View Full Version : Glow Engines
- saito flex muffler, what is the weight?
- Muffler for YS 61-R
- TT Pro 61 Muffler Extention/Adaptor
- Save this Pro 46?
- Need an engine for an Electrostick...
- Thunder Tiger 1.20 weight ?
- Info on the OS #72 Carburetor
- Awesome Tuned Pipe
- Engine cleaning question
- Powermaster 20% for 91FX and 55AX
- Muffler Extension
- Saito 1.25 knocks at idle
- Will LA .15 fit?
- Perry regulated pump OSGB?
- sundancer 50 fuel tank
- What Engine for a H9 Ultra Stick 60
- Saito 125 Pitts style muffler?
- Does a saito .62 run okay upside down
- Jett 60LX -V- Weston WE.50V1 P
- plug&rpm
- o rings for carb on magnum pro 45
- Running in Laser 150
- New OS 110 Four Stroke
- Magnum XL 52 repair
- QUESTION ON THE OS - FS .61 4-stroke
- Another Pipe set-up question
- Fox .45 rebuild. How?
- OS .60FP parts
- Super Tiger 45ABC Italy
- Difference between aero-and car-engine
- Tuning Problems
- Is it possible to replace a piston's ring pin?
- Are Four Strokes Dangerous !!!
- HOW DO YOU GET AFTER RUN OIL IN AN OS 70 SURPASS II?????
- OS 91 Surpass Pumped. Fuel tank Vent?
- Magnum XL-70RFS fuel
- saito 91 carb repair Question
- AP .09 Hornet
- Problem with an OS 46 AX
- Perry Backplate pump question
- MOKI /MARK 210 Manual
- Fox 50 carb adjustments
- New OS 110 Alpha
- Muffler Bolts & Gasket for TT Pro 40
- Evolution .46 Glow Plug Type>??
- Help changing bearing in ST S61K
- MVVS .61 &.77 glow engines?
- Flight time with a Saito 82 and a 260cc tank?
- ST Bluehead 60
- Hi Temp Fuel Tubing Help!?!?!?
- Using a smoke muffler without smoke
- OS Max 15 RC
- Internal differences between .60FSR and .61FSR?
- moki engine
- OS .61SF clone?
- No compression on ASP engine
- Want small, lite Glow engine .20-.30
- Evolution .46NX needle valve modification
- Klotz Techniplate oil
- what 3 blade prop for a ST g2300 ?
- Irvine 53 MK2 ABC
- 160fx max and smoke?
- ARE MY TWO NEW SAITOS RUSTING????
- Austrian CNC motors?
- OS 60 FP Needle Valve
- O.S. 55 AX muffler extension?
- Spark Ignition 2 stroke with glow fuel
- Satio 100 velocity stack
- Any reviews on the Thunder Tiger 4 strokes?
- Saito Price Increase?
- saito 100 exaust
- Magnum xl 46 dis-assembly help
- Saito 80 GK blown up
- Thunder Tiger Pro 120 - Pitts???
- Fourstroke- Side or Inverted mounted
- what kind of milage do you get?
- GMS 120 ???
- Super Tiger 46, Bull Ring, Italian
- DO YOU REUSE YOUR FUEL???
- Engine comparrison questions?
- snap ring failure,,,,,,,,
- Saito 82 Crankshaft diameter
- OS 91 FX pusher prop ?
- Is this a sign my engine is worn out?
- Deciding between OS 55AX & OS 65LA
- What's with all this Nitro?
- Mousse can shootout
- ST61 made in Italy
- MUFFLER EXTENSION MAGNUM XLS .15A
- Traxxas 3.3 question..help please
- OS 91 Surpass Prop Size For T.F. AT-6 ?
- saito stripped exaust threads
- Fuel tubing size for large 4 strokes
- Engines and humidity
- What use is a spacer
- OS 91 problem need advice
- ap 15 carb need help
- Macoy 19 and 35 worth what
- Webra 160 for F3A pattern plane
- K&B Ringed .61
- OS 91 fs running rich with needle closed
- RossiĀ“s releases
- Saito 100 Prop
- Best Pressure Tap Location On Tuned Pipe?
- OS 55AX
- O.S. 61 V Parts Wanted
- replacment carb for a mark 135
- Always remove the backplate!
- OS FS 30 to 91 which Engine?
- OS 91 FX rebuild
- OS FS 91 SURPASS
- OS Surpass 70
- Current Exchange Rates
- os fs 120 surpass @ ys 61-r long
- HP 120 Powertwin Questions
- OS 160 FX + custom header + MVVS pipe
- G75 Carb
- Pipe Setup Question
- K & B 65 screw/bolt thread type
- ASP 52 FRONT AND REAR BEARINGS SIZE HELP
- Saito 50 problems
- Saito 80 problem
- Super Tigre G61, G75, G90 Comparison
- O.S. 18 CV-R Factory Settings
- 2c vs 4c
- Evo 46 fuel?
- O.S. FS-91 Surpass II Tachometer Readings
- Review of the OS FSa-56 and FSa-81
- TT f91s 4 stroke dissassembly help
- o.s. 1.08 need higer rpms
- Parts for Saito .91 or .91 Saito for Parts! ??
- os .61 special edition question
- OS 25FP VS. 25FX
- fourstar engine
- ENYA 60 III T. V.
- 120 ax lean run
- Saito FA90T Conn rod wear/Engine Overhaul
- 4 Stroke Questions
- where i can find the rpm x power program?
- Cross-Flow with Tuned Pipe?
- SK .50 just arrived
- OS 1.10
- OS 61 SF "ABC" info needed
- about bearings
- Problem with Saito rocker shaft
- Evolution .46nt, glowplug alternatives?
- Os Max FS-70 Ultimate info
- Supertigre X15
- Old Perry backplate pump
- K&B 61 Need to know position of piston ring gap
- Should I change needle settings with different # glow plug
- 15% helicopter fuel
- Using gas/petrol in methonol instead of nitro
- Norvell Parts
- Evolution 61 NX
- Saito 56 RPM fall off
- OS .91FS Break-in
- OS .91 Problem
- Used Engine Advice
- Engine cuts out when throttled.
- Magnum 91 4 stroke parts in an OS 91?
- Saito 1.80 idle woes
- YS 140 Sport?
- Saito 182 Twin Plumbing
- ENGINE COOLING ON A BEECH T-34
- New Engines at I Hobby Expo
- Os 120 pumped engine and 2 line fuel system
- How Much More?
- Moki 2.10 problems
- Magnum 91 FS.. Running problems
- OS gemeni 120 connecting rods
- Hardwood mount strong enough for YS110 with just selftapping screw?
- slimline Q series pitts muffler
- hello air leak power loss?
- OS 61VF GS A-1 prop recommendation
- Priming a big inverted glow engine ?
- MDS ENGINE PARTS...HELP!!!
- WEBRA SPEED .91
- Thunder Tiger Pro .46 question
- Fuchs Aerosave
- RCV ENGINE OVERHEATED
- Does anyone recognize this engine?
- OS 61 FX Carb Question
- Help with Rossi Engine
- SuperTigre RR G-40.. Info?
- ASP .80 Four Stroke Manual
- Anybody with a os max sx 61?
- Saito FA90T Vibration at 1/2 throtte
- I should have bought the AX not the LA
- Propeller Worms
- Glow Engine Cleaner?
- OS .30 surpass opinions??
- Did i ruin my os engine....
- OS .91 FX Leaks Fuel
- Old OS muffler
- What would happen?
- no compresson on hb glow engine
- OS FS 120 E PROP SIZE
- OS 20FP TWO-STROKE PROP AND OWNER'S MANUAL QUESTION????????
- os with magnum parts
- Aviatronics Aviastar .53 from Sig
- O.S Wankel Engine Fuel Question. Not The type 2
- 4s performance - would someone explain?
- Could we convert this to GLOW?
- TurboHead Mufflers ?
- OS 61FS 4 stroke questions
- Morris hobbies
- fine tuning saito 90 twin
- YS engine questions
- Magnum 46 XLS...baffled
- saito 150 or 125
- OS 1.60 FX on Pusher model.
- 4 stroke, loss of compression after crash
- OS 61 fx heli head
- Ross twin 60 (Updated)
- Evolution .46nt adjustment questions
- prop for ST 2500 in 120 size warbird
- Engine temp.
- Saito 80 help !!
- Thunder Tiger 54 issue
- MOVED: Shelf Life of Nitro Fuel
- Novarossi .21 part compatibility
- Bisson pitts muffler on TT .61
- Engine repair shops
- Replacement carb for Supertigre .75
- Help! - Can anybody tell me what motor this is?
- O.S. .91FX muffler/ baffle question
- Best place to get a engine
- SAITO 125-FIVE MONTHS OLD-VALVE CAM FAIL??
- OS 120 FS E
- Bearing replacement / Saito FA82a
- ASP .75 2 Stroke engine?
- K&B 45 RIRE DF QUESTION
- OS 61SF compression test?
- O.S. 120FS engine
- OS Dia Star
- New to 4 strokes????? what do I need to know
- YS spark ignition engines
- OS FS 90 Missing back cap? Is open?
- jammin jpx 28 bearing sizes
- jammin jpx 28 rear bearings
- OS FS91 Runs Very Hot?
- Puzzling 4-stroke issue (SC 30FS)
- 182 SKLANE w/ASP 61 HELP!
- OS 160FX, VP-30, and Slimline Pitts Muffler
- Piping exuast away from airplane?
- Hot spot on piston/head
- OS 61RF Engine Rear Bearing Removal
- Saito 72 or 82??
- , ASP 120 4stroke
