![Default](https://www.rcuniverse.com/forum/images/icons/icon1.gif)
Jim, I just sold my LASER 100 so I'm coming into a little money. I think I have one of all the worthwhile Saitos. Two of some, two .65's two little .30's, two FA .40a's, two .56, two .62 etc.
Jim, I just sold my LASER 100 so I'm coming into a little money. I think I have one of most of my fave Saitos. Of course any Saito is a fave. Two of some, two .65's two little .30's, two FA .40a's, two .56, two .62 etc.
The Japanese certainly took over the market I loved it too. Made a lot of Britbikes available for cheap. Plenty of Bonnevilles and Commandos sitting around in backyards for$100. I always appreciated the edge that they had in handling over the Asian bikes The Ducati and Guzzi likewise. For durability the Guzzi are superb and they have a pretty good race heritage as well. My 1983 daily driver Guzzi California II has 198,000 miles on the clock when I sold it in 2010. No major repairs. The ham radio buddy I sold it to is still riding it.
The Maico Breako thing was just something my brother in law came up with. He and his racing partner got rid of the Maicos at the same time. He bought a Bultaco and his buddy got a CZ. They both did quite well on those two bikes
Speaking of Brits. I wonder if there will ever be any more new Lazer engines. I see they are out of stock but no further words on the new shop
My neighbor in W.Va. rode a Bultaco 200, people used to scream at the MX officials when they would let him race in the so called 175 class, as a race starter I knew that the rule book said 126 or 151 to 200 I forget.. He was one of those guys who was graceful like a ballet dancer, he looked like he was going slow but was always nearly half the race track ahead of the second place guy. He was sneaky fast as they say.
I have plans for a B-17 from Jan Hermkins. It's 1/10th scale, and plans show a .40 2 stroke for power. What Saito with CDI would work to replace the 2 strokes? I'm thinking the FG-11 might do it, or the FG-14, but want to be sure before I start my acquisitions.
The FG 11 has a bore increase of .03" over the Saito .62, (bore 1.03) to make a .66, (bore 1.06) it is a sweet running engine. I have one and I like it.
Here is what I wrote concerning the FG 11 on March the 8th of 2017:
Thanks Jim, and it works'
Saito FG 11
Prop===Xoar 13x6
Fuel===Gulf Gasoline, 89 octane ethanol free/Mercury Marine two stroke full synthetic compatible with water or air cooling@ 20 to 1.
Stock FG 11 Ignition=RCXL
95 minutes total run time, I ran the tank 1" lower than the first run, there was no difference in the running.
Max rpm stock muffler== 9,155
Max rpm Turbo Header==9,293
Idle RPM with both=2,150
High Speed needle is sensitive one click lean with stock muffler =9,100
One click lean with TH==9,240
The TH has that same deep throb as the glow engines.
That's it, it's a keeper.
Saito FG 11
Prop===Xoar 13x6
Same here. Put it on my LT-40 after having it in my T-Clips. Problem i had was it is not strong enough to recover from a stall if it happens too low, so swapped it out with a .65(I think) glow. It is perfect for the LT though. Haven't flown the T-clips yet since I repaired it to see how well the new motor can pull it out of danger. I had stalled it with too high AOA like I normally do with my SSE, and wound up dropping a wing, and full throttle did little to get enough speed to pull out of it in time. I always felt it was a little under powered for the Clips.
![](https://cimg8.ibsrv.net/gimg/www.rcuniverse.com-vbulletin/400x266/_1_740e9b18f1437c7e5300dc3f9beb4dc4ac26c7e3.jpg)
ps dave the maico breako here came about because the parts you commonly use most like rings and pistons plus gaskets every couple of meetings were more expensive than say a honda cr500 which did'nt look as pretty as a maico 490 but more than equalled it in performance
![](https://cimg0.ibsrv.net/gimg/www.rcuniverse.com-vbulletin/750x499/moto_guzzi_8c_3_750x499_018593191544c84841d220a4b485c8bd74d075c5.jpg)
1955 Guzzi 500cc V-8 170 MPH plus.
![](https://cimg7.ibsrv.net/gimg/www.rcuniverse.com-vbulletin/800x556/guzzi0_b8ae0ce10ea5b97c5242709e058c2949fd3ac1d7.jpg)
1972 Guzzi 850 Eldorado
![](https://cimg9.ibsrv.net/gimg/www.rcuniverse.com-vbulletin/800x600/guzzi_232fe6efe8e6553d740bae8c0aa76cdc802d8b16.jpg)
2001 Guzzi V-11 Sport. Salvaged from the Maryland flood that year.
![](https://cimg3.ibsrv.net/gimg/www.rcuniverse.com-vbulletin/2000x1504/vent_120895c77426a67536fb7bba898b525e3e0fb675.jpeg)
Obligatory Saito content
The Tonti framed Guzzis are amazing bikes that handle and brake very well in the twisties. For a basic pushrod engine they can put out darn good power too. The early Dukes with the bevel geared, shaft driven OHC were a bit labor intensive. Valve adjustment with the little valve tip caps and all. The Guzzis are so easy to work on a mechanic is not needed.The Nikasil cylinders, the nitrided crank are near bullet proof. Not like they often need it but you can replace a pair of Guzzi cylinders on that LeMans in about 1 hour, with just basic tools. Racing isn't everything however. When I open the garage door in mid-January and suit up for the ride to work, I know the old Guzzi will snap to life and is always up to the job. Just the same when I am headed on a day trip from Detroit to St Louis. The Guzzi will get you there even if it is 30 years old and nearly 200,000 on the clock. I like all motorcycles (except most Harleys) If I ever have to live with just one motorcycle, it will always be a Guzzi.
![](https://cimg3.ibsrv.net/gimg/www.rcuniverse.com-vbulletin/420x233/1951_indian_brave_bonhams_7148ea967085c1625a18178637fe9c45c3d11855.jpg)
In my 66 years of riding I've only owned two non Harley's. The MAICO 125 mentioned above and my very first bike when I was 14, a 1952 Indian Brave, (248 cc), flat head/side valve, made by Brockhouse in the UK. It had a fried alternator/generator or whatever they called it. It would run total loss for weeks on a common 6v car battery. For years I thought it was a re-badged Beezer, but not.
Here is a pic of the 63 year old Triumph that I was out riding yesterday. Bought this one in the 1970s for $200 . It was in about 12 carboard boxes at the time.![](https://cimg8.ibsrv.net/gimg/www.rcuniverse.com-vbulletin/1500x977/trw945_bf3475e95686915b88b176134e6c93384e179e73.jpg)
1955 Triumph TRW
Indian Wally's son had a pile of the Scouts and Warriors. I don't recall the side valve versions. Don't think he had any of those. His were US built singles and twins, all were OHV and seldom ran well.The Indian built small bikes had individual valve covers and looked a lot like Saito engines. The later Brockhouse bikes were actually Royal Enfields. Never owned a Harley but I have worked on plenty of them. (Actually, I don't HATE Harleys, I just like poke a bit at Hobbsy about them)
1955 Triumph TRW
![](https://cimg8.ibsrv.net/gimg/www.rcuniverse.com-vbulletin/600x463/classicchrome_slant_front_maroon_600x463_8c556e5d758cff8945dd71fc710cc209d274bc5a.png)
That Triumph is a beautiful green, if I could have a second bike it would be this. I like that big tall Saito 499 that is fuel injected.
Jesse most of the saito engine and airframe to fly them people here have a grandson that,given some spanners and a sunday afternoon can put your 55 trumpy back in to those cardboard boxes.Nicely done resto,the big money paid at auction now is for bikes with the original patina specially jack ehrets as raced vincent black lightning he signed.Went for a million US over your way and came back where it belongs to an aussie buyer.
Dave...never restrict yourself to just riding harleys it cramps your experience and why torture yourself when life can be so short pard?
The only Harley fault I've noticed is that you arrive at your destination too soon and have to get off. I was hoping to go for a 100 mile ride, (well 90) to Jamestown, but that's 180 over there and back. I've been known to ride that far for a hamburgler. as my daughter called them when she was little. It's getting geared up for a cold rain here.
. I have always preferred preservation over restoration and rarely subject a machine to that stuff.
Aside from a connecting rod bearing that was damaged by the previous owner when he took the bike apart;; Along with a few gaskets, tiresdtubes , hoses , battery etc ,That Triumph is ORIGINAL. That IS the "patina".
![Smile](https://www.rcuniverse.com/forum/images/smilies/smile.gif)
Sorry about the [post above. I'm not used to the glitches on this site yet.
Dave, No need to stop riding . A 1000 mile day is a good start. BTW, That 90 mile ride in the cold rain sounds very nice. Let us know how it went when you get back.
Last edited by Jesse Open; 04-24-2018 at 06:30 AM. Reason: Removwed tounque in cheek comments lest they be taken the wrong way :)
Jesse apparently dave's not back yet...that MUST be a comfortable harley i hear they don't put a lot of strain on your arms either.That inverted saito engine set up is very well thought out and executed.
ps i think rollie free set some land speed records on a vincent.
![](https://cimg3.ibsrv.net/gimg/www.rcuniverse.com-vbulletin/640x515/edgar_vincent_4_1eff471df388472994ed73d7da5aeb901ffd0eea.jpg)
Maybe Dave is waiting at the side of the road somewhere. If we don't hear from him soon, I'm hopping on the Triumph and initiating a search and rescue mission. We need Dave!
Yep, the prop is a chrome plated APC 13-8
https://en.wikipedia.org/wiki/Rollie_Free
