Panzer III L Project
CA
So a while ago, maybe a couple years by now, my PzIII broke down on me. The gears stripped and I ordered the mato metal upgrade set. Fast forward to now, and i'm back on it. You can read about it on my blog here:
http://bhop73.blogspot.com/2011/07/1...zer-iii-l.html
but here are some teaser shots.
CA
RE: Panzer III L Project
ORIGINAL: ROLLIN ARMOUR
I have some coming in the mail from Welsh. Are they simple to put on?
Not difficult at all. Basically you'll need to shave/cut most of the original part off. The metal parts each have three prongs sticking out, so you'll need to drill holes in the back of the hull. My set, which I assume is the same as yours, had a template for the holes. Once the holes are drilled, you just glue the parts in place with some strong glue, like epoxy or super glue. I just used super glue, I figure the track tension will keep it from weakening.
ON, CANADA
bhop:
Where's ya get the PE intake/exhaust grilles? And please, when ya show pics of other goodies, let us know where we can find 'em too pls?
Thanks! I've got a Pz. 3 to work on meself, once all the bits shiow up.
CA
ORIGINAL: WhiteWolf McBride
bhop:
bhop:
http://www.welshdragonmodels.co.uk/
CA
Small update.. descriptions and a couple more pics on my blog:
http://bhop73.blogspot.com/2011/07/1...d-7-31-11.html
CA
Here's another update. Details on my blog:
http://bhop73.blogspot.com/2011/08/p...to-detail.html
Some pics.
Some pics.
CA
What is the green putty you use for the welds? Cool headlight covers. Scratch built?
CA
Doesn't seem like anyone really cares, but here's an update anyway in case i'm wrong.
http://bhop73.blogspot.com/2011/08/p...for-paint.html
Ready for paint!
Ready for paint!
I'm following this build with great interest and I'm sure I'm not alone. Keep on the updates, it's looking superb and has given me some top ideas for my future PIII build.
CA
Thanks guys!
The tracks, suspension, sprockets and idlers are all metal, from mato.
ORIGINAL: Mathom1
Ditto...keep sending updates. Did i miss it .... are you running metal or plastic tracks?
These PzKw III and IV builds are the best!! The machines are so full of detail, and mechanical bits that you don't see as much with Panthers and KT's. Love this build thread, please keep us posted and thank you for the fascinating read so far!! Cheers.
BC, CANADA
Putting in all the little details you have done like the tow cable clamps and brackets, headlight wires and weld beads are time consuming but really make the tank stand out. What kind of paint scheme are you going with?
CA
ORIGINAL: smittyrob
bhop73,
I agree with all the other posts. Your PZIII is looking great and I have followed along from the start. I also plan on doing a PZ III from the battle of kursk ( used as a command tank I believe ). I plan on adding side skirts. It will be a companion tanks to my PZ IV. Again, thanks for sharing and do keep posting.
Jim
Jim
This is one great looking Panzer III! A lot of detail, homework and sweat equity went into this.
Just keep showing your work. You've been here long enough to know how the other members are.
- Jeff
ORIGINAL: bhop73
- Jeff
