View Full Version : Glow Engines
- Timing OS61 RF-P
- A question about Magnum 91 4 stroke?
- Tightening a cowled 4 stroke muffler.
- GMS Engines
- Old .61 OS MAX-H Gold Head - make muffler?
- YS 120 Prop throwing problem
- Moki engine parts
- OS 46 AX prop's
- OS .46 AX Muffler flyoffs!
- Screw size for 40 size engine
- Saito 72 - 90* Bend for Muffler Pipe
- Saito 180 no pump solutions? HELP
- K&B 7.5 RE ducted fan
- twin engine for nosen 40 champ?
- Saito 72 Crank Breather
- im Brand spanking new (with OS46FX)
- After-Run Oil?
- YS 63S ARRIVED TODAY!!!
- help with ENYA 120
- Modifying 4c Engines
- Best method to determine thrust?
- Magnum XLS 52a Muffler ?
- does the SAITO engine powder coating affect cooling?
- Break in ringed engines
- Prop spinner size for Saito 72?
- Anyone have any info yet on the OS 70fs ultimate?
- OS 120 Surpass with Pump
- Engine repair
- A.S.P. 1.08 Red Head Questions.
- 91 SAITO
- The oil test.
- Saito .56 or os .52?
- Where do you buy your engines from?
- my Sour Saito
- What is the Magnum XL25 like?
- Robart R780 & Saito 325R5D Video Clips
- OS40FX Peeling?
- Moki 1.80 + Perry Pump
- Looking For K&B Greenhead 15 R/C
- Great Planes Aluminum Spinner help
- Glow Driver for Saito or OS 120?
- YS 91 vs YS 110
- MDS Carb question
- OS 70 PUMPED ULTIMATE ENGINE
- prop size & needle valve settings
- Running a Saito 1.20 inverted...any probs?
- monting engine with crank case cover bolts
- ASP 61 FS valve clearance
- Rossi RC80 : anyone know this engine?
- Carburetor Help
- Old Fox Hawk 60 for Parts
- Prop won't stay on
- Best place to buy castor oil?
- Saito 100T throttle linkage
- What size fuel line for YS 140
- Pitts Style Muffler on OS 61 RF
- Saito 180 - need ideas for fuel line plumbing
- Saito FA65 Keep it?????
- OS 61 FX, super tigre 91 or TH 75?
- Fox 60 Eagle III Dead After Throwing Prop
- Engine Storage
- Magnum 1.20???
- Wich four stroke to buy?
- Muffler extension.
- What is the Difference in YS 1.20 Models?
- Supertigre G51 Cracked Drive Washer
- TT 46 Carb tune needle adjust HELP!
- OS61FX Excessive Compression
- OS46FX and fuel tank pressure
- Moki 2.10 settings
- 91FX problems....help!!!
- Muffler Extentions?
- OS Max 25F
- Norvel Big 074
- cline regulator vs. iron bay vs. perry pump
- OS Max H60GP break-in and fuel type
- Thrust calculator
- ENYA 11CX nitro - tune, break in
- THUNDER TIGRE HOME BREW FUEL QUESTION
- Now a .56 in a 40 size case from Just Engines
- Where to get header pipe for an old rossi 21
- Toothbrush vs. Piston Stop
- Supertigre 75-need special muffler
- 45fsr info?
- How do I tell if my crank bearings are bad?
- another 4 vs 2 stroke power question
- GMS RUNS RICH
- Moki 1.80 VS OS 1.60
- OS 70 Surpass
- PLease help !! need a part for an old OPS!!!!!
- OS70FS Detonation
- Need Some Cowling Instruction Please
- Enya 40 4-stroke parts, where do I look?
- Mid range problem UPDATE... SOLVED
- Prop driver/hub
- which irvine engine should i buy
- more help with breaking in
- Silly question I was asked but no clue why
- Stoopid Saito questing number 1
- ULTIMATE "40" SIZED ENGINE
- Picco .60 , How long ago ?
- Upside Down Saito Hydrolocked
- Suggestions for Prop - TT F91S 4S
- Need help getting valves off an OS .91 FS
- just ordered a Magnum .91 fourstroke
- Help identifying an engine
- whats the crankcase width on a .45 fsr
- Saito 60 twin
- Saito .30 tuning
- Saito 90 twin
- Help and advice with YS45
- 4-Stroke Cam Shaft Leak
- New Norvel .40, Irvine .39, Webra 36, or???
- OS 46FX Prop Question
- Enya VT 240 Twin F/S
- low compression 61 Magnum 4 stroke
- royal engine
- OS 91 4 STROKE
- OS 46FX help
- OS.91 Surpass Engine
- hp goldcup engines??
- os .25fp carb
- MOVED: Coleman lantern fuel
- Novarossi-50 Blue-Head?
- K&B Screamin' 48 Muffler?
- Magnum .80 Repair
- NEED HELP! can anyone tell me who buys&sells old engines
- TT's GP-07, a good deal?
- OS .15 FP BREAK IN
- YS 63 in a FuntanS - throttle servo config
- New Saito 1.50
- Fuel for a Bully 35
- OS 91 fuel & prop size?
- Irvine 40 Props
- Mounting Carb
- Super Tiger in China
- SAITO out-of-USA Support
- YS 63 producing dead sticks
- K&B .28 help
- Old fox 78???
- New GMS Help
- plumbing question for YS
- YS 140 Mufflers
- Tower hobbies .46 dies during flight? help!
- Very strange lean run!
- just ordered a tt 36, what do I need to know?
- 4 stroke glow plug on large 2 stroke engines
- Magnum .91 Four Stroke --- Buy It?
- how to time 4 cycle engines
- info on OS Max 50 FSR
- Fuel tank pressure trouble
- K&B .46 engine
- Saito 72 backplate
- Regular fuel line use with perry pump
- webra .61 silverline
- TT 61 hard starting
- Need specific idle setting for Magnum 1.08
- OS 46fx engines for 85.00
- ID an Engine
- Standard Muffler for MDS 2.18
- Thunder Tiger GP40 Manual
- mds 210 props?
- MFA 61.
- Best Overall .15 RC Combat Engine
- Making Exhaust for 1.60 Twin?
- Nelson Glow driver HELP
- Tank to carb placement
- Maybe More Dumb TT F91S Questions
- glow plug
- Perry Pump
- Webra's muffler fits GMS, so...
- Horizon Hobby Fuel Dots
- OS 25SF keeps dying after a few minutes of flight
- Webra engine
- How do you warm up your engine?
- Macs header for OS.25FX?
- Muffler problems Saito 180 and 150
- The Enya 1.20R vs. the Saito 1.20
- throttle expo
- HB 61 Muffler
- New 16 oz. Saito .82!!!!!!!!!
- Enya 40
- Saito Flex Muffler
- Followed your Saito advice on break-in! :)
- Saito 1.80, great runner, just leaks...help!
- Irvine engine problem
- K & B .61
- GMS 40 2000
- Bearings with Brass retainers, What is your opinion???
- New needle valve for OS 91 FX?
- May lose field due to noise. Need Advice and muffler suggestions!
- new magnum .52 4 stroke exhaust valve leaking?
- Rossi parts
- Stewart Maximizer Belt Reduction System
- 1.00-
- Enya 1.55 Inverted
- Impeller jet?
- Saito 100 cylinder replacement
- GMS 40 ABC 2000
- Saito 150
- Who makes a good onboard glowdriver?
- Saito 150 bearing sizes?
- YS ENGINES AND FUELER VALVES
- Inverted Saito 91 Mounting
- magnum 46 settings
- Trouble - GMS 120
- Hi Temp Muffler Compound
- General Engine questions, 4-cycle beginner
- OS FS70II valve clearance adj. kit
- Thunder Tiger 42, how much shaft play???
- Macs muffler no power gain on .46fx?
- removing the shims in a magnum or gms for more power
- General needle settings on YS63
- Anyone own a Saito FA-450R3D
- 1/5 scale pica waco
- Poor midrange on ST3000
- 4 Stroke compression leak - disassembly no good
- How low have you got your idle? (only 2-stroke please)
- What Should the Head Temp. be on my OS 46AX?
- Correct prop size for the XLS .46??
- Air bubbles from cline regulator
- Power of a Fox 40bb from the 70's??
- bearing question
- Got a Rossi? Hold on to it.
- New TT 90 Pro
- ST 2500-2000 inverted muffler
- New Saito-82a vs. YS .63S
- blow by improves performance?
- YS 1.10 VS Saito 100
- Webra Speed 91 parts
- my OS 40LA
- Saito 65 issue
- HELP! HELP! HELP! Saito 1.50 problem
- Does Webra still make 4-Strokes ?
- Horizon Hobby Dumps MDS Line?
- Smoke Muffler
- shim THE HEAD?
- Magnum .91 4 Stroke
- OS 61 Prop Size
- Carb suggestions for TT GP25?
- I have an old OS 40 SR, HELP!!!!
- Stallion .35
- MDS 78 PRO - TOWER .75 - TT.61 PRO - OS .61 - WHAT`S THE BEST???
- Saito 150 slow to idle
- back plate interference, saito 80
- Saito 30 exhaust too short
- Pitts Muffler...
- Saito 72 w/3-blade
- NEED HELP URGENT TT-120 PRO
- Looking for engine mounts
