Old 05-27-2020, 03:12 AM
  #46376
Originally Posted by Glowgeek
I recently picked up a "low time" 180. A little teflon disc fell out from somewhere when I pushed out the cam pin. Where did it come from, in the front of the cam pin? Is it just cosmetic?
Anyone?
Old 05-27-2020, 03:20 AM
  #46377
Hobbsy's Avatar
There should be one in front and one behind, they are metal now.
Here you go: https://www.horizonhobby.com/steel-st-washer%3Am-0-yzbbccffhh-az-at-sai120s37
PS, They are tricky to install.
Old 05-27-2020, 03:34 AM
  #46378
Dave, not those cam shim washers. The little teflon disc I'm referring to is solid with no hole in it. It's the same OD as the cam pin and looks like a teflon piston pin retainer except much smaller, of course. It must be cosmetic to make the front of the cam box look flush?
It is not a listed part for the fa180a.
Old 05-27-2020, 05:08 AM
  #46379
FlyerInOKC's Avatar
Pete has been checking out the Saito numbers, here is what he wrote.
"Good to see lonnie post those saito fa115 and (fa125 yuk) figures, he's right on the money and it will be interesting to see dave's figures, he tunes them well but always swear black and blue that he hates apc props so it's unlikely we will get a fair comparison, unless lonnie ships the apc props to dave and the skinflint pays the frieght. That might not be a good idea on second thoughts because dave is pretty long in the tooth nowadays sittin on the front porch rocking chair snoring the next door neighbours awake.
ps could you ask acdc not to write long post's please, my right index fingertip is getting RSI from all the downward scrolling
Cheers mate"
Old 05-27-2020, 05:49 AM
  #46380
Old 05-27-2020, 06:12 AM
  #46381
Hobbsy's Avatar
Pete can relax I just bought an APC 15 x 6, all comparisons are fair as long as you explain/list the criteria.
Old 05-27-2020, 06:17 AM
  #46382
I never know what prop is best to use and just wing it. Hmm that one looks good on the plane, and use it kind of winging it. I would like to put the right prop on the 72 that is on the SSE so that I can get more slow speed performance. I don't want it to go fast, but want to be able to pull out quickly at HOA maneuvers like a Harrier. I have a 13 x 6 or 8 APC on it now.
Old 05-27-2020, 06:29 AM
  #46383
Hobbsy's Avatar
I prop em for 9,500 and that's close enough for the gal I go with.
Old 05-27-2020, 06:36 AM
  #46384
FlyerInOKC's Avatar
My airplanes aren't built for speed so I stick with wood. It is easier on the digits when you screw up.
Old 05-27-2020, 02:18 PM
  #46385
APC 14x4W or Xoar 14x4 is the ticket. Should rev to 9800 richened for flight. Crisper throttle response with the lighter weight Xoar. And don't worry about the rpms, a 4 pitch prop won't unload in the air at all. Top speed will be approx 30 mph.
I had a 62 on my SSE and it was lacking a bit. Planned on upgrading to a 72, bought the 72 and rekitted the SSE before I had a chance to mount the engine. I have the new SSE about half built.
Old 05-27-2020, 04:38 PM
  #46386
14 wont work on the SSE, the 13 barely clears as it is. Tail level and I have about 2 fingers of room between tip and table, and broke my Xoar when the tail lifted on the run up bench, never got a chance to see how it did with a lighter prop.
Old 05-27-2020, 05:03 PM
  #46387
Taller Carbon Fiber LG will fix that problem right quick.
Search for this: LGZX300#26CC-CF
Old 05-27-2020, 06:48 PM
  #46388
It would muck up the performance though sticking the wheel weight out further. I like how it flies as it is.
Old 05-27-2020, 07:23 PM
  #46389
Lonnie, weight wise, it looks that comparing the 115 to the 125 is much like comparing the 100 to the 115.
I checked the weights of all 3 engines (less mufflers) and here is what I found>
from my Saito 100 manual and Horizon's site,
the 115 weighs 35 grams more than the 100,
the 125 weighs 35 grams more than the 115.
it's interesting how that came out
Jim
Old 05-28-2020, 02:21 AM
  #46390
Drop her pants and she'll fly better.
The SSE was never designed for 3D per se but will hover and harrier if built light enough. With CF LG, no wheel pants and lightweight foam wheels mine did ok. I think the fa72 with a 14x4 prop will fly it with authority.
Old 05-28-2020, 02:33 AM
  #46391
Hobbsy's Avatar
My 1.25 with the CHI mounted, the 1.25 muffler is nearly twice as large as the other two mufflers.
Old 05-28-2020, 04:02 AM
  #46392
Dave?
Old 05-28-2020, 06:37 AM
  #46393
Yeah, that 125 muffler is a monster, you would think it would be quieter being so big, but its the loudest one I have. I had to add counter weight for it too, laterally it would roll towards the muffler side.
Wow 1 pound 9 ounces, the Magnum 91 is 1 pound 6 ounces.
Old 05-28-2020, 06:53 AM
  #46394
FlyerInOKC's Avatar
Over 1 1/2 lbs. is a lot of muffler, I wonder if there is a light weight substitute or rotating the engine 90 degrees to put the muffler on the bottom would work a little better?
Old 05-28-2020, 07:11 AM
  #46395
Hobbsy's Avatar
Dave?
If it were mine I would think it's an extra part that got in there by accident, as you said, there's no place for it in the 180, nor in any Saito unless it's the wrist pin pad for a small Saito.
Is the cam support shaft the correct one? Thanks
Old 05-28-2020, 07:13 AM
  #46396
Hobbsy's Avatar
The muffler does not weigh 1.5 pounds, it weighs about 3 oz, the Turbo Header weighs about half that.
Old 05-28-2020, 02:28 PM
  #46397
I'm not sure, that's why I asked about the little teflon pad on the end of the cam pin.
So the cam pin should be long enough to be flush with the front and rear of the cam housing on a 180a? Mine is not long enough to be flush at both ends. The groove near the front of the cam pin lines up with the set screw when the pin is flush with the rear of the housing. At that point the front of the pin is recessed approx .060", thats where the little tefon pad was used.
Old 05-28-2020, 03:39 PM
  #46398
Oh man, I thought for sure I ordered a 100 count bag 1/8" pin hinges. It was a 3/32 bonus bag of 50 pins with the hinge drill guide. Bugger all.
Old 05-28-2020, 04:20 PM
  #46399
FlyerInOKC's Avatar
Opps! What are you going to do reorder?
Old 05-28-2020, 04:24 PM
  #46400
Hey Peer Group
Opening a Saito FA 90 T for repair. Any hacks to know on twins?
