BVM Bobcat Composite rebuild >
Old 10-06-2019, 07:44 PM
My Feedback: (93)
flyingchef's Avatar
Default BVM Bobcat Composite rebuild
A wild ago I got this Bobcat composite with a broken nose. Since then I mostly restored it and started to install the refurbished gears.
Since I don't any reference as where the scribe lines for the front gear door are supposed to be, I would greatly appreciate if a bobcat composite owner could reply with the curved distance value from the nose tip to the edge of the nose wheel gear door opening.
Thank you,
Bruno
Old 11-03-2019, 01:28 PM
My Feedback: (93)
flyingchef's Avatar
More work has been done since my last post.
BVM guys were kind enough to send me the cut out dimensions from the nose tip to the front gear door.
It allowed me to get the gear door cut-out at the proper location so to follow with installing the internal formers.
Old 11-03-2019, 01:43 PM
My Feedback: (93)
flyingchef's Avatar
It probably doesn't need it but I went on and added a piece of G10 over the two nose landing gear plates mounting blocks.
I received my new set of wings mid October, the wrong phenolic tubes were provided and BVM was very kind the send me the correct ones. The trouble now is now about setting the proper incidence for the wings. Since when you buy a complete Bobcat kit, the plywood rings on the forward sleeve are setup in the factory to set the proper wing incidence. When you purchase replacement wings, those rings need to be installed, however there no info as what the wing incidence is in relation to the stab, for example. I just sent an email to BVM, hopping that they will be able to help, but if anyone has some information they could share, I would greatly appreciate!
Old 11-06-2019, 06:26 PM
ravill's Avatar
Nice repair!!!
Old 11-15-2019, 03:33 PM
My Feedback: (93)
flyingchef's Avatar
I am still waiting from BVM to get info on the wings incidence. Meanwhile, I laser cut the new electronics tray which I redesigned to fit the electronics and turbine equipment.
The second picture shows the original BVM tray on top, and the new one on the bottom
Old 11-15-2019, 05:02 PM
My Feedback: (21)
yeahbaby's Avatar
I bet if you set it to fuselage you’ll be good to go. I’ll text my buddy Harley in Florida I bet he can find out.
Old 11-15-2019, 07:08 PM
My Feedback: (93)
flyingchef's Avatar
At last resort it's what I will do but I still would prefer to find the actual incidence, beside I'm sure it would not hurt to have the data for when someone will need it in the future!
Old 01-11-2020, 03:03 PM
My Feedback: (93)
flyingchef's Avatar
I have been working on the jet and taking a moment to post some updates. Thank you also to yeahbaby and Ravill for the support.
The nose gear and gear are done. I was not a fan of the "floating" gear door so I went the hard way and hinged it on the strut. The strut rotate in the door mount and the brass sleeves.
Old 01-11-2020, 04:04 PM
My Feedback: (93)
flyingchef's Avatar
For servos, I installed Savox SV-1270TG on elevator, flaps, and ailerons. As for the rudders, BVM recommended couple SV-1260MG.
I deviated from the manual for the rudder servos installation. Instead, I made a 3D printed mount. The servo slides inside and is locked with the hatch.
Old 01-12-2020, 04:55 PM
My Feedback: (93)
flyingchef's Avatar
Designed new turbine mounts then verified the fitting with 3D printed version. I will be machining the final version next weekend.
Original mounts
First prototype: In the manual the noted distance between the turbine bracket holes is 136 mm, in reality I measured 140 mm
Version with 140 mm hole to hole.
Old 01-12-2020, 09:24 PM
ravill's Avatar
It’s going to be rocket with a 140. You’ll love it!
What a great thread! Thanks for sharing!
Do you have a mill and a lathe?
Old 01-13-2020, 09:38 AM
Can you please tell me what software you used to design the board.
Patrick
Old 01-18-2020, 01:12 PM
My Feedback: (93)
flyingchef's Avatar
Ravill,
I would not dare putting a 140 on a Bobcat, I have the 120 and will tune it down to 130,000. I also fly at 5280 Ft which reduce the thrust by ~20%
I Have a table top mill from Harbor Freight which I converted to CNC. My lathe is also from HF, it originally a 7X10 but installed the 16" bed.
Sirrom,
I designed the tray in SolidWorks, and Adobe Illustrator for laser cutting.
Glued the wing tubes today with Aeropoxy, I have also installed the flaps and ailerons servos.
Old 01-18-2020, 01:13 PM
My Feedback: (93)
flyingchef's Avatar
Electronics tray setup
Old 01-26-2020, 09:57 AM
My Feedback: (93)
flyingchef's Avatar
As noted previously, I machined new turbine mount so to fit the KT120 (same size as the 80 and 100)
Old 02-06-2020, 05:18 PM
My Feedback: (93)
flyingchef's Avatar
While finishing the air setup for the gears, it appears that the nose gear cylinder is leaking. While waiting for a new replacement, I cut an hold one in half f to see if I can actually make one myself.
Will see this weekend!
Old 03-29-2020, 12:11 PM
My Feedback: (93)
flyingchef's Avatar
A bit off progress has been achieved since my last post in February.
All the servos have been installed and I upgraded my radio to a new Jeti DS12.
I received the new nose gear retract cylinder and machining a new one at the same time. I found a source for the 1/16", 3-56 thread, fittings and now in the process to finish assembling the new machined cylinder.
The new set of Kevlar fuel cells are glued and I moving forward with cutting a brace that will hold all three cells in place. I'd like to cut it using the same foam type that rc helicopters blades holder are made off, I just can't find the particular name of the foam material so to buy a sheet/block.
If you happen to know the technical name, please share it!
Old 03-29-2020, 12:30 PM
My Feedback: (7)
CARS II's Avatar
Awesomeness rebuild!
Old 03-31-2020, 03:54 PM
My Feedback: (93)
flyingchef's Avatar
Thanks Carlos,
Just finished the air cylinder this past weekend, the leak test came out good (120 max).
I machined as well a new brass adapter
Old 03-31-2020, 03:57 PM
My Feedback: (93)
flyingchef's Avatar
Old 03-31-2020, 04:00 PM
My Feedback: (93)
flyingchef's Avatar
Things don't seems to work well, only half of my post is showing and can't edit it,
Old 03-31-2020, 09:48 PM
Amazing work! Meticulous and perfectionist.
Old 05-06-2020, 04:09 PM
My Feedback: (93)
flyingchef's Avatar
Thanks Henry,
Did not post for while, just been busy with airplane projects. I finished the nose wheel hub last week, mounted and ready to go. Since my last post, I switched to a Jeti DS-12 system. I designed a new electronics tray layout (3rd one) and finishing the installation (Central Box 200, and couple R3 receivers). I also added the expansion switch board in the DS-12 with a throttle momentary button, swapped some other switches around, and added a locking 2 position.
Old 05-30-2020, 02:27 PM
My Feedback: (93)
flyingchef's Avatar
Since my last post, I finished all the electronics installation. Since I switched to the Jeti DS12, I cut a third electronics tray layout to reconfigure the installation.
The setup consist now of the Central Box 200 and two R3 receivers. I also slightly modified the UAT tank sitting.
Still in the process of completing the setup.
Next is to setup the airspeed sensor. I machined a small unit that uses a Dremel 1/8" aluminum collet. All seems to hold pretty well once the cap is on.
Old 08-17-2020, 05:58 PM
My Feedback: (93)
flyingchef's Avatar
Finally found the time to maiden the Bobcat. Time to move on onto an
other project!
Mission accomplished
makis (08-18-2020)
