gears falling off, tips?
so i was out with my hpi crawler king today. 5 minutes into climbing the pinio popped off. not a big deal at first. got it back on nice and tight, then 15 minutes later the spur pops off. got it back on and another couple minutes pass and the pinion pops off again. any tips on prevevting this from happening. i am getting them tight but they are just popping off again and again. thanks
RE: gears falling off, tips?
i was thinking maybe locktite on the spur gear screw, as for the pinion gear all i can think of is maybe tap the motor shaft so that the set screw can bite into it?
the pinion and set screw are bran new. ill try drilling th motor shaft. just gotta get the drilled hole perfectly aligned with where the pinion needs to be positioned in line with the spur
ORIGINAL: diabolic-mind
Don't bother. Just use loctite and a good set screw. That's how its been done for 40+ years. Drilling the shaft is just an accident waiting to happen.
awesome, i used a bit of locktite on bot hthe set screw and the screw for the spur gear and had two runs without and issue. its hard to think that with as tight as i had the set screw before it could loosen up like it did. just the little extra help from the lock tite did a tremendous job.
my 1/8th truggy, and savage both would pop off their pinions so I got fed up, and smeared loctite on the shaft before I put the pinion on as well as in the grub screw hole. The pinions have not budged since I did that. And they are still able to be taken off (just need a tap from a hammer). Can't say I had issues with 1/10th's and down as I did with 1/8th pinions though they usually stay in place where they are cranked down.
In most cases loctite is the only way to go. By stopping the screw from moving it cant loosen. That's why important things have extra hardware to lock them in place.
Except on my rock force where the smallest screw on the whole rig kept backing out even with locktite. A little welding and I don't see that part coming loose again.
IL
ORIGINAL: jermpool
Green loctite or red loctite
Read loctite is made to be permanent. It you want to remove it, you must heat the screw/pinon. Otherwise you'll strip the screw
Blue loctite is best in most cases. You don't need to heat it and I have yet to have one come loose.
link, that file tip is actually a great idea, its similar to what i was thinking with drilling the hole but alot less complicated. if i have any more issues i think that is the first thing im doing next. todays project is stiffening up all the slop in the stock steering on my hpi crawler king. my only complaint about mounting the servo on the axle is with the stock shocks it interferes with the articulation. for now im gonna beef up the stock links so they ont flex as much. i already replaced the stock plastic links on the front and made some new links out of tie rods from another truck.
