Carl Goldberg Ultimate 10-300 Brotherhood.
#301
My Feedback: (156)
![Default](https://www.rcuniverse.com/forum/images/icons/icon1.gif)
One of the reasons i made so many changes during building, plenty things are little nostalgic on the original design from Dave Patric (worked for Goldberg at that time). The ARF was different in many ways already and i harvested some ideas from other Airframes i build. made it easier for me to work on them. The original design is a different Airplane every time you disassemble and reassemble the Plane unless you have dowels or guides holding the Wing where it is supposed to be. You can see in my last picture a little seam at the Tail by the Elevators, i made the incedence adjustable just as well, made all the things i did not like better.
Have a build the
Michael
Have a build the
Michael
#302
BC,
One last comment, I design and build lot of planes,all the way from little trainers to my 103 inch Herc, wing incidences are so important and all my planes are built in jigs and set up with incidence meters,without them how can you set up the Ultimate with + 1 1/4 on the tail plane a 0 on the main, Mike
#303
ORIGINAL: alfredbmor
That will be great, we are thinking on making a kit, taking in mind all those mods. that people has been doing on it, so it will not be an original blueprint copy, but we will save the flying characteristics and focus on keeping light.
The main idea is to have a backup scheme of every single part of the kit, then in a bad case of an unwanted crash, we all can remake the broken parts and keep a strong brotherhood.
Please note that, at the end, we will share the drawings as a backup and we wont make any profit from them.
Please stay tuned, I am sure that good news are coming along.
Alfred
Alfred
![Smile](https://www.rcuniverse.com/forum/images/smilies/smile.gif)
Has anyone flown this bird with an OS 110 alpha?
#304
My Feedback: (18)
OH
ORIGINAL: raubold
I added a Canopy hatch, easyer to acces Radio geaer, some more pics, one is 90 finnised state, now DLE 20 waiting for new Cowling
was flown and finished 6 month ago with saito 125
#305
ORIGINAL: bigal126
Adding a canopy hatch is a great idea. Highly recommended. Makes getting to raidio gear a breeze and also pretty much solves the CG balance issues with the larger heavier engines being installed in this bird.
ORIGINAL: raubold
Neat and explicit picture by the way.
Thanks Bigal
#306
ORIGINAL: peternj
Alfred, you are right! Good news is in the air! I bartered plans for hard copies of all the parts which will speed this up thanks to <font color=''#00265e''>frequent flyer</font>! I will have them scanned and out to you sometime tomorrow in PDF format. I've compared the copies against our copy of the plans and they are a 100% match. Let me know if converting them to TIF or other format would help.
pdf and jpg would be more than fine.
#307
I am compensating with dual servo elevator, an 8 oz tank, IBE and going to install the battery last to play with final CG. I might have to go push-pull rudder. Not quite that far yet. I'm considering a few mods now with the cabanes.
I'd be in line to try out some foam cores!
#308
ORIGINAL: WarbirdAirRacer
Alfred, if you/we went with foam core wings they would be lightened and fully sheeted and ready to install servo wiring and join the wings together. And outter wing strut ribs would already be installed.
How do you make the outer wing strut ribs, with out cutting the foam?
I believe that we need to insert in first the wing strut attachments, then apply a coat of balsa sheeting with the right dimensions to have all square up. isn't it?
Feed please, we all are following the thread with the same goal.
#309
My Feedback: (156)
before you button up the Servos, what engine are you planing to put on it ??? I needed both Engines, YS and 125 Saito the Servos in the tail to ballance ok
#310
My Feedback: (156)
Bolt thru Wing in Strut, 440 good enough, works on mine after i made the changes during building and in a Foam Wing a 3/8 Cherry wood dowel drilled after sheeting lets the Allen head almost disapear flush with the covering. Since the wing is differen, different struts dont matter.
#311
To keep notes:
Its really simple! I make a lite plywood rib just like the build up wings have and epoxy them into the foam core before I sheet them. and you have to cut the foam core in half or you can cut out a slot for the rib. I also add rocket tubes to the cores before sheeting as well. So when the customer gets the wing kit all he has to do is run his servo leads/install servos the servo doors (already made), join the wings together/glass the center (just like on the kit) and hinge the ailerons, and sand for covering.
#312
IL
ORIGINAL: THEJADEGROUP
I am recovering a CG Ultimate that I purchased and will be changing the cowl. I purchased a new cowl from Fiberglass Specialities. What suggestions do you have for mounting the cowl to the fusalage?
#313
... when the customer gets the wing kit all he has to do is run his servo leads/install servos the servo doors (already made), join the wings together/glass the center (just like on the kit) and hinge the ailerons, and sand for covering.
#314
Alfredbmor, Bostonba745
Please check your your inboxes and let me know if you got goodies from santa....
So to update the brother hood.... Alfred now has plans for the kit, manual, and most of the formers (minus fuse side, top, bottom, and turtle deck). I think the ball is now in his court to digitize any upgrades into the back up plan....
let me know how things turn out!
#317
Chuckar, welcome to the Brotherhood, you have to feed how the YS-140 is doing with your ultimate, thanks for the pictures they are really nice.
#318
ORIGINAL: peternj
I have not received any new files yet, either so I am drawing over the scanned page that you sent initially.
I'll keep an eye on my inbox.
Alfred.
#320
My Feedback: (158)
ORIGINAL: bigal126
ORIGINAL: raubold
did you get a new kit??
Guess what I bought?
#321
ORIGINAL: Revy
Sold!! Now how much $$ do I have to hide from the wife, lol!
I get a 200 for both with wings.
#322
ORIGINAL: peternj
WarBird, can you recomend documentation on the P-40 for scale details?
Yes I can, however it will be later today before I can get it to ya.
Sorry I been away for a bit....gotta hate work sometimes.
hope everyone had a great Christmas!........what did yallz get?
![Big Grin](https://www.rcuniverse.com/forum/images/smilies/biggrin.gif)
I got a new E-Flite Ultimate 20-300 [8D] I will post pics later today.
#323
Thanks Warbird!
I got a Top Flite Spitfire MK IX Wulf Hunter Gold edition 1/7 scale.... this completes my Top Flite war bird collection I wanted.... Spitfire, P-40, P-47D, P-51B, F4U.... and the odd ball DC-3.... I need to double up on the kits just in case I get dumb thumb syndrome....
Guess my other hobby is collecting kits since a lot of them are out of production...
And my prize gems are the 2 CG Ultimates I got... one of which is being built and traced for Alfredbmore's backup project we're working on...
HAPPY NEW YEAR EVERYONE!!!!
#324
Peter, you can start here.... http://www.p40warhawk.com And I will work on looking for one other great link I know of...
#325
WarBird, that is a really good site. The other details I'm looging for are the panel and rivet lines... As far as the paint scheme, that's still to be determined, but I do like those shark teeth....
Off topic, but I was wondering if you would know where one can find examles, kits, plans of rc planes for either the YAK-3 or the MIG-3? They have very similiar lines to the hawker and P-51B.... not the same but kind of flow like that...
