Old 10-17-2012, 05:49 PM
  #23451
Hobbsy's Avatar
Yes, it is just broken in and now resides on an Alpha 60 that used to wear a Saito 1.00.
Old 10-17-2012, 05:59 PM
  #23452
My Feedback: (15)
jkr_1100's Avatar
just wanted to offer the following ..
Goldberg Tiger 2 ARF with Saito125 Weighs 7.09 LBS (fully loaded ready to fly no fuel)
Goldberg Tiger 60 Kit with Saito 150S Weighs 8.81 LBS (fully loaded ready to fly no fuel)
Goldberg Eaglet with Saito 50 Weighs 4.36 pounds (fully loaded ready to fly no fuel) about 15 minutes on 6 oz tank with a little to spare (1/8 tank)
Old 10-17-2012, 06:09 PM
  #23453
Hobbsy's Avatar
Great selection, my Tiger 60 is the red ARF with an early high compression Saito .80, my Tiger 120 is going to wear a SuperTigre .90 Diesel conversion which turns a 15x8 APC at 9,400 rpm.
Old 10-18-2012, 08:20 AM
  #23454
My Feedback: (17)
SRQFlyer's Avatar
Very interesting! I have a DD head for my ST 90 and was curious how to prop it and what to expect. You saved me asking.
On another note - I was installing new bearings in a friend's Saito 180 and I lost one of the top rubber bushings for the pushrod tubes. I stole one from one of my 150s so he could get in the air. Does anyone have one (used is OK) laying around extra? The 120/150/180 are all the same part. I'll gladly cover the cost and postage, but ordering from Horizon when I don't need anything else is silly.
Jim
Old 10-18-2012, 10:38 AM
  #23455
SrTelemaster150's Avatar
ORIGINAL: SRQFlyer
Jim
Most local Hobby stores will throw your order in when they make thiers.
Even the small LHSs up here in the boonies make an order to Horrizon @ least once a week.
Old 10-18-2012, 11:57 AM
  #23456
My Feedback: (15)
jkr_1100's Avatar
ORIGINAL: SRQFlyer
Jim
Maybe Ebay would have this part? get the Saito part number and search ebay for it. may be just a few bucks
http://www.horizonhobby.com/products...bk-SAIE180B#t4
Looks like $10.40 and comes with 4 seals and new tubes too.
Old 10-18-2012, 12:09 PM
  #23457
blw
blw's Avatar
Senior is right. My small lhs does that and I never see postage costs.
Old 10-18-2012, 12:16 PM
  #23458
ORIGINAL: DougB1
This afternoon I flew the Satio 180 on 5% fuel ( it's all I had, ran out of 15% ) that is in mt 150 size Hanger 9 P-51 It has an 18x6 Vess prop on it and turned 8045 rpm's ( the sweet spot ) not to rich and not to lean. Does this sound like a good rpm for this motor with the 18x6 prop on it ?
DougB1
Could anyone give me some input if this is good or bad.
DougB1
Old 10-18-2012, 12:31 PM
  #23459
My Feedback: (17)
SRQFlyer's Avatar
Thanks guys,
I'll give the LHS a try - have to go there for fuel and other "standard" stuff anyway. Sometimes I just need another brain to help me see all the options!
Jim
Old 10-18-2012, 12:32 PM
  #23460
Hobbsy's Avatar
Doug, having never owned a 1.80 I can't say, I'll do some diggin.
Old 10-18-2012, 12:37 PM
  #23461
Hobbsy's Avatar
http://www.rcuniverse.com/forum/fb.asp?m=10948606
According to thyis you're right in the ball park.
Old 10-18-2012, 12:52 PM
  #23462
My Feedback: (12)
lopflyers's Avatar
Ok, Saito gurus, I need help.<div>My 100 is being flying great, today it just didn't want to iddle. When iddling makes a weird noise and dies.</div><div>I have not changed anything since the last time it flew. Also now it will not start by hand, whereas before it was only one flip.</div><div>Too rich in the LSN?</div><div>
</div><div>Helppppp[]</div>
Old 10-18-2012, 12:56 PM
  #23463
Hobbsy's Avatar
My guess would be LS needle too lean, Saitos idle pretty well when too rich, too lean they don't idle at all. If you watch closely while it quits it will quit slowly when too rich and quit instantly when too lean.
Old 10-18-2012, 01:08 PM
  #23464
My Feedback: (15)
jkr_1100's Avatar
ORIGINAL: lopflyers
Can you "borrow" a tank of fuel from a buddy and see if that helps?
Old 10-18-2012, 02:42 PM
  #23465
A similar incident happened to me last year with my Saito 1.80. There is a little screw that goes through the carb body and into a slot in the carb barrel. This screw keeps the carb barrel lined up when rotating and without it, the barrel will eventually slide off. In my case, the throttle pushrod held the barrel partially in place, but not enough to cause it from sliding out a bit, causing air leaks. It's a long shot, but won't hurt to check.
Old 10-18-2012, 02:47 PM
  #23466
DougB1,
I was getting around that speed with my Saito 1.80 with an MAS 18x6. I can't remember taching with 15%, but it didn't feel much more powerful, if any.
Old 10-18-2012, 03:00 PM
  #23467
ORIGINAL: hsukaria
DougB1,
Thanks just wanted to know if this was good and it sounds like it is.
Old 10-18-2012, 03:18 PM
  #23468
ORIGINAL: DougB1
ORIGINAL: DougB1
DougB1
DougB1
Mine turns an 18x8 @ 8000 W/15% nitro on glow ignition. (under ideal conditions)
Given the probable slight drop in power for 5% I would say that you are about right.
Old 10-18-2012, 03:43 PM
  #23469
My Feedback: (12)
lopflyers's Avatar
ORIGINAL: hsukaria
Hey, I've never seen that lil screw. I'll be looking for it. Thx for the suggestion
<br type="_moz" />
Old 10-18-2012, 03:58 PM
  #23470
Hobbsy's Avatar
Here is that screw, woops wrong picture, even though this is a .40 there is the screw
  #23471
ORIGINAL: SRQFlyer
Thanks guys,
I'll give the LHS a try - have to go there for fuel and other ''standard'' stuff anyway. Sometimes I just need another brain to help me see all the options!
Jim
I call mine in ahead of time so they have it when I come in.
Part # SAI120S40 is the pushrod tubes & rubbers. $10.40 list price.
If you ever need a quantity of parts, [link=http://www.advantagehobby.com/manufacturers.php?manufacturerid=244]ADVANTAGE HOBBY[/link] has a $50 free shipping minimum. (Horizon's is $100)
Their prices are about 5% less than Horizon's & they pull from Horizon's stock. AM orders are shipped same day Monday-Thursday.
Old 10-18-2012, 09:11 PM
  #23472
Ernie Misner's Avatar
On your Saito 100, if the LS tuning was right on the edge of being too lean you might not have noticed it until a change of season and barimetric pressure rolled in. You didn't change the nitro percentage in the fuel did you?
Old 10-19-2012, 03:31 AM
  #23473
Hobbsy's Avatar
Doug, here is a thread that started in 2005, it has a bunch of numbers for you to crunch and consider.
http://www.rcuniverse.com/forum/m_2631988/tm.htm
Old 10-19-2012, 04:43 AM
  #23474
My Feedback: (12)
lopflyers's Avatar
No, I didn't change the nitro percent, this happened from one flight to the next. Bummm started with one flip, nice iddle perfect. 15 mins later don't want to start, I forced it with the electric starter and it fired but when going to iddle it hesitates and quits. Since I wanted to fly I adjusted the subtrim for the throttle and flew her hot.<div>That is why I don't think is either needle. The theory of the little screw in the carburetor barrel makes more sence to me</div>
Old 10-19-2012, 05:11 AM
  #23475
Cougar429's Avatar
It would help to know what you mean by "at idle it makes a weird noise and dies" as this definitely could point to a mechanical problem within the engine. You could have a problem with the valvetrain or even something loose that would affect mixture. If you rotate the prop slowly by hand how does it feel?
One other thing to check would be to see if you have partially or fully blocked the carb fuel inlet or feed system with a bit of crud, (the reason a filter is such a good idea). If you have access to the fuel feed line you can check this by blowing into the carb inlet while working the throttle. Even at idle there should be some indication of flow into the carb.
You also did not mention if the behavior changed if you left the glow heat on at idle. If the glow plug is healthy the reaction when power is removed can tell a lot about mixture.
