Official Tamiya TT-01 Thread
Old 09-15-2008, 06:09 AM
  #4576
Default RE: Official Tamiya TT-01 Thread
I'm new to r/c cars and thinking of getting a drift car. So, should i get the TT-01D drift spec or the TT-01E and modify it into a drift car? Which one is a better buy n a better choice? Please help
Old 09-15-2008, 09:45 AM
  #4577
bashingozzy's Avatar
Will the futaba S3050 digital servo fit the steering servo horn?
INCLUDES: One S3050 Digital servo with preinstalled .83" (21mm) round servo
horn
Four Rectangular Grommets
Four Brass Bushings
Four 2x11mm Mounting Screws
One Large Round Horn 1.4" (35mm) diameter
One Six Arm Horn 1.2" (32mm) long
One Four Arm Horn 1.5" (39mm) long
SPECS: Speed: .20 sec/60° @ 4.8V, .16 sec/60° @ 6V
Torque: 72 oz-in at 4.8V, 90 oz-in at 6V
Length: 1.57" (39.8mm)
Width: .79" (20mm)
Height: 1.50" (38.1mm)
Distance between center of mounting holes: .39" (9.9mm)
Weight: 1.7oz (49g)
Old 09-16-2008, 08:45 AM
  #4578
The Rigger's Avatar
ORIGINAL: samuelmczed69
When you talk about servo calibration do you mean trim?
Yep.
In terms of suspension upgrades etc. what parts would I have to buy in order to 'eliminate all of the slop and make it completely tuneable'? Alloy arms and shocks... anything else? Steering knuckles?
Not necessarily alloy... Turnbuckle tie rods and adjustable upper arm kit are the biggest add-ons, alloy rear knuckles with your desired toe-in built in are right after that, followed by the aluminum steering parts. Personally, I think the Tamiya plastic kits are as good or better than the alloy kits; the type of plastic Tamiya uses is a touch lighter than the alloy, and plastic has some "give" and rebound to it; when (not if, *when*) you collide with something hard and immovable, the plastic parts will flex a bit to dissipate the shock and recover their original shape. The alloy bits will be more likely to either transmit all of the energy to the chassis, or bend and stay bent. The guy I build with on this tour got all AL front suspension bits, and wound up shattering his chassis tub front lower arm socket when he clipped a lightpole. The only exception in my opinion might be the AL steering gear; you want the steering hardware to be as stiff as possible, to maintain accuracy...
Shocks are good, but not necessarily the first thing on my shopping list; you need to minimise the slop elsewhere in the suspension before working on damping and rebound. Anti-sway bars are okay, but you need to have the adjustable parts installed first; they don't work with the OEM suspension. And I've heard from others in this forum that they really don't accomplish all that much. I'll do some experimenting with a set one of these days, maybe, but I've got a lot more things to twiddle around with on my car first...
-Dave
Old 09-16-2008, 08:49 AM
  #4579
SIRCC's Avatar
you hit that one on the head dude
Old 09-16-2008, 07:09 PM
  #4580
The Rigger's Avatar
ORIGINAL: nabby11
You'll definitely spend less money getting the drift-spec car from the start, but IMO you might have more fun tweaking the E-spec car into a drifter. Depends on whether you enjoy tinkering or not.
-Dave
Old 09-16-2008, 08:34 PM
  #4581
Ok thanks for the opinion n i think i'm going to go ahead n buy the TT-01D cause i'm in a tight budget
Old 09-18-2008, 08:44 PM
  #4582
I’m looking for something I can take to a smooth parking lot or tennis court and drive fast and corner. I’m more of a RTR guy but would be open to building if it wasn’t a major project. I was looking at the TT01’s out on tower and it is so confusing with prices all over the place. Is a TT-01 a TT-01 or are there differences.? I there any model that comes with all the upgrades?
I typically replace the RX as I have a DX3. I also have the motor and speed controller out of my slash that I just upgraded to VXL.
Any suggestions welcomed?
Old 09-18-2008, 11:58 PM
  #4583
I did some searching tonight and I'm thinking of getting the TT-01R. What do you think about putting the VXL motor and esc in it as I have one lying around?
Old 09-19-2008, 12:00 AM
  #4584
xxSLiMxx's Avatar
ORIGINAL: td1223
SIRCC has one in his TT01. Read a few pages back (3-4pages) I was thinking of putting one in mine but i wanna see one go first! I think im going to put a cheep one in for now EzRun 5.5T from ebay...$60.00 cant go wrong.
Old 09-19-2008, 09:27 PM
  #4585
SIRCC's Avatar
HERE'S ONE
ID:	1036488   Click image for larger version
Old 09-20-2008, 05:12 AM
  #4586
ORIGINAL: bashingozzy
horn
Four Brass Bushings
Width: .79" (20mm)
Weight: 1.7oz (49g)
Anyone?
Old 09-20-2008, 10:44 AM
  #4587
xxSLiMxx's Avatar
horn
Four Brass Bushings
Width: .79" (20mm)
Weight: 1.7oz (49g)
Anyone?
Yes.
Old 09-22-2008, 07:28 AM
  #4588
hey,
curious if anyone has tried running a Speed Passion Endless Brushless Motor Competition 2.5R in their TT-01, i have become quite bored of the slowness of my car and im in the need for speed.
Basically im planning on running:
Sentilon100A ESC
Polyquest 5100mAh 2S 25C RXP Racing Lipo Pack
Im only experimenting but any tips you have such as what a good gearing would be, i gather a high reduction set up but not sure on what is right for this.
cheers
Old 09-22-2008, 07:35 AM
  #4589
SIRCC's Avatar
before you upgrade your gears try the stock setting for the car. if you feel that it could go faster upgrade point by point, may i suggest that if you jump to high you might miss the adequate gear setting, drift or touring.
Old 09-22-2008, 07:48 AM
  #4590
yeh i was more thinking of trying not to put to much stress on the motor and such..
it would probably just be for touring i doubt ill beable to handle drifting with this motor
Also i was curious of how well the diff in the TT-01s handle the high powered motors after a few runs.
Old 09-22-2008, 10:30 AM
  #4591
xxSLiMxx's Avatar
ORIGINAL: tuxedo
look up burshless tt01 on youtube and u will see how well they dont handle.
Old 09-22-2008, 01:48 PM
  #4592
TIGER76's Avatar
They will handle BL as long as your not mashing the throttle hard lol
Ive ran a mm5700 on 8cells and a vxl on 9 cells in mine with no problems but be warned over 50mph+ the handling goes out the window LMAO best to get the upgraded chassis for fast speeds
Another thing is the steering at 35+mph its sloppy at 50+ its unpredictable to say the least
Old 09-30-2008, 05:34 PM
  #4593
xxSLiMxx's Avatar
Painted up a new body today and i love the colour! I love how it came out so i though i would share! Enjoy, let me know what you think!
The blue lambo is the one with all the red parts and is wating for a brushless/lipo set up. The green lambo with sliver parts has a 15x2 Peakracing/Tazer ESC running on 4200 NiMH Batterys.
Old 09-30-2008, 08:38 PM
  #4594
hey im totally new to rc and am hoping to buy the tt01 soon, could you pls tell me what i would need to buy to get it running, number of servos, esc..........
Old 09-30-2008, 08:42 PM
  #4595
xxSLiMxx's Avatar
ORIGINAL: Jem93
Try reading thru some of the pages....EVERYTHING is explaned, whats needed, best upgrages, ect ect ect.
Old 09-30-2008, 08:50 PM
  #4596
okay.....but how many servos would you need?
Old 09-30-2008, 08:52 PM
  #4597
xxSLiMxx's Avatar
ORIGINAL: Jem93
One servo .....just a question i dont mean to come off like im beening mean or anything....but did you do any research at all on the TT-01?
Old 10-01-2008, 04:55 AM
  #4598
you dont know how much research ive done, its crazy but its hard to find these things, what radio and reciver would you recommend, im jus lookin for a basic set........and would you guys know where to get a dodge charger body from?.........thnx
Old 10-01-2008, 05:00 AM
  #4599
also, what type of esc would i need?
Old 10-01-2008, 08:37 AM
  #4600
xxSLiMxx's Avatar
If your just looking for a basic radio any radio will do, theres nothing special about basic radios. If you want something with all the goodies look into Spektrum or something along thos lines!
Proline makes a Charger body if your looking for the newer style: http://www.prolineracing.com/p-328-d...ger-srt-8.aspx
I beleve HPI makes and older style one, but im not 100% on that.
As for an ESC it depends on what you plan to do, if you wanna go REALLY fast, then any good brusless set up will do, novak/sidewinder/ect ect Or you can do something smiple like a Tazer 12T esc (im useing one of these now) and get your self a good 12-19T motor.
ESC: http://www.dynamiterc.com/Products/D...ProdID=DYN4927
Im sure you are going to be asking this sooner or later "whats the must have items" Well here it is!
1) oil filled shocks
2) Alum drive shaft
3) good tires
4) Alum steering setup
5) adjustble a-arms
6) carbon fiber uper chassis
7) full race bearings
8) good driving skills
Tho are the "must haves" Keep in mind its a TT-01, this car was ment to be an awsome raceing machine, but with a little bit of changes and some pratice with it, its not a bad little car.
Slim
