Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > RC Truggy
 Official Jammin X1CRT Thread >
RC Truggy Trucks and buggies together make a truggy. Discuss all things truggy right here.
Old 08-17-2008, 09:08 AM
  #926
Default RE: Official Jammin X1CRT Thread
I beleive they do fit, the X2's are stronger though
Old 08-17-2008, 01:58 PM
  #927
phattracker's Avatar
ORIGINAL: catkchun
ORIGINAL: phattracker
I'd try going up in your oil weights. Like 10-20-7 perhaps. The motor is strong and its spinning the wheels a little to strong I'm guessing. I mix my diff oil using the GE silicone calculator. http://www.gesilicones.com/gesilwiza...ng/fluid2.html What I run ends up being real close to 12.5-20-7. I can drive the heck out of it. lol
May I know what engine are run?
I ran the stocker. Force .28 Bump start only, 14t CB, 34mm lightened, vented Flywheel.
Old 08-19-2008, 09:23 AM
  #928
ORIGINAL: J24gordon
Thanks bro!
Old 08-23-2008, 03:03 PM
  #929
hi guys i have a little problem and would love some insight, i am new so please bear with me thanks i have a problem with my front tyres they keep knife edgeing or ballooning when under full throttle and even after changing out my diff silicone to 3000wt front 7000wt rear 30000wt center dont know what to do again oh i am still using the stock tyres thanks.
Old 08-23-2008, 05:05 PM
  #930
ORIGINAL: highredoctane
Sounds like your running the rtr version, if so buy some other good tires it'll help alot, the stock ones are junk
Old 08-23-2008, 11:09 PM
  #931
docphysics's Avatar
and try running 10K front, 30K center, 3K rear. The rear should not be heavier than the front.
Old 08-25-2008, 09:21 AM
  #932
yeah it's a rtr but i am running a lrp spec 3 z.28r with a jp2 pipe so it has alot of power. I will try changing up the oil let u guys know how it goes thanks much.
Old 08-28-2008, 10:31 AM
  #933
on my jammin i have cen matrix front shock (i buy it with this shock) so wich oil you recommand for this shock in front, and did u recommand to change it for OEM jammin shock?
Old 08-29-2008, 12:28 AM
  #934
getting my x1 next week soon to be x1.5 lol got some plans already brewing...and when money permits the project will begin
Old 09-20-2008, 08:58 PM
  #935
canadiannascar's Avatar
Hello, I'm new to the Jammin, I have a used Jammin X1-CRT Pro, & was wondering if a Picco 26 Max would fit ?
I know it's a mid block, & guessing it won't fit..
Also, any links to a clutch\flywheel\bell that works for the truck ?
Thanks...
Old 11-13-2008, 01:18 PM
  #936
I'm running a crt x1 truggy with the force .32 big block. Seems there's plenty low end torque, so, what's your recommended clutch bell? I'm running 14t now. Anyone have any idea what will happen if i switch to, say, 16t? 18t pushing it too much?
Just for bashing, in the local sand pit or what ever.
Old 11-13-2008, 02:02 PM
  #937
docphysics's Avatar
I would probably try 16T. 18T might be pushing it too much.
Old 11-13-2008, 02:54 PM
  #938
ORIGINAL: docphysics
Whats your opinion, what will happen if I push it too much? Break something or engine just won't rev enough?
Old 11-13-2008, 03:04 PM
  #939
docphysics's Avatar
the .32 is a big engine, so I doubt it would break. It might be slow at the bottom end as the engine tries to get the RPM's up. With a 18T it might take a while to get up to full speed and you would need a large area to run it.
Old 11-26-2008, 07:02 PM
  #940
riverat1540's Avatar
hey just got a crt pro x1 got it used on a trade and am building it up , going electric and spendin money like a drunkin sailer, let me know what u think? will be using neu 1515 1y 2200kv motor and 5s 5000mah lipo to power it also ordered big bore shocks for it
ID:	1079549   Click image for larger version
Old 12-08-2008, 12:50 PM
  #941
Heres my jammin crt armed with proline paddles, bashing in the snow!
http://www.flickr.com/photos/2709557...7610794483585/
Old 12-08-2008, 06:24 PM
  #942
Heres my crt x1 brushless conversion. weighs 10lbs and does 60+ handles great with lots of power on reserve hope u like it
Old 02-24-2009, 09:29 AM
  #943
Just broke the crankshaft on my force 32.
I would appreciate any suggestions for a new engine! I've considered some .21 engines, for easy handling on the track. Say Picco p3 .21?
Whats your weapon of choice for the jammi crt?
Old 02-24-2009, 07:24 PM
  #944
Just put in a trinity extech 2.0 full mod. awesome engine w/ 10 min 33 second run time. Still tuned a little rich but it makes great power.
Old 03-04-2009, 02:34 AM
  #945
My Feedback: (15)
anybody know if a lrp m26ss motor will drop right in? i got a jammin crt x1 roller and wanna try this motor out until i can get something else. how well should it perform?>
Old 03-04-2009, 06:08 AM
  #946
Turboprop130's Avatar
It depends on what engine mounts you currently have. If you have the low profile mounts that come with the pro kit you will need taller mounts. I run a LRP .28 in my pro kit and use a rotostart. I had to get taller mounts. I use the ofna mutilator mounts.
Old 03-04-2009, 08:18 AM
  #947
My Feedback: (15)
cool thanks for the info
Old 03-04-2009, 09:08 AM
  #948
ORIGINAL: riverat1540
Your making me jealous. LOL. I just got a CRT1 roller Im going to convert. 10lbs and 60 mph is a whole lota fun
Old 03-05-2009, 07:31 PM
  #949
im ordering the motor plate from rc monster. what size battery tray do i need they have two different sizes. or is someplace you guys reccommend to get one. thanks
Old 03-21-2009, 03:35 PM
  #950
it depends on what batt u are running send mike an email and he is best to clear any confusion before u order
