Which is a better deal?
FL
This- http://www.rcuniverse.com/market/item.cfm?itemid=421111
or this- http://www.rcuniverse.com/market/item.cfm?itemId=420216
It is for a 4 channel EDF I plan on buying later this summer to fall.
RE: Which is a better deal?
Note tht old Vanguard is a plain featureless Tx long discontinued. It has dual rates and reversing thats it. Nothing else. If what you want it for requires elevon mix (many EDF's) then you are SOL.
That other system I have never heard of. You will be better off with any of the four majors than those rebranded no names.
John
John
You know that Vanguard is not a VG 600 as labeled in the ad, Its interesting that model ID is the current model of Airtronics plain 6 channel Tx. I thought there was something wrong so I pulled out an iidentical one (I thought I had thrown the last of them away) and the proper ID of the old Six channel Airtronics FM Vanguard tx is VG 6dr.
Be aware with that relabeled whatever it is, very unlikely you will ever be able to get any kind of factory service if neccessary.
E Bay is the very worst place for new folks to look for a bargain but you can find a lot of heartburn and equipment you cannot use.
John
John
ORIGINAL: wrcsti
I plan on buying a V-tail mixer. So I should take the old futaba? thanks for the reply.
http://www.hobbycity.com/hobbycity/s...idProduct=4170
Both radios are too expensive at any price! Its kinda like looking for water by peeing down a dry well.
John
FL
ORIGINAL: JohnBuckner
John
John
FL
John
ORIGINAL: wrcsti
John
How about this?
http://www.rcgroups.com/forums/showt...4#post10289819
First thing I would stop looking for used stuff. New flyers should only purchase new equipment when it comes to the radio link. Never used. Later on perhaps after you know a little more about it then yes you many want to take a chances here and there.
Purchasing equipment stick to the majors: Futaba, Hitec, JR or Airtronics. All have excellent entry level computer radio systems all will have a variety of mixing and all will be capable of programing more than one airplane.
I do not follow radio prices but they all offer good systems that usually can be had for somewhere between perhaps 120 to 150 bucks. I am sure others will chime in here with some good systems and prices.
John
John
FL
Im not new to the hobby, just moved and had to sell my plane and radios about 4 years ago and wanted to make sure that everything is just like it was before.
