- Hangar 9 Aspire upgrades
- Dodgson Lovesong
- Clipped wings
- Multiplex Easy Glider Question
- extra battery
- Too much battery
- Sig Riser 100 Throttle/Spoiler servo
- EXPENSIVE HOBBY
- Best Glider weight range for Slope Soaring
- Please identify this glider
- New Ideas and Designs
- Spoileron with DX7
- New kit builder Warps
- Olympic III Plans
- Belly skid tape
- cularis
- motor size
- Power Pod What is UP or DOWN thrust
- Can G5 be used to learn thermaling skills?
- East Coast Pilots - time to start planning your contest schedule!
- battery help
- Which aerobatic slope soarer, the Voltij or the Vector 3
- Fournier RF 4
- folding prop vs solid prop size.
- Exceed RC 6-Ch 2.4Ghz Transmitter w/ Receiver
- DG 800S 147-177in.
- Graupner EA W22 questions
- Tailless glider wing sections
- nesail.com?
- i need information about my glider built from foam
- Anyone???
- Going to the Hill
- New Soaring Goodies
- Looking for altimeter
- CAN YOU IDENTIFY THIS PLANE????
- D-HELIOS
- .30 motorglider
- HC Super Danny (LJ Signature)
- Looking for the person who posted these fix pod images
- ACE High MK II Glider
- MEN Gobbler sailplane
- Toy Glider Survey
- Silly question
- Elevator control for Polk Hobby CHARLOTTE ARF GLIDER
- windrider habciht
- Christmas glider question
- DYNAM SONIC 185 REVIEW
- Wish to extend flight time.
- Zigzag Turbulator Tape Source
- New to sailplanes
- Sagitta 900 Conversion to Electric
- Dodgen Lovesong wing rod
- SOARING COMPETITION IS ALIVE AND WELL
- Sig Ninja EP conversion
- Laser art majestic
- Help with 7C and spoilerons
- Balsa Wood Gliders Project
- 2.4 and composite plane
- old radio vs new
- Robbe ASW 27
- Grob 4 meter Graupner
- Time to make the switch!!
- New wing foam core options!
- Custom wing cores cut a reasonable rates...
- Airtronics Aquila 99" vs Sagitta 900
- wattage hawk
- Southwest Classic 2010
- JART in Italy?
- Im looking for a fiberglass fuse.....
- Instructional Hand Models - source??
- GP Spirit Vertical Stab & Rudder Plans
- What isR\E
- Tangent Alpina 4001 electro
- Younger Pilots
- Leading Edge Gliders P-40
- Electrifying Sig Riser 100
- Stupid question about the Butterfly
- 83" mothership
- ls-3 scale
- servos for a Nitro Hobbies Super glider
- Dynaflite Butterfly pushrods
- banana hobby st-360 ep glider good to get
- short kits
- Adding ailerons
- GP Spirit 2M sailplane - glow power?
- Dynaflite Butterfly tricycle gear conversion???
- What to do with a crashed electric heli.....
- What servos to use?
- Help with Glider Please
- Sailplane mix
- Easy Glider Pro Battery Mounting
- What do you recommend for a first slope plane?
- Glider coverings
- Which Transmitter
- how much is 2 degree upthrust?
- Towing with a four star 60
- Where do you buy a winch
- how long do i charge for?
- Multiplex DG 600 Evo
- Bungee/Hi-start rubber
- Sprit Elite
- My first towing
- Hi, i got a 77 inch glider, i want a brushless motor for it
- EPP Profilm wrinkle question.
- Orange Coast Radio Control Club Swap Meet 10-4-09
- Can you identify this glider?
- Polydihedral question?
- Advice needed on excessive wiring.
- Wik Condor
- Giant glider tow
- NE Sailplanes
- Dynaflite Butterfly conversion???
- Parkzone Radian?
- The 1 hour club!
- Glider advice
- Last Chance to fly with the Eastern Soaring League in 2009
- A new magazine is born: AUFWIND English
- Contest - ESL FINAL TD CONTEST WEEKEND 10/3,4 - Current Standings
- Hobie Hawk Electric Conversion
- 049 power pod wanted
- RC Glider I was given.
- Vario Which 1 ?
- Prototype of the flexible wing in f3j
- Electrifying 2 mtr Sig Riser
- Strobe light
- Best Kv Choice for Easy Glider E with stock Gearbox?
- Convert Organic to Elec Organic
- Listen To Free Podcast On Cutting Edge Soaring
- Covering Foam Wing?
- Wik Condor
- Any RC pilots in the South Bend, IN areas?
- GM Thermal Charger
- Sig Samuri???
- Making an engine pod for a 100" glider
- WINDRIDER BEE2
- Robbe ASW 3130 m.m. Sailplane
- Twist-O-Flex Build thread
- Lucy Speedy 2 meter sail plane
- Contest - DLG or Unlimited, your choice, 9/12, 13
- Hand Launch Tow Line Gliding Setups?
- Can you identify this vintage sailplane??
- Slope Soaring in DFW area?
- Angle of incidence in catapult/handlaunch glider
- Talon SuperTalon Twist-O-Flex
- Newbie question regarding flying in cold weather...
- Radian Modifications
- First glider/sailplane RTF?
- LSF?
- Contest - Unlimited Sailplane 9/19, 20 Syosset, LI, NY
- R/C Soaring Book
- Vista Wing Incidence
- Need help getting an ID on an old 3m
- New to RC gliders/sailplanes???
- What would happen . . .
- Retractable monowheel for sailplane
- Best 100 inch plus arf e-powered glider for the money?
- Props
- Waco Primary Glider
- Looking for e-sailplane suggestion
- thermal soaring with real flight
- Calypso Contest T
- New to sailplanes
- building plans
- New airfoil for Bird of Time?
- setting up a cargo trailer for sail planes
- Slope soaring scale recomendations??
- alternative for balsawood fuselage?
- Craft Air Leo
- SKSS 3rd Annual Aerotow Aug 21-23
- motor thrust question
- Contest - Unlimited Sailplane 8/22,23 Reading PA
- Contest - Hand Launched - Rockville MD Aug 15 & 16
- Hawk rock or hawk mountain slope soaring PA
- slope soaring off buildings
- HINGE TAPE FOR JW 60
- battery packs
- Mark Drela Bubble Dancer
- Contest - Esl - Sudbury Ma - Aug 8/9
- FVK Sprite Thermik
- Help w. Identification of this Glider
- selflaunching system
- Ailerons on a Bird of Time
- Modifying a really old 3m sailplane
- Saracen sloper
- DG-1000 OR ASW28 ?
- polyhedral wing for a glider
- e-book FREE
- Blu-Guppy a 96" KFM3 Sailplane
- Composite Hinge Construction
- Engine Pod degree offset
- Need ya'lls help!
- DLG
- The World Models / Aure EP
- Pike Superior ail/flap servo mounting
- Mountain Models Quick Flick II
- Velcro tug system!
- Better than a ZAGI?
- Siren Great Planes Help
- Gnat zip glider.
- Biofoam catapult 8inch glider
- Brushed Motor Help
- GRYPHON aerobatic wing
- Glass fuselage
- servo setup/wiring question
- I could really use some help.
- What's the difference in motors?
- coyote lite build
- Giau Pass & mont. Rota (Dobbiaco) - Italy
- Tow Planes
- Sailplane Calc Update
- You gotta laugh!
- Which full house radio?
- Australian slope festival
- Who is going to the ESL Contest In Sudbury, MA July 11 & 12?
- Who is going to the ESL Contest near Reading PA July 11 & 12?
- MOVED: My thoughts on the Spektrum incidents...
- Who is going to the ESL DLG Contest Aug. 1 & 2 in NY
- MOVED: Spectrum recievers and brown out
- Cermark Phoenix CG - Where is it??
- Question - CG for MAD Messerschmitt P-1111
- suggestions needed - reinforcing a Toucan
- new here
- U-2
- Scale areo tow in the Barossa Valley South Australia
- Which 2.4 tx? 10CG or DSX9...
- Gentle Lady Power Setup
- Great Planes Spirit info
- A Timer's Guide for TD contests.
- Tangent DG 600 Evo
- Aerotow off water
- Launch Dolly
- oly 2 s and bird of time arf
- Spectre Wing
- Which Transmitter??????
- 120" Sagitta
- True flight basics for first timer + Tower Vista
- Sailplane selection
- Any slingshot launched gliders out there?
- Cannon RC Systems c. 1985
- Nats Registration Deadline
- Siren Zippy Battery
- Clockwise, or Counterclockwise?
- ASW 28 Electric Glider ?
- EP sailplane contest regs
- Whitler? good hotliner?
- Newbie mode 1 advice.
- Radian
