Nitro models pusher Bobcat?
#926
MO
RE: Nitro models pusher Bobcat?
Would it make scense to position the tank right at the CG? That way full or empty the CG remains consistant...or am I missing something.
#927
I have my 24 oz tank dead on the CG of my Goldberg Sukhoi.
I concour: empty or full, placing it there has -0- impact on balance. I never considered this on the Bobcat but after reading your posting, I too will be placing the tank forward abit, lol...
PM
PM
#928
MO
Angus,
Great craftmanship!
Please continue to post more pictures of your build. I want to learn from a master.
Great craftmanship!
ORIGINAL: Angus McDonald
I removed most of the underside and built up some of the spars as well as add another one. Then I glued in a mount for the retracts similar to a flex plate. I moved the servo well over for the ailerions. When I pulled off the balsa sheeting to remove the existing mounts and do the build up, I sure noticed the poor and lack of gluing done inside.....I'm not sure if I would put a turbine on one, it's going to give sooner or later. Anyway I re-glued everything and did full sheeting so I can glass it.
Angus
Angus
#929
AZ
I highly recommend flying the Bobcat and fine tuning the set up before anyone considers moving the fuel tank. I am finding that the "real" nuetral CG is closer 11" aft of where the leading edge meets the fuselage.
There have been many posts talking about the need to increase elevator throw, I now believe this is due to forward CG. I moved my CG back from 10.3 to close to 11" by removing .75 oz of lead from the nose. The elevator authority is much better and the plane is still slightly nose heavy based on analysis in flight.
The more I fly the bobcat the more I am impressed. I suspect this is due to the design of the airframe which I think we must credit to Bob Violett for. This plane has a very wide envelope and flys very well. With that said when the model was "converted" into the NitroModels Bobcat some of the background was obviously missing. At the center of this is the CG issue.
I was very fortunate in that many people had already flown the Bobcat when I did my review and had found the CG to be wrong. There were many other issues pointed out by early builder/flyers that made my project easy. I remember several posts scattered through different threads indicated that several CG calculators indicated 11" inches or slightly more to be the correct CG.
I can say with certainty that especially with heavier engines, the pilot needs to run out of elevator at the same time he/she runs out of altitude. If you do this the stock landing gear will not bend. If this is not somthing you can do or you don't have a very smooth landing strip I would simply replace the stock gear wire from the beginning.
Angus and others are sure making me want to try retracts, this plane is fast dirty, I can only imagine how much a cleaner aerodynamic footprint would help.
#930
OH
hello,
have a question. everyone talking about fixing landing gear blocks. I read in a post about putting epoxy in hole in front and behind of blocks. dou you have tomake your own holes, and how do you know where to make holes. not very experienced with patching covering
thanks
thanks
#931
My Feedback: (38)
ORIGINAL: mattgrant
Original Response:
The fuel tank is over the CG at 10". If you balance it at 10" there is a slight change in trim between full tank and nearly empty.
Are you saying to move the fuel tank forward? Right now as we all know, it is installed in the rear compartment, right be hind the engine. Just curious, can the manuel be that in correct?
Original Response:
2. If you are having problems with richness due to increase pipe pressure, install a hopper in there, and bonus you can fly longer!
3. Regarding reinforcing the landing gear blocks, you can drill holes and fill with exoxy or take a sharp xacto and cut nice square openings near the blocks, carefully remove the balso/covering squares, glue/glass in the blocks and then replace the squares and then wick in CA. Either that or get some same color stick on monokote from your LHS and patch.
4. DON'T ADD SO MUCH LEAD WEIGHT TO THE NOSE. Shove your battery pack way up there and hold in place with some thick foam pad and if that is not enough, Y-connect another pack and shove it in there and balance for aft with that, that way your dead weight is actually usable power for longer flight days.
5. You shouldn't be jumping off the runway, set the nose gear for slight positive angle and hammer it down the runway, it will take off and fly 2-3 off the deck smoothly.
6. I've got triple rates on the elevator, I fly with low and landing takes mid, and 3D stuff take high. If you don't have enough, you need a stronger servo!
The plane will nearly land itself, and touch and goes are fun. keep your rudder handy for the wind...
Hope this helps, thanks.
#932
SC
The tank is pretty close to being right on the CG at the stock location. Like I said, I happened to notice a very slight trim change near the end of the tank. Nothing major and at most it would need a single click or two of elev trim to compensate. Moving my CG aft .25 to .5" might eliminate it.
ORIGINAL: Larry Legg
#933
SC
To date may MLG have held up fine. I drilled a 1/4" hole in front of and behind the MLG mount blocks and poured in 5 min epoxy. I patched the holes with monokote. Worst case scenario you can put a piece of clear tape over the holes or matching color of self adhesive trim monokote.
To locate the position of the beginning end of the landing gear blocks poke a pin in the area in front of and behind the landing gear mount area. The pin will not be able to pop though on the hardwood of the gear blocks, but will easily poke through the balsa sheeting in front of and behind the blocks.
ORIGINAL: erin-rob
hello,
thanks
hello,
thanks
#936
My Feedback: (38)
ORIGINAL: mattgrant
DRAGONPILOT was are you using for your CG??? 10.5"???
Yep is right around there, I shot for 10.3 initially but I haven't checked in a while. I failed to mention that my Bobcat came with 2 3/4" beefier wheels the first kit and the second unbuilt kit were smaller. (see earlier post by me).
In any case, I've got those in the rear and a Greatplanes 2 3/4" rubber tire on the nose gear. (a little more weight up front). I'm going to retracts as soon as I can free up some time with smaller rubber tires and wire struts. The gear hanging down is ok but damn it'll look good without it. And faster. If you're using a bigger volume engine, install a 2 oz hopper. It makes all the difference. Smooth runs, longer flight times. PS, you're looks fantastic, great job with that finish.
#938
http://www.raidentech.com/bobcatjets.html
Trying this. There are only two sites that I know of that carry the Bobcat. You can also try: AK-Models. They carry a similar plane. Good Luck.
#941
http://stores.ebay.com/Harris-and-An...-C-and-Hobbies
$125.00 + 39.95 shipping BUT they have them...
Well, they HAD them, lol...
PM
PM
#942
Banned
1 Post
Fuel Proofing
Earlier in this thread someone said that they did not think the paint on the fus was fuel proofed. I did a little test bu dripping some fuel on the fus engine mount over night and when I whiped it in the morning with white tissue there was no paint colour on the tissue at all. I therefore conclude that is is fuel proofed... I used 10% nitro fuel.... Has anyone else found this
Dennis
Dennis
#943
AZ
My experience says the paint is fuel proof. I think I remember what you are talking about and in a later post there was a clarification that it must have been residual powder because the problem went away.
#944
I am curious. I see that 2 mini servos are required for the elevator. Do these 2 servos need to be run through any kind of matching box or is a Y lead sufficient ?
#946
AB, CANADA
For you guys that used the stock hardware, how did you manage to hook up the rudder horns? With the extreme sweepback of the hinge line, I can see how a horn and clevis would work from the stock servo position..... I cut slots and epoxied in Tamjets (keeping the topic jet related....) CF horns and used ball links to the servos....that works! ....on the ground , at least!
#948
Banned
1 Post
ORIGINAL: Flyboy Dave
The metal control rods that came in the kit were soft as butter....
....I chucked them.
....I chucked them.
Dennis
#949
Maiden flight of Serge's BobCat....video http://home.dc.rr.com/maurie/BobCatMaiden.wmv
#950
Banned
1 Post
Very nice first flight what engine and prop have you in her. Mine is about finished I have almost completed my build thread here :
http://www.rcgroups.com/forums/showthread.php?t=625414
Dennis
www.densplanes.co.uk
Dennis
