 Skymaster 1:6 A10 Build >
Old 09-02-2012, 07:36 AM
  #526
Gonzalo38's Avatar
Default RE: Skymaster 1:6 A10 Build
Congratulations Gonzalo. Beautiful plane.
Yesterday, two of them were flying at our club. Great show.
Mine should be arriving in a couple of weeks.
Old 09-02-2012, 08:49 AM
  #527
dubd's Avatar
Congrats Gonzolo! Now, will you build my A-10 for me???
Did the A-10 feel overpowered with the Merlins?
Old 09-03-2012, 06:28 AM
  #528
Congratulations Gonzalo. I thought that the maiden was Never going to happen !!! LOL.
Of course I wasn't there, but the power management issue you describe sounds to me more like an improper throttle curve. Those heavy metals fly much easier when the thrust is linear with respect to the stick position.
If you haven't done it, I suggest that you make a throttle curve on your transmitter that outputs 67% when the stick is at 50%, and outputs 37% when the stick is at 25%. Also, activate the expo function on the transmitter throttle curve menu to soften it.
With a linear throttle setting (not with the curve I described) , you have way less than 50% power when the stick in on the middle. It may not bother with light loaded planes, buy may be annoying with heavy metals.
Anyway, I am sure that I will have the chance to fly your beauty at BITW and fine tune it for you......
Jack (dad)
Old 09-03-2012, 06:36 AM
  #529
ORIGINAL: dubd
OMG, I never thought I could read something about "overpowering" from you
I fly my Mibo with a pair of P160's (Titans actually) and is not overpowered. You use that thrust as "torque" to do verticals at slow speed (scale). Awesome !!
See you in a few weeks.
Jack (dad)
Old 09-03-2012, 07:22 AM
  #530
dubd's Avatar
ORIGINAL: Jack Diaz
ORIGINAL: dubd
OMG, I never thought I could read something about ''overpowering'' from you
I fly my Mibo with a pair of P160's (Titans actually) and is not overpowered. You use that thrust as ''torque'' to do verticals at slow speed (scale). Awesome !!
Jack (dad)
LOL you have me there! I must be getting conservative with age. I even opted to use a 140rx rather than a 180rx in my BVM F-100.
Old 09-03-2012, 08:54 AM
  #531
gonzalom's Avatar
Very good points Jack (Dad) and in fact some of the settings that you are recommending can be theoretically done on the ECU for the Merlin turbines.
My first flight was done with Normal: Full Expo as its the default of the turbine…and despite everyone was telling me that with 50% throttle I should be flying to a perfect cruising speed….. In my case I felt the airplane was a little bit too slow and felt heavy. On landing with full flaps was a total floater.
On the second flight I change the settings of the turbine to Half Expo and what a difference! At 65% throttle the airplane was on rails and the way I like to fly.
I also noticed my trims where exactly the same for all flaps positions and I didn't feel at all the tendancy of going up or down when applying power...... but I need to check that more on the next flights.
To illustrate more see below the graphs for the Merlin power distribution and throttle position.
Thanks for your feedback as always and looking forward to see you in October!
Gonzalo
Old 09-03-2012, 04:29 PM
  #532
Congratulations Gonzalo ! Nice job!
Old 09-03-2012, 05:09 PM
  #533
gonzalom's Avatar
Thank you Anton! I LOVE your ARFS they are coming better and better every year!
We just need you to make some Scale Helicopters ARFS too plus the VTOLs
Thank you for bringing some amazing ARFS and saving us 100 of hours in making one!
Best regards,
Gonzalo
Old 09-04-2012, 09:13 AM
  #534
nice pictures for A-10 full ordinance flight from Mark Hinton UK
ID:	1798365   Click image for larger version
ID:	1798366   Click image for larger version
ID:	1798367   Click image for larger version
ID:	1798368   Click image for larger version
ID:	1798369   Click image for larger version
Old 09-04-2012, 09:25 AM
  #535
fifou313's Avatar
Hello Anton
Very Impressive plane.
Can you sold the plane painted with an heavy weathering (like a very dusty plane)? Because I'm thinking about the A 10 for my new plane but your painting scheme is too shining for me (as a plane with a fresh paint).
I like very much the weathering of the plane of Marc hinton. Can you do the same for an order?
Thanks a lot.
best regards.
Fifou
Old 09-04-2012, 09:44 AM
  #536
dubd's Avatar
Awesome photos!
Anton, is Mark flying with P-140s now?
Old 09-04-2012, 04:23 PM
  #537
ORIGINAL: dubd
Awesome photos!
yes, now with P-140s
Old 09-04-2012, 04:31 PM
  #538
ORIGINAL: fifou313
Hello Anton
Thanks a lot.
best regards.
Fifou
Hi, Fifou
yes, we can do the little or heavy dusty weathering for A-10, when you place order pls ask John,
Best Regards
Anton
Old 09-04-2012, 04:35 PM
  #539
the Michel from Chile just maiden flight the A-10 for customer (little dusty weathering)
Old 09-04-2012, 07:34 PM
  #540
erbroens's Avatar
Anton, this two guys are Ariel and Pablo, friends from Michel.
btw we have in Curitiba another A10 to maiden soon. Hope to post some pics if everything goes as planned!
about the kit, I found it well built, nice finish,good markings and accurate scale line, many clever details,etc.
only thing that didn´t liked is the landing gear that doesn´t lock without air pressure.
Enrique
Old 09-04-2012, 11:48 PM
  #541
mick15's Avatar
I may well be converting my landing gear to hydraulic.
m
Old 09-05-2012, 09:36 AM
  #542
erbroens's Avatar
yep, this seems to be a solution.
Meanwhile we need to keep this plane in a stand while not flying. Not very practical for a plane this size and weight.
Old 09-05-2012, 11:04 AM
  #543
gonzalom's Avatar
It locks very well when the gear is in down position but it doesn't lock in the up position and that why Skymaster put an additional lock system on the mains that are install on the wings. The front gear is OK.
Gonzalo
Old 09-05-2012, 12:19 PM
  #544
dubd's Avatar
I will be using mechanical air valve with my A-10 for this exact reason. I had a SM f-16 with electronic valves and gear would collapse when sitting. My current SM f-16 uses a mechanical valve and can sit for months without a problem.
Old 09-05-2012, 11:00 PM
  #545
Likai's Avatar
The A-10 gear is designed with mechanical down-lock, so even there is zero air pressure it will be locked in down positon no problem.
Old 09-05-2012, 11:31 PM
  #546
dubd's Avatar
Li Kai, great to know, but why are people saying their gear won't lock?
Old 09-06-2012, 02:36 AM
  #547
Gonzalo38's Avatar
I never had problems with my gear in my A-10. I was using an electronic valve and never had to use a stand. I'm going for the same configuration with my new one.
The other two A-10's that are in the club also use an electronic valve with no issues.
Old 09-20-2012, 10:59 AM
  #548
mick15's Avatar
I have just started fitting out my new A10 and being one who has an inbuilt hate of visible linkages I have begun to hide all of mine.
ID:	1803280   Click image for larger version
ID:	1803281   Click image for larger version
ID:	1803282   Click image for larger version
ID:	1803283   Click image for larger version
Old 09-20-2012, 03:41 PM
  #549
Nice to see its arrived Mick. What engines do you plan to use? I suppose you will be under powering it as usual!
Look forward to seeing it at Classic Jets.
John
Old 09-20-2012, 11:04 PM
  #550
mick15's Avatar
I'm fitting the Evojet 160s out of the F15, in the hope it will have enough power.
m
