpanels are a easy repair i suspect, but i will keep you offer in mind thanks anyway!
reagards, Henk
reagards, Henk
