- Looking at a Thunder Tiger .46
- New OS FS-81-A pumped leaking at regulator
- Tower Engines Gone?
- Super Tiger G90 Needle Valve extention?
- How to clean a muffler?
- Exhaust position
- Brief loss of compression on Saito 100
- looking for a displaY ENGINE os 60 open rocker
- YS 63 FZ Problem
- ST G51 Fuel question
- Irvine .72 problem
- OS 70FS valve
- K&B .65 Sportster Carb questions..
- New OS60FX engine after crash
- Drive washer for .40SF
- ST .60 Blue Head shaft size?
- enya 50 cx tn
- Part for TT pro 61
- 40sr
- Enya 53 older style, poor idle
- Cross Ref.
- Help with an ID
- Opinions on ASP61 four strokes
- Open discussion about the glow engine's carb
- Enya 6001 ring placement
- 4 Stroke twin Vent.
- engine runs backward during breaking in
- Magnum XLS .46 Break-in/engine tuning problem
- ASP Engines
- OS FP40 Needle Valve
- Lincoln 61 glow???
- 25 fp carb on 35 fp-s engine.
- SAITO 150! Prop for max thrust..
- New Saito 57T twin Gas Engine
- New Saito 200R3 Radial
- Saito Red Valve covers
- Recommended glow plug for MVVs 91 ?
- YS 140 SPORT mount Qustion
- My two Penarth of the Saito 220 zues low end set up
- Magnum 120FS
- Difference between the Magnum XL 91RFS and the XL 91FS AR?
- ys 60 fr
- Opinions wanted...
- SO, where is this new Engine?
- HSN Only...is that weird?
- On board tachomter
- Cox engine not running properly
- Sig Extra 330 - AX 120?
- looking for "perfect" old time 4 stroke for plane
- engine temps
- throttle barrel stuck how to undo?
- Super Tiger G90 Question
- OS-FS-200S
- Saito 170R3 Horsepower?
- Help! Can you identify this carb
- OS 120 w pump
- Saito 100 Questions
- OS 7M Carb
- Anyone still using the youngblood mp5 with os 50 hyper?
- OS max .25fp vs. fx
- General Radial Question
- An y Update on GMS Availability?
- Anyone tinker with a MVVS 77 Motor?
- magnum xl180 4 stroke
- OS 91 fs (pre-surpass) tuning issue
- new saito 91 four stroke problems
- Thunder Tiger Pro12 running issues
- Saito 125 - weak compression after rebuild
- Ueda 61
- Changing Fuels.....and mixing
- Will it run ?
- 90 Twin
- 20% nitro vs 30% nitro
- OS Max 61 FX on a TF Corsair 60??
- Saito decals..where to find them ?
- Don't need no stinkin' after run oil!
- OS 25FSR
- Fox dual plug .60 RC boat Engine.
- Advice needed...
- Identifying engine age
- YS 63 FZ or OS 46 FX in Venus
- Max Sustained RPM for a Saito 1.00??
- engine rebuild service?
- OS 1.20ax needle help needed
- ST45 Problems
- Super Tigre 3000
- Large 2 strokes...i wonder what could happen..
- Engine identification help 2 stroke glow
- Need a manual for older ASP 91 red head
- Connecting rod stuck on wrist pin OS 32SX
- Inverted Magnum 1.20
- deleted
- Need carb for original OS .91 Surpass
- running in sc120fs
- Slimline has temporary web site
- Magnum XLS .52A
- OS 110A question
- OS 1.20ax Crank question
- Idle problem Saito 72
- SUPER TIGRE 2300 ?
- Advice on getting an old engine running again?
- German K&B ?
- Open Rocker "British" Magnum 91
- My exhaust manafold broke twice on my Saito 100
- How to adjust FA170R3 Saito engine
- Saito 45 Mk 2 heart transplant.
- os 25 needle valve question
- Norvel .10 needle
- fuel in muffler
- Evolution 52 NX with OS 46 Muffler
- Tuning Nitro engines
- Best practices/fuel for OS FS-52?
- Enya 80XF-H manual???
- Enya 80XF-H Manual?????
- K&B .20 Sportster Carb adjustment
- Four stroking 2 strokes
- muffler exhaust
- Dirty Exhaust
- Horizon Hobby / Saito product availability dates- arbitrary??
- Moki Engines Thread
- New OS 4 strokes
- ASP full line available in USA via Nitroplanes
- TT GP-42 - Great Service from Ace Hobby
- Hangar 9 Alpha 40 engine choice
- saito 220
- Satio engine Question
- Diluting Pre-mixed fuel....
- Stolen engine: HP 1.20 Power Twin
- SAITO'S GOLDEN OPPROTUNITY SALE 33% off all engines
- Acidic Nitro
- 4-stroke Plug suggestions
- Saito Carb question
- Tuning a Saito 100 inverted
- os 95 ax baffle question
- OS Max FXi .46
- 7DV carburetor
- Thinking About Buying the Magnum XLS61A
- Tower Hobbies 40 FP
- DLE 30cc engine and 4 stroke muffler
- Magnum or Os
- It's Back...The OS 25FX
- Maden flight on Twist with MDS 68
- Revive old engines
- Super Tigre G-90: dies throttling up or down...?
- Moki 1.80 questions
- GMS engines
- Engine too high ... tank too low
- Which Plug ?
- axail 28spec 1s
- K&B 5600 .20 Engine Question.
- Magnum gp 40 carb
- TH .46 carburetor replacement
- original muffler
- HB .61 PDP
- saito 180 parts and service
- Saito 180 Question
- OS .95 prop and tuned pipe
- OS 4s leaking valves
- fuel tank problem
- Saito Bearing Failures
- MOKI 1.20
- New Four Stroke With Engine Knock
- Gears for on board starter
- Rear exhaust 91 glow options
- help!!! magnum 4 stroke!
- Ok, time to ask for help - ASP 52A-II needles settings
- moki 210 glo no go?? help
- Broken conrod in YS110FZ
- SAITO 56
- Need break-in recommendations for a vintage ST g60 series X pumped & piped.
- O.S. BGX-1 questions...
- Cant get sleeve back over the ring..
- Saito .30 carb settings
- Saito 1.50 Broken Crank
- Magnum 91 rebuild idle problems
- New Gas Enya
- Saito 180
- OS 61FX - Engine tuning 101 help
- OS 7 cylinder radial
- Engine bolt torque
- Saito FA-180 exhaust
- magnum 91fs bearings
- os .50 sx RING = bearing noise
- looking for open rocker o.s.. engines
- What size is this engine?
- OS 1.60 help
- Slimline Mufflers Gone ??
- 2 cylinder engine
- Saito engines
- Saito FA-180 nub on carb
- Magnum XL61RFS four stroke Bent Valve.
- Supertigre S-90 Troubles
- ASP FS61 midrange problems
- Sanye Engines
- Super Tiger 60
- Webra speed .40 ABC (old)
- Searching for OS 46 Sf & FX reviews
- Super Tigre 75
- KELEO CREATIONS Inc Contact details
- EVO engine front needle conversion
- os 120ax and slimline pitts muffler
- K&B .65 sportster break-in
- ST 2300 fuel tankage
- Help With Saito FA-65
- Is modification to front bearings needed?
- Silicone Coupling for Tuned pipe
- Lack of throttle curve K&B .61
- MVVS 21's
- Where to locate spray bar hole? .25LAS
- Enya 30 SS manual/instructions
- EVO 52nx / 60nx vs OS muffler bolt pattern
- Thunder Tiger FS-130
- Thunder Tiger Pro 91
- Question on Magnum .80 4 stroke
- Blue Bird .46 engine???
- HELP!!! who can name this motor???!!!!
- OS FSR Piston/Liner
- nitro & plugs
- OPS parts
- hb .15 model engine
- Aviastar 46?
- mvvs 91
- Saito 270
- OS .91 FX tuning
- OS91FX Advice
- OS Max .91 FX Rich in Mid-range Transition... one gallon through it
- O.S 15 FP Piston / sleeve
- MOVED: Glow Fuel
- Axial .32RR-1 exhaust
- How to repair an O.S Surpass III Pump
- ST 3000
- Question for all you Moki owners
- What to use to flush engine or what not to
- Prop shaft size, thread pitch?
- Old 91 Surpass FS rebuild help pls
- On Board Glo driver
- Fox Engines .45 sport engine help
- YS 110 EZ
- Tower Hobbies Engines – What happened with them?
- Crankshaft
- OS 90 parts
- OS 81a FS "drop in" for 70? It depends...
- Evolution 46nx problems
- Help I bought after market. Do I need bearings?
- wood screws? (mounting on test stand)
- How long should a Jato 3.3 engine last
- fa 80 (older)
- Satio FA-90T Thrust Question
- Vintage Super Tigre info??
- ASP 65 4-stroke help!
