The Official Tamiya TA05 Thread
Old 04-24-2008, 02:09 PM
  #226
Default RE: The Official Tamiya TA05 Thread
The porsche.I have 2 kits.
Old 04-24-2008, 04:53 PM
  #227
BigT441's Avatar
ORIGINAL: rcluke
difference in degree / shore / color is how soft the compound of the foam is.
the higher the number, the harder the compound.
the softer the number, the softer the compound.
for carpet racing, i used to use, 42shore 26mm wide tyres on the front, and 36shore and 30mm wide on the rear.
thanks alot luke. foams are new to me, so I had no idea what the numbers meant.[&:]
Old 04-24-2008, 05:23 PM
  #228
ORIGINAL: AutoXMan
Those foam tires will last longer than rubber tires on asphalt?
Yes and No. The parking lot I use for Practicing has a lot of rocks so the foams chunk pretty easily. So when I'm bashing I use the stock rubbers. Its the only time I use them so they last me a while. I burnt the tires off(2sets rubber) the TT01 I had just running a CO27 and 58spur 23pinion. So far the TA05 slicks have held up better.
Old 04-25-2008, 12:16 AM
  #229
Ahh. I think I've just chewed up my spur gear. I was testing some changes just doing straight runs in the car park at work during lunch. I was running fine until It started making this chunk chunk noise.. stopped and checked. I can turn the spur one way almost all the way until a point, it stops... then I turn it almost all the way the other way and it jams at about the same place. Looks like a new one is in order.
Lesson 1:
Don't run it in a carpark with lots of small rocks. I was afraid of the belts, but the spur got bitten...
Thank goodness it wasn't the diff though. phew.
Off to the LHS to get some more parts... at least this part is fun.
Old 04-25-2008, 10:33 AM
  #230
rcluke's Avatar
ORIGINAL: littleleon
Lesson 1:
time for 64dp ?
Old 04-25-2008, 10:42 AM
  #231
just wondering what you guys do for basic maintenence, what do you check ect?
after a race, I strip the the wheels and axles clean the grease of the axles and replace with new grease, (the old grease usually has carpet fluff and crap on it, check belts for wear & tension, and basically clean the car, check toe ins are correctand that the wireing is ok and that no screws have come loose.
just wondering what you guys do, and do you have set times for changing stuff like suspension oil ect, or do you do that on a regular basis, ie after every racing session?
Old 04-25-2008, 10:49 AM
  #232
rcluke's Avatar
ORIGINAL: Mad Fox
after a race, I strip the the wheels and axles clean the grease of the axles and replace with new grease, (the old grease usually has carpet fluff and crap on it, check belts for wear & tension, and basically clean the car, check toe ins are correctand that the wireing is ok and that new screws have come loose.
i take it off the track, turn the car off, remove the transponder and put a cooling fan on it.
i am gonna start doing more maintinence.
Old 04-25-2008, 11:27 AM
  #233
rcluke's Avatar
a pic of the TA-05IFSR
looks pretty sweet, i wouldnt mind one, as a second runner.
http://www.hlj.com/product/TAM49491
Old 04-25-2008, 11:33 AM
  #234
can't see much of a difference to my IFS, except that it has a few bits painted blue. [sm=72_72.gif]
Old 04-25-2008, 11:35 AM
  #235
rcluke's Avatar
ORIGINAL: Mad Fox
it will have a few different parts also, the belts, bushings etc.
when tamiya america get the specs, i will post them up.
Old 04-25-2008, 11:38 AM
  #236
rcluke's Avatar
TA-05R
the different parts are,
from Tamiya america
About the Model
* All-new aluminum center plate, blue anodized aluminum spur gear holder, and carbon fiber damper stays reinforce the chassis while reducing weight.
* Impressive list of included option and spare parts:
51000 High Torque Servo Saver (Black) $8.25 MSRP
51065 TRF415 Suspension Mount (A) $10.50 MSRP
51068 TRF415 Suspension Mount (D) $10.50 MSRP
53539 5.5mm Aluminum Spacer Set $8.75 MSRP
53640 5mm Aluminum Bolt Nut (Blue) $7.50 MSRP
53642 5mm Aluminum Ball Connector (Blue) $7.50 MSRP
53644 Aluminum Stabilizer End (Blue) $6.50 MSRP
53685 TRF415 Front Bridge Suspension Mount (A) $14.00 MSRP
53823 Clamp Type Aluminum Wheel Hub (5mm thick) $21.00 MSRP
53836 48mm Swing Shafts for Assembly Universal Shaft Set $15.00 MSRP
53849 TA05 High Precision Diff Joint $18.00 MSRP
53857 04 GP Spur Gear 105T (TA05) $4.30 MSRP
53869 5mm Aluminum Short Ball Nut (Blue) $10.00 MSRP
53871 48mm Lightweight Rear Swing Shafts (Blue) $16.00 MSRP
53874 TA05 High Precision Center Pulley Bushing $3.60 MSRP
53894 TA05 Carbon Reinforced A Parts $18.50 MSRP
53895 TA05 Carbon Reinforced K Parts $9.25 MSRP
53897 TA05 Aramid Drive Belt (Blue) $9.00 MSRP
53899 Reversible Lightweight Suspension Set $117.00 MSRP
53918 TRF Damper Low-Friction V Parts $6.00 MSRP
53935 TA05 Wide Pitch Diff Pulley $6.75 MSRP
53571 TRF Fluorine Coated Damper $76.00 MSRP
53842 TA05 Stabilizer Set (F&R) $18.00 MSRP
* TRF Dampers (Blue), Damper Springs (White), Front/Rear Stabilizers, and Aluminum Turnbuckle Shaft (Blue) are also included in this assembly kit.
* R/C system, ESC, battery, body, motor, tires, and pinion gears are sold separately.
Old 04-25-2008, 12:55 PM
  #237
Cheers for the list Luke [sm=teeth_smile.gif]
Old 04-25-2008, 01:03 PM
  #238
rcluke's Avatar
does anyone have a 5.5T brushless in the '05 ?
Old 04-25-2008, 04:43 PM
  #239
BigT441's Avatar
I don't dare run that high yet.
Old 04-25-2008, 09:13 PM
  #240
My LHS recomended that I replace the Tamiya gears with Kawada. I'll be doing that after my next run. He managed to help me get the original spur gear back online, but it wont last forever.
I really love that place. (the LHS that is) I could just about live there
Old 04-26-2008, 07:34 AM
  #241
rcluke's Avatar
go to 64dp
the ones on rcmart are fine (i run a yeag racing spur and a kawada pinion ... i think[&:])
Old 04-26-2008, 09:07 AM
  #242
BigT441's Avatar
anyone have advice on the TRF special damper set compared to the Yeah Racing alloy damper set? I'm stuck on which ones to buy.
Old 04-26-2008, 09:29 AM
  #243
rcluke's Avatar
ORIGINAL: BigT441
no question about it.
if you are racing, you need the TRF's.
they are smoother and far superior.
plus they look cool inside (the same color as the M-03R chassis)
Old 04-26-2008, 09:31 AM
  #244
BigT441's Avatar
yeah I figured that. lol, thanks luke [)]
Old 04-26-2008, 09:35 AM
  #245
rcluke's Avatar
ORIGINAL: BigT441
you will not be disappointed with them.
rcmart have them quite cheap at the moment.
what oil do you use?
i would also recommend getting some different springs, Tamiya on-road tuned hard ones.
Old 04-26-2008, 09:43 AM
  #246
BigT441's Avatar
I'm using.... 100W shock oil
and you say the TRF damper set is on rcmart? I can't find them [&:]
Old 04-26-2008, 10:04 AM
  #247
rcluke's Avatar
there you go [)]
http://www.rcmart.com/catalog/product_info.php?cPath=389_390&products_id=23733&p name=Tamiya%20(#42102)%20TRF%20Special%20Dmaper%20 Set%20(Hard%20BK)
Old 04-26-2008, 07:30 PM
  #248
Does anyone know of any sites i can order TA-05 parts off of and get them shipped to Australia within a week?
Old 04-26-2008, 07:32 PM
  #249
ORIGINAL: BigT441
wow 100w shock oil on a touring car! Are you racing asphalt or carpet? Foam or rubber tires?
Old 04-27-2008, 04:58 AM
  #250
Had my first race today , came 4th out of 10 on my first race even though my drive belt slid off the center pulley and was not turning. btw how do you fix that problem? on my TA-05 on the center pully there is the 2 cog things but nothing stopping them from sliding. mine just slide around sometimes. Also my ESC cable was rubbing against the rear tyres which resulted in the cord being cut clean through the middle, so that cut out my last 2 races.
