Destroyed Philips screwhead!
Hello!
I have a destroyed philips screwhead in a bad place, where the only way to reach the screw is from up. The screw is a 3.5 mm woodscrew, screwed into a plastic engine mount. Its almost round....
Greatful for ANY help!!
Best regards
Nokke
Best regards
Nokke
Sounds like you need to sacrifice a dremil bit. Maybe remove the motormount from the firewall. If you can do that, then a fiber cutting wheel would easily do it. BTDT. Worst case would be to destroy the motor mount and buy a new one. Use allen head machine screws with a washer and this wont happen. Not the button head.
Edwin
Edwin
Sears has a screw out set that might work. The cost is around $20. It's the one that Bob V. demo's on his TV commercial. They come as a set of 3 or 4 the small one should be able to get it out.
Go to the hardware store and ask for an "Easy out" with the proper drill bit. I was able to get stubborn Phillips head screws out of a motor head once this way. The Easy out looks like a screw with its threads running the opposite direction. You first start with a hole you make with the drill bit so that the Easy out has something to grip into. Then turn the easy out into the hole counterclockwise using a pliers or a vise grip. The farther it goes in, the better the grip it will have. Just don't drill so deep the head of the screw breaks off. These have never failed me. Good luck.
My Feedback: (10)
The only problem with the easy-outs is that they need a depth of at least the width of the hole, and that's if you're using the very tip.
I'm talking about the regular, tapered easy-outs... Snap-On and a couple other
large tool companies make some better ones, that aren't as tapered,
and have multiple sharp reverse flutes... they can take a bit more shallow hole.
If we're talking about a 3.5mm screw with a tiny head, it just ain't happening.
The idea to turn it into a flat head was the best, if you can get to it to do that.
Like someone else said, you may just end up trashing the mount here.
In the future... use better screws and/or better (or the right) tools.
I've been bitten by this one a few times myself
Try this...
Get a small drill that you can dispose of (or anything that's made of tool steel)
Using the shank end, grind a "flat" like a screwdriver then point the tip
Next, grind the tip to an angle that will cut when rotated counter-clockwise.
What you have made, in escense, is a spade drill that will bite into the screw head and (hopefully) screw it out.
All the above are good ideas on getting the screw out. Personally I only use socket head screws or bolts when mounting a motor. Using anything else is asking for a stripped screw head!
Socket head screws are definitely the real answer. I replace all kit and arf screw hardware when it comes to engine mounting, with socket heads. If you can get the whole mount off at the firewall, maybe just cutting the screw with a Dremel cutoff wheel might at least free the motor. Try the slotting technique first. Good luck.
Banned
Nobody has mentioned C4 plastic explosive here and I'm surprised. If you put a chewing gum wad size of C4 over the bolt head and then insert your remote igniter into the C4 plastique explosive. Leave the room or go a very safe distance away and detonate and this almost always gets the screw out or at the very least leaves the screw and removes everything around it. Of course I am just kidding. Could not resist
My Feedback: (178)
LA
PHS
I've found that if you threaten the screw it will usually back out on its own, or get really mad at it and bite the head off...
seriously, what about using a dremel cut-off wheel, cut the head off, remove the other screws, remove the engine then grab the remaining threads with a pair of needle nose vice grips..? :stupid:
Take the rest of the screws out and grind the head off of the rounded one. Slide the engine off the remains and then get out the pliars to get the rest of it out....................John
Ok! Thank you everyone!
I'll see which one of your solutions will work best, and let you know afterwards.
Many thanx
Nokke
Many thanx
Nokke
My Feedback: (31)
CO
Screw removal
Try a small needle nosed vise grips or a needle nosed pliers. Try grabbing the screw head to rotate it. If the tool doesn't slip off, this usually works.
OK, here's another idea. Put a drop of CA into the damaged Phillips screw head and put your screwdriver in that you have dusted with some accelerator then place the screwdriver into the hole vertically and let it bond. Come back in an hour and see if you can very carefully turn it. Wacky idea, isn't it? Might work, make sure the hole is clean first. Good luck, Tom
Throw your hands up in disgust and be thankful that you've got twenty people working on how to remove a stripped screw. At minimum wage, that's one expensive screw. I would try to get "that" screw out without destroying it, and put it on display. Possibly even develop an online "museum" devoted entirely to this famous item. You'll need a logo first.
If you soak the area around the screw with gasoline, then carefully light it, you can burn away the material around the screw. Most of the charred stuff should come right off of the screw. May take a small amount of polishing though.
SC
Well, I couldn't resist adding one more idea. I personally would avoid trying to Dremel, file, grind, gnaw, etc. on the screw with the engine in close proximity. One slip and you start Dremeling, filing, grinding, gnawing, etc. on your engine.
I would sacrifice the mount. Get a Dremel fiber cutoff wheel and cut the nylon mount from the opposite side right next the screw shank. When you get deep enough into the mount, you can break off the mount arm and pull the engine/screw free.
I was thinking along the lines of the CA concept but I was thinking more along the lines of 20 minute expoxy. I think the CA will let go but the epoxy might do the trick.
I don't think I'll be able to sleep until I figure out a way to help old nokke get his destroyed Philips screwhead out.
I'm thinking the glue idea isn't going to work.
So how about if you arc weld a screwdriver to the destroyed screw by placing a lead on the part of the screw that protrudes under the mount and put a lead on an old screwdriver and just weld the screwdriver to the screw? Wait until it cools and just screw out. Easy. Good luck, Tom
