is it safe like this??
Hello,
I am in the final phase of completing my FeiBao Rafale. I have installed 2 smoke tanks on top of fwd section of turbine and lower part of Bypass attached (actually only fitted) to tailpipe mouth.
I am not comfortable with 2 issues:
1) are smoke tanks too close to turbine? will they melt due to heat or is it safe enough to install as is? (red arrows on photo)
2) Should i fix tailpipe to bypass with screws/nuts or other or should i live setup as is bearing in mind that tailpipe is secured to turbine mount (blue arrows on photo).
Thanks for your input and suggestions.
Regards.
Regards.
