Two ARF maidens. What a day!!!!
My Feedback: (221)
Took two new planes to the field Sunday afternoon and had a great time!!!!!! Watched 83 yr old Miles Reed put on a show with his 40% Weeks Special, then got to fly two new planes of my own. During pre-flight of my new Skyshark Christen Eagle, I found that, with right aileron input, the engine cut out. Very strange and had everyone there working with me to figure that one out. Got her fixed and finished the normal range check and all, then took her up for her first flight. Uneventful take off and a nice trim flight, (as best I could in the 10-12 knot cross wind). Landed safely on the third approach in the almost direct cross wind. Then, after a couple others had flown, put my new Phase 3 F-16 to the air for the first time. WHAT A BLAST! This little plane flys like it is on rails in a moderate wind, and down wind, she is really movin. Looks great in the air too. I recommend her to all who like a fast fly by with an EDF jet. She also slows to a crawl and handles very well even with the fan shut down. Everything that everyone had brought out went home in tact. GREAT FUN!!!!!! Here are some pictures.
RE: Two ARF maidens. What a day!!!!
ram3500-RCU
What did you to fix the interference problem. Was it electrical or what???
Some of us might be able to use the info some day ourself.
Congratulations on you sucessful day. May they all be the same.
My Feedback: (221)
Sorry guys. I guess I left you all hanging on this one.
I used an optic idolater as an on off switch for the ignition which I intended to have on a transmitter switch. On this plane, I used a Y on the ailerons, so aux #2 (normally the left aileron mixing channel on my 9303) was not used. This was the one I plugged the optic switch into. Big mistake. It was still working when I gave left aileron and was cutting out the isolator plugged into it. It took about 20 minutes to figure all this out. I simply switched to aux #4 on the receiver, and adjusted the travel on that channel, and now the cut-off works great, with no radio glitching due to the optic connection. On this plane, all the radio gear is accessible under the removable canopy hatch, so it was easy to fix without taking the wings off. I love the design by Sky Shark.
My Feedback: (8)
Way to go on your TWO maidens!!!! (one is usually enough for me on any given day) The Christen Eagle is one sharp bird; what power setup are you using?
Miles Reed is 83 years young? What a treat to hear he's still flying his planes. Watched him many times as he flew at Clarksburg, WV in the mid seventies when I lived there. Still flying at 83, eh...?
Yeah, we want to know what engine is in the Eagle. I have one on the back burner, seeing yours has made me want to skip a couple of projects and get right on it!
My Feedback: (221)
OK guys. Here ya go.
She has an FPE 2.4 (40cc) turning a Zoar 20 X 10 prop. Gas is 93 octane with Schaffers Syntec 2000 oil at 50-1 (the engine is broke in). I have the choke and optic on-off on transmitter switches. I intended to fit it with a Byson Pitts style muffler and ordered one. Waited 6 weeks, and when it came, it was the wrong one.
I decided to just mount the stock FPE muffler and fly the darn thing. It required another hole for the pipes, but the chamber fit in the large Eagle cowl just fine. It looks OK I think.
Power with this set-up?..........GREAT. It will do nice torque rolls and such, after I get some time on her. She leaps into the air, if I like. Plenty of reserve power.
I had a DL 50 sitting on the bench, but the plane just doesn't need it.
It balanced perfectly with no dead weight.
My Feedback: (221)
ORIGINAL: sqeakalong
whats going ram glad to hear about the madden do you know that I have still not madden the patty but this week i surly will I want a b plane so badd tell me something was the one you got hard to build are pretty much eyes close (meaning did you have to fabricate much thank
My Feedback: (221)
ORIGINAL: lill will
Hope that Patty maiden goes well. Balance it on the front side of the range at first, or slowing for a landing will be a challenge. I flew her with an 8" pitch prop and used spoilerons for that reason, after I got the CG far enough back for 3D performance. You will love that plane.
My Patty died last fall in a low inverted pass that got tooooo low. Her organs were donated to my new Yak. All is well.
yes I remember I am very interested in that bi plane there what is the wing span and also to go back allitle do you feal safe with balenceing a plane with the string metod
My Feedback: (221)
ORIGINAL: lill will
hay ram I was noticing that there is a flyen coming up there are you going? http://www.willardrcfunflyers.com/WillardFunFly08.pdf
My Feedback: (221)
ORIGINAL: lill will
My Feedback: (8)
Thanks, rams. Have lots of fun with your bipe...she's a beaut. ....and tell Miles the "Clarksburg boy" is STILL impressed with his flying antics! [X(]
My Feedback: (221)
My Feedback: (8)
Thanks, rams. It would be nice to see a pic of Miles..you know, he always took the time to listen to my questions and gave thoughtful answers to the newbie standing in front of him. The '70's and '80's were good times at the flying field. Thanks for bringing up some fond memories. Soft landings. Joe
My Feedback: (221)
