- giant plane
- Maiden flight on 540 Edge
- ACE 33% Extra 230 - need control throws
- Midwest Cap 80" & BME 44
- DA-100 Dimensions
- prop size
- Carbon Gear for H9 80" CAP??
- ST 3250 Muffler Question
- H9 330S Horizontal Stab Linkages for Elevators
- Stinson Question
- Aerodynamic Center
- Help got a bent crankshaft on a FUJI engine
- Balancing Large Planes ?
- Moki 2.10 (upright or inverted?)
- wing bags
- RC-56 enought to hold canopy on?
- Biplane Kit for a G-62
- my DP extra....
- I need a DA-150
- OXAI Models and the Like
- I Need the CG for a Pacific Aeromodel Laser 200 ARF 120
- Thumbs or thumbs and fingertips
- Moving The CG ?
- Hydeaway Wing Rock
- K&S Cans in Fiberclassics 2.6m Extra
- Best smoke fluid thats not messy!!! smokin pics
- Looking for 1/4 scale Gee Bee D plans or kit
- Flyababy Bipe, other owners help??
- Comp-ARF 2.6m Extra Control Throws
- Composite ARF - 3.1 Super Extra!!!!!
- Air Models Props
- Used Brison 2.4 Prices
- Weeks solution
- 42% weeks solution from si models
- Couple of Questions
- Soft mounts for gas engines
- Carden 35% Cap
- Aftermarket Canopies?
- Where to go for color scheme/graphics design
- Giant Stinger: Setting up electronics
- J-3 Cub 1/3 scale plans -- missing one sheet
- Fiberglass Cowls
- Engine Spacing on H9 Extra 330L
- aluminum vent fitting
- Holy Cap
- Tail Wheel Bracket Help
- Aileron mod on BUSA EAA Bipe
- L 19 bird dog 1/4 scale
- Problem with US Engines and BalsaUSA 1/4 Pup
- Hanger 9 Ultimate, covering problem?
- edge 540/zdz 60 troubles SOLVED
- A.W. 33% 540
- I NEED A NEW PLANE FOR A G26 !!!!
- Scratch building Hostetler's Gee Bee 29%
- servos 4 DP ultimate ???
- Dual 6V system with two MPI switches. What are my charging options?
- hanger 9 ultimate question
- Composite-ARF 2.3 and 2.6
- Hanger 9 Cap wing alignment is off
- How to prevent wing tube wear
- Control Surface Pilot Holes
- Split elevator setup
- Awesome day at the field
- Mailing the CAP-X to Australia??
- 35% extras almost in?
- Boxed aileron vs. full span
- SIG SPACEWALKER DIFFERENT COLORS?
- i am looking for the manual of Cermark Pitts-s2b(old version). [:o][:o]
- Sure-Link pull-pull system
- Anybody out there building a 35% radiowave
- Help finding muffler for 3W-75 on a Corsair
- Tru-turn spinners/best price
- Cross-Country Project - need some advise
- I wanna fly my H9 Extra 330S
- HELP!!!!!!
- 3W 106 vs DA100 vs BME 110x
- H9 Vr. Protech Extra 330S 96"
- Landing gear alternatives?
- ultracoat paint matching anyone?
- MOVED: carden 35% edge????
- Tracking Straight
- LE Designs ARF's
- 4 Servos on a biplane question
- Anyone using TBM batteries ????????
- Carden 35% edge - ZDZ 80?
- How do u set up spoilerons on H9 Edge 540?
- old "lance kits" from saltlake city
- Extra 36% pushrod lengths
- Engine and Plane choice Help...
- DV Hyde Mount DA-50
- Position of holes drilled on props for DA50
- Bud Nosen Aeronca Champ
- Servo Placement on Lanier arf 120 Stinger
- fuji 86cc twin and nylon gear bolts for 33% EXTRA330L
- Cap-X ordering
- What is the best place to order a BME 110X?
- Edge/DA50R combo....What prop??
- H9 Sukhoi Which Engine
- Fema on board starter for SuperTigre on ebay
- engine size
- Trailers
- 9Z Programing Question
- 40% Reciever battery packs
- First 3-D.
- FLUTTER! Can a loose aeleron cause extreme flutter??
- dynaflite 1/4 cub
- Carbon Fiber Gear for 27% MIDWEST CAP 232
- What paint to use for a plastic canopy??
- AIRFOIL FOR YAK 55?
- GT-80 in Big H9 CAP 232?
- Carden 35% Extra or CompositeARF 2.6m Extra
- Vision 3D
- PULL PULL SETUP WITH FISHING LEADER LINE
- H9 Sukhoi Servos
- Your experience with the "new" Super Tigre 2300
- Hanger 9 Taylor Craft Rudder Deflection?
- For the video lovers.... New 40% footage from today!
- HAVE MOTOR NEED PLANE!!
- Bad Customer Service from RC Showcase
- A couple of minor nits......
- Wing Bags
- Great Planes Patty Wagstaff 300 wings stuck
- Prop Cover's Who Sell's Them?
- sullivan smoke pump works part time??
- Composite-Arf Wing failures??
- Double Vision
- hanger 9 cap 232 help
- How many think shortman won't get a new plane! (or what should he get)
- how much weight added with paint?
- EXPERIENCED BIPE PILOTS - SOME SUGGESTIONS AND COMMENTS PLEASE
- Heard of the geenmodel Laser 200 Class 120?
- Edge 540T in PA
- Typhoon 2+2 setup
- H9 EXTRA 330S Thrust line
- Next Shipment News
- New engines from 3w
- Best single servo pull-pull setup?
- Ball Links or Clevises on 31% +
- Music wire.
- What are you guys using for smoke pumps..
- 30% Byron RV-4
- Light Weight giant scale non-aerobatic aircraft - does one exist
- 36% Extra - Aerobatic Setup
- Byron Christen Eagle
- Best Hangar 9 1/3 ARF?
- Dave Patrick Models Edge 540T 40%!
- SOLARTEX information ??
- H9 Super Cub Tailwheel
- 1/3 Scale Stearman Landing gear
- 52% Giles 202 - Wow!!
- Katana s 36%
- Canister room in 35% WH 330L?
- 42x10 or 26x10
- BEST 3d trainer for gas?
- BME 110 Extreme in H9 Extra 330?
- CA 31% Extra owners - Large Scale Builders - HELP!!
- Composite-arf Yak colour change
- What Giant Scale stuff are you selling/buying in Perry GA next weekend (3/2-6)
- Help Identifing Ultimate biplane
- hanger 9 edge "hatch & canopy"
- H9 CESSNA 182 ARF...BEST ENGINE CHOICE
- H9 SuperCub/Roto35 Build
- lanier cap arf
- Engine for Wild Hare 35% Extra 330L
- where to find onboard starter for G62 and how to split fuse in halves?
- 30cc engine RPM
- Wild Hare and Brison 4.2?
- Servos
- Difference Between H9 330L and 330S??
- 1/4 Sig CW Cub
- Plane setup CG and dual recevier
- Best 1st scale aerobatic plane
- GP EXTRA 330 L SERVO SELECTION
- Great Planes Giant Extra kit
- Out of town at Phoenix Contest
- Giant Scale Batteries? What do you use?
- Giant Aircraft Radio Poll
- 31% CA Models ARC Questions??
- easy way to program flap/spoilers on 9c?
- Better Flying Giants
- How to Find CG
- IS IT SHOWTIME SMOKE SYSTEM OR NO SHOW SMOKE SYSTEM?
- Rear mounted servos?
- Will the moki 2.10 give the GP pitts unlimited vertical?
- Carbon Fiber Tangs
- Jekyll 91 knife edge pitch question
- Who sells kevlar coated wires for pull pull?
- Don Smith Super Connie
- GP Christen Eagle - How's it fly?
- Feet Flying???
- looking for giant scale set up tips
- Need source for 48" long "Music wire"
- Giant Scale and Gyros
- Gp Pitts fuel tank???
- cessna 180 or 185
- kangke rearwin speedster pic wanted
- Sig 1/4 Scale Cub Always bounces on Landing
- Perry Smoke Pump Enough ??
- Website for A&A Industries?????
- Learning 3 D on ARF Which One
- Man I'm gonna need some help!!!
- Goldberg 30% Ultimate First Flight
- 2.3 Composite-ARF - Chapter II
- Battery situation facts
- Mounting landing gear on Giant 30% Cessna
- H9 Cap 33% with single 8611 aileron servo's
- rascal 110 & 3w-34
- Insane Byron GeeBee R2
- A Few Pictures of my 80" CAP
- CB associats
- Rudder pitch coupling
- harrier wing rock
- 33% Aero-Works 540t
- buy a DPM ultimate but...
- DOUBLE VISION BEAUTIFUL
- SNEAK PEAK AT CHIP HYDE'S NEW PLANE!
- CAP-X Manual NOW ONLINE!!!
- Elevator control link length??
- Yaaaaay
- Where to buy a Lanier Stinger ARF??
- Severe case of "Servo Confusion"
- Hanger 9 33% 330.... 3w106 g-62 3w75
- Sirius Lithium Charger
- Need Ideas & Pictures for Cockpit
- hanger nine sukhio
- My 35% Airwild Edge is ready to ship!!
- Looking For a Specific Paint Scheme
- New chip hyde CAP-X just recieved at the wram show
- Which servos for 28% Cap
- Stinger 120 or four star 120
- next project on board
- super cub kit??
- Taylor Craft Ailerons
- JR Matchbox Instructions??? PLEASE!!!
- New planes and web site ,composite-arf
- MOVED: 30% Carden Cap Construction Pics
- Lasercut Monokote!
- Need to disappear to the basement for a month
- 3W-75 in a Composite Arf 2.6 or 2.3 ???
- Balsa USA 1/3 Stearman
- Two planes.. two power setups
- MOVED: carden 30% extra
- DA 50 VS BME 50 VIBRATION
- modeled a large scale jet
- Making longer 20g Servo Leads?
- Dave patric edge?
- Dalotel
- is Cactus Aviation out of business ???
- Trailer set ups
- TR'ing under adverse conditions
