Official Tamiya TT-01 Thread
#676
WA
ORIGINAL: RiCeY
omg I just chucked in a 9 turn with 19t/61t and this thing HAMMERS !!!! Gets a bit hot but so have to have more cool down rest stops hahaha
Going to try 25t/55t tommorrow hahaha
#679
WA
ORIGINAL: bIGmiK
If the book says it can, it can. Just make sure you have the motor in the mount correctly and the right size gears.
#680
My Feedback: (58)
no adjustment needed RICEY,that particular TT-01 is set up for drifting. if you are adjusting the camber on a drift-chassis,you are just wearing out the inside of your drift tires......................
#681
the drift chassis is the same as the non drift chassis its the hop ups you get that make the difference as far as I know...
#682
My Feedback: (58)
no,i mean,that on a car you are drifting with,you want all the suspension sitting as square,and flat as possible. and,the aluminum arms,sit the suspension,and the tires dead square. now,if i was grip racing/running this car,i would probably,want to add some camber,and toe-in,but,i don't race,compete,or anything like that,so,i have TT-01's with the adjustable arms,and i still run them dead square.
#683
Well the tt-01d comes with adjustable suspension. As far as Im aware for drifting you would want neg camber on the front for more steering control and neutral or even pos camber (which I have) on the rear to make the end slippery and easier to drift...
Uneven tyre wear is a part of life when ur a drifter haha
#684
camber adj on a drift car works quite well, ive got -2 deg on the front and about -1 on the rear.
to tune a super stock:
change bushes for better ones
adjust timing
and its servecable, which means its great for the money you spend, i love it.
adjust timing
#685
Hi,
I'm fairly new to rc cars ad recently I bought the TT-01 Mercedes DTM 2004.I bought the following hop ups;
ALUMINIUM PROPELLER SHAFT
SPUR GEAR SET 55T/58T
METAL MOTOR MOUNT
ALUMINIUM STEERING SET
CVA MINI SHOCK CYLINDER UNIT
ALUMINIUM MOTOR HEAT SINK
FULL BAL BEARINGS
BALL DIFFERENTIAL SET
24T/25T PINION GEAR SET
TAMIYA SUPE MODIFIED 11T MOTOR
QUAKE NO LIMIT ESC
ANSMANN LION SMOKE TYRES WITH FOAM INSERTS
ANSMANN 3700MAH BATTERY
For stength, is there any other hop up I would need? Also would the 11t motor be too much for the chassis? Any advise would be much appreciated. Lastly which gear and pinion ratio would work with each other?
METAL MOTOR MOUNT
FULL BAL BEARINGS
QUAKE NO LIMIT ESC
#687
Im running a 9t with no dramas (yet haha)
I am carefull though no full throttle from standstill, I ease the power on
Just keep an eye on the esc and motor temps as they will get very hot
#689
Yeah its insane hahaha I bought one of those hot wheels radar guns to try and get a speed reading but they have no range so will try and get a real one and post the speed
#693
ok get a strip of flat road, mark with spray paint about 30 meters, make sure to hit top speed before crossing the first line and start timing on a stopwatch, when the car exits the other line 30 meters away, stop the watch, then work out how many meters per second it went and change to kph or mph.
easy and damn effective
#694
WA
ORIGINAL: jimmbeam72
Hi,
Are there any essential hop ups for the TT-01 with a no limit esc and an 11turn motor?
Hi,
#695
PA
I just got a Tamiya TT-01D a few months ago, and am looking for good upgrades. I'm also looking for a good Brushless motor system for about $250. Whats better LRP/Reedy or Novak?
#696
ORIGINAL: firebird76
#697
WA
ORIGINAL: RiCeY
The D already has a few hopups, get the ally prop shaft and motor mount and youre set
#699
WA
ORIGINAL: RiCeY
haha well I got a little careless and stripped my 61 gear :O
other than that its all good
