 Composite ARF Mig29 >
Composite ARF Mig29
Composite ARF Mig29
Old 10-27-2019, 11:59 PM
  #601
David Gladwin's Avatar
I agree with Craig, you need 10 bar , 150 psi. Mine does work well at that pressure. Make sure, though, you use the Festo high pressure tubing.
Make sure you retract the gear in straight flight before the speed builds up too much. Retraction during a turn has a G effect and will slow or prevent full retraction.
I will also add that I added a duplicate line on the pressure UP line as PH suggested volume is almost as important as pressure.
Yes Craig, 3000 psi would be great, but possibly slightly excessive !!!
D.
Old 10-28-2019, 03:26 AM
  #602
My Feedback: (44)
spaceman 01's Avatar
Will do thank you guys .
Old 10-29-2019, 01:57 AM
  #603
HI guys
I have got an early model without nose retract mod for 2x cylinder. Is it possible for someone to post pictures of nose retract. Want to make. conversion. Thanks
Alex
Old 10-29-2019, 04:28 AM
  #604
My Feedback: (23)
DelGatoGrande's Avatar
Originally Posted by spaceman 01
Finally we Jim Hiller and I flew the Mig 29 I was scared in the beginning but after I took over it seems like it flies like a trainer very stable aircraft I’m still having couple issues with the hydraulic system but I will try to fix it here’s a link.https://youtu.be/3mJ4oNwBRMQ
Μπράβο Nick!
Do you know whats the final weight ? What size engines you used?
BRG
George
Old 10-29-2019, 10:08 AM
  #605
My Feedback: (44)
hi George,
66.5 lbs. wet and I am running two 140 G kingtech , and I get good six minutes of flight.
How is your SU 35 ? I am going to paint mine this winter and put two P160s jetcats for power.
Old 10-31-2019, 08:26 AM
  #606
My Feedback: (23)
hi George,
Hey Nick,Maiden the su35 with twin p100.. perfect combination . video in my thread here http://www.rcuniverse.com/forum/rc-j...minator-5.html
But my love is for the su37 vector-thrust version . With scale nozzles not the ugly-look vector systems we have.
The last year i made a spot welder and having loads of test flights. Problem is cooling...after flat spins and cobras in low speeds, rear fuselage gets too hot
I dont care if ill burn it to the ground , i want the su37 version or nothing
The last 5 months i came up with a design of a flexible secondary cooling wall and the problem disappeared .Like a standard double wall pipes but with the last part moving.
Im waiting a higher grade stainless steel to arrive to make the final design and keep on testing ...
Once i have news ill post them in my thread..
Old 08-11-2020, 04:05 AM
  #607
Originally Posted by Craig B.
Hi David,
Thanks for your comments.
I had originally fitted jr 6301 servos then tried the futaba bls 177’s. The 177’s blew the jr’s away wrt centering and tightness in the gear train so I stuck with them. I am a long time jr user but the futaba servos seemed far superior. I have also heard that a 75 kg futaba is on its way. Would be a great option. My whole mig is now fitted out with Robbe futaba sbus setup and a mix of futaba 177’s on the tail and 8911’s in the wings, KST x10s on the rudders. Still finishing the final fitout but I am loving this thing! Major engineering exercise but if you live that sort of thing as I do then it is very rewarding as you know. Will check out your pics.
Hi
If you looking for some replacement BLS177SV servos's I have 12 brand new going cheap
Robin
Old 09-25-2020, 03:02 AM
  #608
Ro
Originally Posted by hemi
Levi
Did you get your Mig from Ro? I knew he sold it before he moved but wasn't sure who got it.
John
Hi Hemi,
I sold it to Mark F. from CompARF when I moved to Germany. Nice guy.
You have to shim the main mounts to get the correct scale verticle alignment and adjust the scissors so the doors close all the way!
You can see my images early in this thread.
I think twin P100-130 would be perfect these days. Saves weight and less wear on your Migs. Don't use heavy cockpit kits either may help.
Old 09-25-2020, 06:48 AM
  #609
My Feedback: (21)
Anybody have the specs for this Mig? Wingspan , flying weight etc.?
Old 09-27-2020, 02:32 AM
  #610
Levi Wags's Avatar
Hey Bob. You can google the specs or check CARF website. Mine is 23.5kg dry. It’s on the heavy side for this Mig but I have everything operational. 2 x P140RX’s. It’s a dream
Old 10-23-2020, 12:59 AM
  #611
I have just spent a couple of days going over my Mig ready to fly this weekend, sadly now cancelled. due CV restrictions.
A few points:
A few rivets holding the jetpipe to the bellmouth were coming loose. Unlikely to fail completely but ........ ! Take a look guys.
The wheelbrakes on this model have always been poor. Has anyone redesigned the wheel/brake assembly?
The Festo pilot valve, recommended to me by Shane Harding , have proven 100 % effective. Model stood on its legs for 6 months, no sagging !
Hydraulic system now running at 12 bar, working perfectly.
My jet has now been tarted up, burnt nozzles, cockpit and pilot, IR detector etc but still a way to go To begin to match Levi’s superb effort.
Had a close look at real SU 27 in Moscow recently, god its ugly compared with the 29 of which a number are on public display there, all looking very tired and neglected. The SU looks like a Mig which has been on a starvation diet.
Really looking forward to flying the jet. again, twin JetCat 140s, Futaba servos,, HPS a700 s installed ( thanks for the tip Craig) perfect !
Old 10-25-2020, 10:03 AM
  #612
My Feedback: (206)
TSHARK203's Avatar
Hello friends
Well my kit is up on its gear...yea. However the person I got her from had misplaced the nose cone. Does anyone out there have a damaged bird they are not going to fix or a extra nose cone laying about that you can part with.
Old 10-26-2020, 12:06 PM
  #613
My Feedback: (14)
Hey guys, how much interest would there be in a 1:5.5 Mig29 Arf? I am contemplating a super scale scratch build project...
Old 10-26-2020, 04:01 PM
  #614
My Feedback: (44)
Hello guys I have been flying mine and I can tell you that this is the best and easy jet that I have flown so far.
but if you wanna design And make a mold you should consider the SU 57 at a 1/6 scale .
just an idea and I know it will fly off the shelf.
Old 10-27-2020, 04:15 PM
  #615
My Feedback: (14)
Not an su57 fan😭
Old 10-27-2020, 04:30 PM
  #616
My Feedback: (206)
TSHARK203's Avatar
1:4 would be better. The 29 is not a very large plane. You cab get a lot more detail with a large aircraft. Much like skymaster has done with the 1:4 SU30.
Old 03-04-2024, 01:23 PM
  #617
Per Strommen's Avatar
Default Finally ready for maiden!
20 years have gone by since kit #29 came into my possession. Still a few details are missing, but I am now ready for the maiden flight.
Wish me luck!
Auburn02 (03-04-2024)
Old 03-04-2024, 02:08 PM
  #618
Good luck, Per
. Love that Ukrainian colour scheme !
This jet is a complete doddle to fly, just so docile even with an engine out !
Mine is waiting for spring, sat on its gear all winter with NO sagging!
Twin JetCat 140 s, Futaba HPS A 700 servos on Stab.
A delightful machine.
PS The hangars in the background are those at Abingdon. They are seen in some shots in “Masters of the Air “ where much of the film was shot.
The following 2 users liked this post by David Gladwin:
BadBill (03-05-2024), Per Strommen (03-05-2024)
Old 05-20-2024, 08:34 PM
  #619
Quick Question to anyone that can help
Does anyone know what the correct forward angle of the main legs is ?
Old 07-06-2024, 02:36 AM
  #620
It has flown!
As Mp files are not allowed, I am unable to show you the video, Sorry
Before and after picture.
Old 07-06-2024, 02:57 AM
  #621
https://www.youtube.com/playlist?list=PLX8fAD61Za_d242qavJ8NYkNDQlZiwWiJ
Old 07-07-2024, 12:31 AM
  #622
Congrats Per!
can’t seem to view the video… is it just me?
David Gladwin (07-07-2024)
Old 07-08-2024, 05:30 AM
  #623
Auburn02's Avatar
I was able to get to the videos with a little effort, try this link for a playlist of all 3:
Old 07-10-2024, 08:03 AM
  #624
I tried a link to my MIG-29 playlist, but that apparently only works best for me.
Try these instead:
Takeoff was straightforward.
I did a "slow flight" in an effort to establish a landing/final speed as I have installed a pitot tube and the telemetry for announcing the airspeed on my Powerbox Core radio.
The nose gear folded due to the increased drag in the grass. I have tried to fix the mechanical lock in the nose gear cylinder but not quite there yet. I have two hydraulic cylinders on the nose gear, so operating on a hard surface works well.
Looking forward to more flights with this model, it flew well.
Per
Old 07-22-2024, 05:15 AM
  #625
Some details:
