View Full Version : Glow Engines
- Thrust in pounds?
- Irvine 61 Prop
- TT Pro46 too rich in mid
- YS 91 problem
- Moki 2.10 will not idle down.
- which .46
- TT 46 Issues
- Engine wont run upsidedown
- Moki 1.8 sucking air?
- O.s. && Vrdf
- OS 61SFH carb
- Help running a OS FT-160 twin
- Fox Hawk .60
- Webra 91 any good?
- K&B Torpedo GreenHead .45
- anybody know info about kyosho gt .12 engine
- vintage '84 K&B 40 R/C
- Problem w/ Magnum .40
- What Is This??
- ys 63 help
- Get the most out of your Saito
- OS 91 Surpass tear-down
- What is the crankcase breather return for on a Magnum 120 FS
- Radial bearing clearance: C2, C3, C4, C5?
- Magnum Pro 45 - HELP!!
- Os 32 F ?
- ASP .91 carb sourse?
- Fox 72 duel plug
- Do bigger 2c glows just run better than smaller ones?
- Help, Engine took a Bath!!!
- RCV from Condor Models/ Great Service
- How much noise is 86 DB?
- os 10 la won't peak
- Muffler advice
- Apc 18-6
- Old Unused Motors
- YS 140 dz new defective?
- www.gmsnegines.com - Any experience buying from them ?
- Glow plug life span ?
- Webra 50 Speed bearings
- Engine wont stay running
- Ys 63 Needle Settings ???
- Thunder Tiger---Magnum----Super Tiger???????????????????
- Saito 120 Throttle
- best fuel?
- O.s. 10 La
- Ys91ac ?
- Irvine .53 Muffler Choice ?
- Need help with used OS 120E
- Tiger Shark Engines
- Realistic RPM
- OS 1.40RX vs. 3D 1.70
- Inverted Four Stroke
- were do you get YS GROW plugs
- Magnum Overhaeting
- ASP 91 has had it
- converting a Perry carb. to remote
- Need help in finding a correct muffler
- Webra 1.20 help
- Magnum/ASP Availability in Canada
- TT .46 Pro and Tower Muffler
- Evolution Engines
- ys versus saito
- Magnum 4 Strokes
- O.S. 46 - Mysterious engine failure...
- Interesting fuel draw problem-46fx
- Glow driver- YS140?
- Anyone running the Irvine .53 at 45 degrees inverted?
- Saito 100 spare parts
- Saito 72 runs then stops
- Engine rpms
- Missing Nipple
- Dual Plug Saito 1.20 w/pump?
- Whats wrong with MDS?
- Webra 50GT and 61F
- easy sport 40 engine
- Rule of thumb on in-cowl applications
- Moki 1.8 and Mousse Can
- MDS .18FS Pro Question
- FA 100 for Goldberg Ultimate?
- Saito 100, Irvine 72, OS 91 comparison
- OS BGX Idle Problem
- os max .10 overheating?
- Saito 182 TD Problems
- Do magnum's really need 20% castor for break-in?
- I could use your 2 cents worth
- Pesky ST 90, gets hot, dies abruptly
- Jet Turbines
- Basic (dumb ?) question re. Webra .50
- Piston Ring Blow-By
- Saito 180 and sikhoi (goldberg)
- Enya cx11Diesel
- FT-120 prop speed
- H.P. question
- Best way to break-in ringed 2 strokes
- What is this problem?
- MVVS 49 power questionable with quiet muffler
- Ys91AC in 1/4 Cub - Prop size?
- Evolution 46
- 60 size Veco / carbon buildup
- Tuned Pipe Set-up for ST.61
- Royal .45 muffler search
- irvine 53
- Irvine 53 Idle Problems...
- Please help!
- Supertigre 2500
- Perry Pump and Carb Setup
- Problems on My PICCO P60
- Another wasted evening with the OS 91FX
- Engine break-in ST 75-ringed
- Os Ft-160
- cline or perry?
- Rear mounted needles. Good or bad?
- Prop Washer
- Moki 2.10 Props
- Questions about o-rings for new TT 46 pro
- Saito 180 and AW Edge 25%
- whats the BEST prop for a TT PRO 46
- needle setting for 0 1 picco
- Replacing .46 OS engine parts...
- HELP - New OS1.40RX running like Crap!
- O.S. 46 FX broken engine mount screw
- Rossi
- Norvel venturi Screen or not?
- Moki 1.8 break in fuel?
- Replacing feul needle on Hyper 21 motor with one from another motor???
- cold fuel
- fuel tank question
- Magnum 52xls 2 stroke is running backwards!
- Saito 100 idle
- Os 90fx
- Glow plugs keep burning out!
- New Enya .60
- OS40FP Crankcase Oil
- K&b .20
- How to make a dual on board glow set up?
- What's wrong with 3 in 1 oil?
- OS91FX and OS91SX-H
- Does anyone recognize this engine?
- mds .48 runs fine after all
- Surging and fuel coming out of carb
- Engine Conversion
- YS doctor?
- Saito engine repair
- Advice On Os Stopping
- YS 110 Information Please...
- In-cowl engines
- Dykes ring
- OS 61 Hanno pump settings?
- ASP .91 :: need info
- Magnum .52 2 Stroke Break-in Help!
- Mecoa Engines
- Engine recomendation
- SAITO 120 Melting Silicon tube
- .15 Engine Reccomendation
- Please Help Saito FA-80
- YS 63 newbie question
- Os 61 Sf-p
- Bisson Pitts muffler question.
- OS 91fs vent line question
- OS 77 DF? What the dealio?
- What Perry Pump goes on HB .61 PDP?
- HELP w/ MVVS 1.22 Twin
- Marvel and Synthetic oil
- O.S. .46fx Probs
- Help Me Find A New YS 110 Please?
- Dumbest question ever asked..4 stroke
- Silly Newbie Diesel questions
- moki 135 e.p.t. genesis pipe
- engine for CG Freedom 20
- Which engine for a new Avistar???
- Break-in prop for TT GP 42????????
- smoke coil tubing
- What is the best prop for a Magnun 120 (2 Stroke)
- slimline muffler fit the OS 120III pumped?
- RCV early model SP120
- Slick 50 and 2 stroke ABC's
- Old OS .10FSR fuel mixture.
- Changing Saito 56 bearings
- Saito 72 carb.
- Enya Parts
- Ross 60 Twin
- diesel utilization in model aircraft
- Which prop to go fast?
- Breakin in a Saito 1.50
- Perry Pumps - V20 or V30?
- YS110 vs OS120-III close call for most power??
- engine dies after vertical?
- ofna 8 port breakin
- Moki 2.10
- Stripped Glow plug threads
- Magnum 91 4 Stroke-What's wrong???
- Saito 72 breaking in question
- Help. Moki Overheating.
- Mag .32 remote needle valve placement
- GMS-60 dies when inverted
- K&b.48
- Best fuel for YS?
- Ok you engine experts...
- Make your stock OS .46 muffler perform like a Tower Muffler for FREE
- Moki 1.8 needle setting
- what engine should i get?
- Enya 35, can I drill for a muffler?
- Saito 170 Radial_Smoke System??
- Looking for a Replacement
- Magnum .46XL Carburetor
- Moki 2.10 Help "mounting Radial"
- Magnum XL 91 AR FS....No thank you
- Mecoa 46 & Pete n Poke
- O.S. CV-R stalling
- Perry carbs
- OS52FS Tach Reading
- Why does my engine spit black goo on first start
- Magnum 120 4 stroke - prop size
- Need OS 61 4-stroke information
- What size spinner for a YS91FZ
- r1.55 length
- Webra .52 needle valve
- Tower .46 Woes - suggestions wanted!
- OS 10 hard to start
- 46- fuel problem??
- perry pump/ air bleed carb
- O.S. LA starting problem
- MDS .28 break-in instructions for a newbie
- Surpass 70 or Saito 72
- 4 stroke economy?
- ASP/ Magnum 52 fs vs 61 fs which one?
- Webra 32 what to do
- Extracting screw from crankcase of an os .15 cv-x
- Os Ft 120
- Need help with torq .21 carb settings...
- OS 1.60fx - who has it, what airplane
- Irvine .61 mixture question
- muffler mod.
- Lets race...OS vs YS..opinions?
- 3 blade props on Enya 50
- I want to upgrade my engine in my savage. OS or wasp?
- ASP .61 won't run - help
- magnum .80 four stroke
- ASP .80 4cycle adjustment...help
- Pitts Muffler for Super Tigre 45
- Specs for an OS60?
- Pitts Muffler and Power/
- Saito FA-150
- MVVS .61 Diesel
- Fuel Consumption 2s vs. 4 stroke
- ROSSI 40 prop
- ENYA 1.55 R 4 stroke / muffler
- asp91 muffler choices
