Lol
finely got in the shop. Friend shipped me an FG 11 with a broken off high speed Metal valve didn’t have rights spray bar so I improvised and put in a 91 spray bar in it runs OK on gas but the high-speed needle is touchy however switch to glow which is what the spray bar was meant for holy Cow runs great. Now I know the pros and cons of running glow Through a gas carburetor but just an FYI if you’re desperate to fly your plane and you can’t find a spray bar, a 91 spray bar will work and switch to glow until you get new spray bar
My Feedback: (8)
Got 10 cans (5 gallons ea) yesterday. Great folks Looks like Pedro is on to some oil at a good price too.
Gary, your really hooked. you got toomuch fuel again. like when you got all that 30%. well I guess you could burn some in your Colman stove if you go camping
Jim
Jim
My Feedback: (27)
The Go-Kart synthetic oil (Thor Oil) ran great in my FA-72. I've used about a half gallon of fuel so far and it works great. I was flying it in an OS 40 Surpass today.
I dont burn this stuff alone! The flilying season here is ramping up. There are quite a few fellow club members mixing their own. I help by finding sources.
I used to run Coleman stove fuel in my gassers back in the day. Doesn't stink as bad as gaspoline. Also a LOT less carbon.
"Too much" ?? LOL
We also had military lanterns that would burn either.
The pump gasoline burned in them was less efficient and stunk. And contained lead lol. Maybe that has something to do my piss poor memory.
Lol
Cap, here are my numbers for my FG 11/66, turning a Graupner 13 x 7. The fuel is 90 octane ethanol free, (Farmer Gas) and 20% of the oil pictured.
Full Blatt.
No smoke.
Idle
Years ago I worked with a machinist who had moved back from San Diego. He had worked in a shipyard on a lathe with a cab on the cutting tool the operator rode in. He was machining propeller shafts for big ships. I wish he had a video I could have watched!
Even though the timing is set at 40° btdc, it is very smooth with no sign of kicking back and no rattle.
https://www.horizonhobby.com/on/dema...G11-Manual.pdf
On Page 3 here it shows the neutral timing setting, that position on my FG 11 is 40 BTDC.
My Feedback: (149)
Hello RoKit, Not sure of a designated one for the FA170R3, but many that frequent this one have R3's (and more LOL) with lots of expertise. Welcome aboard ! I have a FA170R3,(bought used) but it has a CH Ignition conversion to include a Saito gas carb.
Here is a link to it running - Mike I have done the engine, here is a link of the engine running.
You will have to tune it bit more at your end.
You may not be able to go full throttle may go only 3/4 , use the trim to rich top rpm and leave it like that.
https://www.dropbox.com/s/qh7z599g9u...00231.mp4?dl=0
T-man49 in Al
Saito 723
T-man49 in Al
Saito 723
