#4927
![Default](https://www.rcuniverse.com/forum/images/icons/icon1.gif)
Saito 150 - won't start after replacing spray bar and high speed needle.
Yes, rockers and manifolds are in place and working properly. It rather looks the engine gets no fuel. But priming shows fuel coming off the muffler. Turns well with the e-starter but no
fire. Replaced the plug, all F-type and burning. What is to do?
#4928
Did you check the charge in your ignitor (or is it -er?)?
ORIGINAL: Luxuswaffe
#4932
Make sure the igniter is fully charged with electric power, so that your glow plug is getting power, so that it can get hot enough to ignite the fuel/air mixture.
#4933
W8ye thanks but I already ordered it back in sept and they say it should be sometime in January or february any other sites where I can order the carb housing.
#4934
Not unless there would be a Hobby shop that had one.
IMHO they have not been available yet.
Horizon hold the reins on Saito parts and most dealers just order as needed from Horizon
If the spray bar is broken from the carb body, it uses the "91" spray bar.....
http://www.horizonhobby.com/Products...dID=SAI91S122B
#4936
Have had same issue with spray bar for the 150. Ordered one directly with Horizon and the wrong part arrived 2 weeks later. Sent it right back to Horizon and got the right spray bar after another week or so. Parallel, I ordered a second spraybar with my LHS and they cannot deliver until Jan/Feb 2007(!).
Let's move away from SAITO! I am spending too much money into the hobby to only wait for some silly brass parts.
#4939
Hello gents, Like to join. Have Saito 100, 72, 72, 56, and an OS Klunker 70. can't win em all... used OS.
Saito 72 on Sig Sr Kadet. Perfect match. 12x6 APC Seems to give right power and slow speed operations, but worried about overrevving. Can you throw out some good prop ideas and max rpms for longevity. Purrs like a kitty at idle 2000. Want the instant go around power for the trainer.
Additionally, the other .72 is about to go on my old hang9 Advance 40 that is tricked out a bit. My OS.46 just doesn't give me the pull out from the dance. Looking for a prop for it. I just bought a 14x4w for the OS and will eventually try it on .72. thoughts?
want HARD pull, dont care about top speed on any of my planes. What increase over an FX.46 can I expect?
The 13x6 MA K pulls hard on both engines, but on the Advance, I might have some ground clearance problems. want APC props.
forgive rambling...
forgive rambling...
#4940
ORIGINAL: Hobbsy
when I pulled the spinner out of the box I gave it a toss toward my scrap wood box thinking it was plastic and a no no for the Saito.
![Big Grin](https://www.rcuniverse.com/forum/images/smilies/biggrin.gif)
JettPilot
#4942
My Feedback: (32)
NY
I thought I could use the plastic spinner that came with my groovy. It has an aluminum back plate and looked fine to me. But, after a about a dozen flights it broke internally where the bolts screw into the back plate. I immediately replaced it with a Tru-Turn aluminum one. DO NOT TAKE A CHANCE WITH PLASTIC.
#4943
That appears to be a ZAMA carb with an insolator bolted to an adapter, I can't see if the carb is attached to the backplate, the stock glow carb isn't.
Jett, I have used Graupner spinners on my 1.50 and a couple of others with no issues, their backplate is something that is really tough.
#4945
It appears that they only have three blade Graupner spinners now, bottom of page.
http://www.hobby-lobby.com/spinners.htm
#4946
I have a Saito 72 for a plane I'm still building. I have no idea how it runs yet, but it looks really cool. I open the box sometimes and show it to people. One day I will fly it, and it will be good.
#4948
SAITO 150 won't fire up:
Just figured what I did wrong: When I replaced the spray bar, I installed it the opposite way around, so no fuel could pass along the high speed needle; in every adjustment it was closed and no fuel got through the carb. Now the engine is purring like a big cat again. The Saito-manual is very poor on it's explosion drawing.
#4949
Just a note on the majority of the rc model manufacurers, since most printed matters are sometimes not readable, they do provide an online version which is in PDF, this in turn help modelrs to use the functions of PDF by utilising the zooming function on the pdf reader.
Just go to saitoengines.com then you will be linked to horizon hobby and from there you can select the right engines then click on support and select the manual link.
Hope that helps.
I believe towerhobbies does the same and QQ somenzini has a coloured version of his manaul.
Hope that helps.
![Smile](https://www.rcuniverse.com/forum/images/smilies/smile.gif)
#4950
RVM, regarding that Dawn cleaner, please be careful how you use it.
I used it and it gets of the light to medium gunk. As a test, I first cleaned an old Saito muffler - that got it about 80% clean. Then, I squirted it down with the stuff and put it in a plastic ziplock bag for 24 hours (so that the Dawn wouldn't dry out).
24 hours later, there was not much more cleaning done, but the metal on the aluminum muffler felt 'eched' somewhat. You might want to try this stuff out on a muffler of your own first, to see how it works for you, before trying it on something like any engine internals.
Just a thought,
Bob
Just a thought,
Bob
