Old 05-03-2018, 06:22 AM
  #36376
Jesse Open's Avatar
The rebuilt 120 just before installation in the 1/5 scale Pica Waco. The other pic is a comparison of the carb bores on the three Saito big blocks. (150 in the middle sporting a homebrew , longer than stock velocity stack as seen in on the 150 with the brass muffler.
Old 05-03-2018, 08:35 AM
  #36377
so i sprayed the chief on there instead
yes yes that is one classy paint job there
Jim
Old 05-03-2018, 08:40 AM
  #36378
It sounds like a Cherry Bomb too. Good deep rumble. Nice thing is the very light weight. It does not stress the threads like the Saito trash can and iron pipe muffler system did. He has used it for about 4 years now and never came loose or gave any problems that I am aware of. Intalled wit SWAK and left it alone.
my "long gone" Magnum 180 muffler had no baffles at all, yet it's tip was a bit smaller than the header, I drilled it out as others on RCU did, it still was rather quiet and produced noticeably more RPM than stock
Jim
Old 05-03-2018, 09:20 AM
  #36379
Hobbsy's Avatar
Idle: stock exhaust
Max rpm: stock exhaust
Max rpm: with Turbo Header
I just ran the new FA .40a for 70 minutes doing my usual break in procedure.
Saito FA .40a new and un run
Fuel==Wildcat 10% with 18% full synthetic
Plug===Stock?
Prop===Graupner Sonic pro 11 x 6
Max rpm stock exhaust==10,530
Max rpm with TurboHeader=10,800
Picture #4== no leaks any where.
I don't care much for that Hobbico tach., it reads all over the place and finally settles down the number I photograph.
Old 05-03-2018, 10:10 AM
  #36380
Jesse Open's Avatar
Good numbers for a .40 ! Great looking setup with that spiffy muffler and elbow combination. What plane is it going on?
I have one of the old heavy MidStar kits about 90% done. Yes sir, ain't that a spiffy elbow, I didn't know if the FA 40a would respond well to the TurboHeader, but that 270 rpm increase is typical.
Old 05-03-2018, 11:37 AM
  #36381
Dave, I like this SIG Mid Star 40, it would due nicely with a Saito on it, but mine would have to have an open cockpit
SIG Mid-Star 40 Kit SIGPlanes.com
https://www.google.com/search?hl=en&tbm=isch&source=hp&biw=1676&bih=838&e i=rWfrWvrUOdLV5gK685H4Dw&q=sig+mid+star+40&oq=sig+ mid+star+40&gs_l=img.12..35i39k1j0i24k1l2.4135.139 53.0.16125.16.16.0.0.0.0.80.1074.15.15.0....0...1a c.1.64.img..1.15.1070.0..0j0i8i30k1j0i10i24k1.0.Av 99Kap_M5Y
http://www.rccanada.ca/rccforum/attachment.php?attachmentid=80572&d=1277870219
Old 05-03-2018, 11:46 AM
  #36382
the site will not let me post a photo unless I copy it to my computer first, is that the norm ??
Old 05-03-2018, 01:28 PM
  #36383
Hobbsy's Avatar
Jim, put your photos in a file that you name, for example, My Photos,etc. The Go Advanced button will give you the option to Search Your Device or a URL. Click on the picture, it will load to here and then let you UPLOAD to the post you're making.
Old 05-03-2018, 06:30 PM
  #36384
yes I understand all that, but I used-to be able to just right click on a photo (in a site) and copy it's URL, then past the URL in Advanced, then click Upload and the photo would be in my post,, but not any more, the URL wont copy now,,, for an example, to the right of this page I am on now there is a photo of a young man holding a skate board, if I right click on that photo a little white window pops up, I can select> "Copy Image URL", some times it has> "Copy Image Address",,, any hoo, I now have to copy the photo to my computer first, then install in my post (Advance) << all that takes twice as long
Jim
Old 05-04-2018, 02:26 AM
  #36385
Jesse Open's Avatar
Being new here, I am still struggling with some of the quirks. All too often I have typed out a (Too)lengthy response, bumped the wrong button and watched it disappear! (Kharma???)
Thanks for bringing up the Mid-Star 40. I have a brand new FA-40 Saito that I was considering dumping. Now it will be getting a new home in a Mid-Star 40. Great suggestion. That plane builds very quickly too.
Old 05-04-2018, 02:46 AM
  #36386
Hobbsy's Avatar
Well, I've never used the (Copy URL) method, I always use the (Save As) option, so I don't how to do it your way. Sig has their pictures protected some way so unless you can find a Sig picture somewhere else you can't get them.
Old 05-04-2018, 02:54 AM
  #36387
Rudolph Hart's Avatar
Jesse it's called alz for short and sometimes old age second you know, you get this great idea and start to write it down then a snooze overtakes you (nanny nap over here) and the site times you out.Some of my work painting is on a facebook page at perth hydrographics.
Old 05-04-2018, 05:03 AM
  #36388
FlyerInOKC's Avatar
Sounds to me more like the computer version of the old R/C pilots affliction "Dumb Thumbs". Did I mention I was a poster child for this affliction?
Old 05-04-2018, 06:23 AM
  #36389
If the software finds something in the url that is incorrect it wont paste. Happens quite often to me. Example would be google images. If there is an image that is linked to another site and the link has embedded information and not the actual image, it wont paste. Usually it happens for GIF images, or those that use Java or some other language and the image is embedded in the code. It can also happen for protected images that the site they belong to has them locked to prevent them from being copied.
Old 05-04-2018, 07:14 AM
  #36390
Jesse Open's Avatar
You know, I've lost a lot of friends with that kind of talk...
Even more without it....
I think....
Oh look, a butterfly..
Old 05-04-2018, 07:52 AM
  #36391
It's the loose nut above the keyboard syndrome.
Old 05-04-2018, 08:43 AM
  #36392
thank you thank you thank you my RCU Saito friend !!, it's a wonderful thing to understand LOL
it just goes to show that if it's not 3/8ths of something, it just may be 5/16ths of something else
Jim Bob
Old 05-04-2018, 08:46 AM
  #36393
now lets not talk about that. I am allways having to click that edit button, just like I did in this reply to add the 2nd quote
Jim
Old 05-04-2018, 08:55 AM
  #36394
FlyerInOKC's Avatar
I think....
It has really had a bad affect on the airplanes in my hanger too!
Old 05-04-2018, 02:59 PM
  #36395
Hobbsy's Avatar
Alrighty then, since I ran the FA .40a with one of the new 11 x 6 Graupner Sonic Pro props I just had to try the 10 x 6 on a Saito .30: No pictures though.
Saito FA .30
Fuel====Wildcat 2/4 10% with 18% full syn
Prop====Graupner Sonic 10 x 6
Plug====OS-f
Exhaust=Stock muffler
Maxrpm=10,301
Best idle 2,160
Ambient temp 90 f.
Old 05-05-2018, 02:00 AM
  #36396
Let's see the photo okc your comments are hilarious at the bottom of every post and jesse can see the butterflies again so i guess we are all back in the late sixties at a concert by some group nobody has ever heard of (could have been dave doing a guitar solo in country and western) lying flat on your back with thousands of others just dreaming
Old 05-05-2018, 02:54 AM
  #36397
Hobbsy's Avatar
Naah, it would be Blue Grass, there ain't no country music any more, well, maybe there still is in your Country.
Old 05-05-2018, 06:23 AM
  #36398
Ain't that the truth! I turned on a country channel on Amazon Prime, and was lie *** is this crap? This isn't country? Found a Willy station, now That's Country!
Old 05-06-2018, 09:55 AM
  #36399
Jesse Open's Avatar
Throw in some Hank Williams, Hank Snow, Hank Thompson.....
And vintage Ray Price
Old 05-06-2018, 11:04 AM
  #36400
Charlie Pride, Charlie Daniels, Waylon Jennings, and Merle Hagard. Now thats Country!
