- 7C TX Modes?
- T6XHS v/s T6XAS
- 9ZAP WC2 Automatic System Shut Off
- 9c timer volume
- Dual Elev Servos w/ 8U Super
- reciever servo connections
- Receiver Repair
- Futaba 3151 question
- 9C charge with Triton charger
- 9C TX crystal change (Not for NA use)
- Futaba 7C PMIXing HELP!!!
- Another 9c Programming question... Throttle delay on another channel
- 7cap programming
- Skysport 4YF
- Couple of Buddy cord questions
- Futaba 6xas batteries--Question ?!
- Transmitter specifications?
- S9250 Digital Servo's in GP Patty Wagstaff Extra300s?
- 3pk mixing
- 9Z "LINKING" Question
- Slight Radio mishap. Help?
- 9VAP Mixing
- Program Mix for Dn Elev at Throttle Idle in 9C
- Can't get 140 % End point on 9 CAP Ch 7
- noisy rudder servo
- Transmitter Crystal Labels
- Specs on Fut servos
- trainer cord on 7c
- 8 U Rudder pot
- FP-R127DF vs. FP-R138DP Current Drain?
- 6XA Problem
- Trouble programing 8U with Futaba Gyros
- 7CAP Manual
- Compatible TX module for 8U
- 9206 jittery, 4.8 volts with dual rx packs
- 7CAP - lost endpoints after timer setup
- futbab skyport 6
- Futaba 12 channel radio???
- a better throttle ratchet.
- Are all Futaba PCM channels 1024 bit resolution?
- 9CA trim doesn't function on slaved ch. 8
- FP-T4NL "buddy cable" for FMS
- Crow Feature with 7C?
- Question for Futaba
- 9Z newbie questions
- Servo Reversing
- Fataba Skyport4 versus electric airplane
- Synthesizer Module Schedule for 9CxP
- T6xa Dual Rates change trim
- For Krysta Thank YOU
- Redunbant Batteries
- Futaba 9CAF Radio Only one Aileron works
- Futaba 7C with Hitec Rcvr ?
- How Do I Cycle 6XAS Transmitter NiCad?
- FP-T8SG question
- Modify Futaba Y4F to Mode2
- older futaba tx question
- 2PCKA Problem
- Safe voltage for S9150 and such?
- trim problem intermitent
- T6XAS tune-up question
- "crowing a ultrastick 40"
- futaba cap9
- My 6EXA throttle stick is stuck
- Question for Bill Baxter
- 3PDFX Box size
- 9c throttle setting
- My 6XA dosnĀ“t transmit anymore
- Field Force 9
- R149DP 40MHz and R149DP 41MHz
- FUTABA 3010's and NIMH BATTERIES????
- reversing a single servo using a Y conn.
- Broken Case
- R127DF w 9Z WC2 Synth?
- Broken switch lever
- question on batteries and switches.
- 9C 2->6 mixing?
- 9zap changes trim with D/R WHY?
- glitch prevention advice please
- Futaba GV-1 Sensor DOA
- Servo specs different your site vs. data on box What is correct?
- Futaba Rx FP-R103F
- 9C, retaining model memories when battery out
- SHIFT SELECT ON 9C?
- 9C set up
- Futaba 7CAP manual
- 3pk sceen blank
- Futaba 9CHP question
- Tx module cases
- Servo S3305
- Futaba Receivers/Crash
- hello skysport 6vh
- Hitec servo jittering with 9cap
- Dual Batteries?
- Reversing one servo on split elevators 8uafs
- futaba TX hitec RX question
- 9C split elevators
- Receiver question.
- FP-5NLP and FP-S130 Questions
- Newbie question about 6XAS__CHARGE
- Need help changing from Airtronics to Futaba wiring
- Futaba S9350 Digital Servo Question
- futaba 2 pl computer radio
- Ensuring Frequency Band
- T6XA glitching
- Futaba 9Z WC2 and JR digital servo
- Questions on 7CAF
- 8U Super switch programming
- 9ZWCII
- Super 7 question
- 9CAF what receivers can I use
- Flight Conditions
- Trying to find out CHANNEL on my Tx.
- 9C and 138 receiver
- HI Krysta...T6XAS Flap programing difficulty
- Radio Glitch
- 9Z problem?
- 9C channel 5 issue
- Futaba Hi/Lo Band question
- Replacement toggle switches for FP-T7UHP
- 9152 digital servo
- T6xas flap/elevator programming question.
- changing channels
- new to 9WC II and need help!!
- 9Z (or other) manuals in Portugese or other languages?
- Futaba Synthesizer for 9C
- Futaba T4VF and RC simulators
- Hi torque servo?
- 4 ch ElectriFly Rx
- Nexstar Transmitter LED's
- Transition 9c to 9zapwc2
- S9001 servos now dual BB?
- 9402 plastic gear set
- 3FR trainer cord?
- R149DP Receivers
- 9C to 9C-WC2 up-grade?
- Can I change my battery to a 6 volt 5 cell pack?
- MOVED: 9ZAP Synthesized, What Receiver?
- 9zaps verses 9zas wc2
- 9ZAP modules
- robbe futaba fx14/fx18
- Futaba Receiver + Generic Crystal
- Futaba 6XA Programmable mixing
- 6v NiMH without regulator
- 9C throttle EPA settings for e-planes
- 7uaps Daul rate and EXP errors
- 9 ZAP Problem.
- How to set Idle Down with TWIN Engines?
- Futaba T8UHF Hover Pitch Knob
- 7U Replacement Gimbal pots
- failure 149dp??!!!!
- 9z beeps
- AM Radio
- needs hints on setting up the futaba 9c for 3d aerobatics
- Module Change
- 9C OWNER'S MANUAL ADDENDUMS?
- Futaba Tx bandwidth
- 8uafs silver face plate peeling
- Transposed channels on T6XA?
- s9206 plastic gear availabilty
- Charge Rate thru Transmitter
- FUTL8910 Synthesized Module - release update?
- Need ideas on setting up Flaps on Warbird using a 9ZAP
- BYPASS DIODE
- Futaba 6XAPS and 6XAS
- Futaba S3305 Servos for AirPlanes ?
- Throttle Needle Mix - 9CAP
- 72 MHz Channel Distribution
- 4YF battery leds
- S9253 Servo Question
- Differential aileron
- Defective ZAP
- LiPo battery voltage compatability with Rx gear
- 9CHP programming confusion.
- switch assignment
- Differential on Ailerons with 7UAFS Radio
- futaba?can fly helicopters too??
- Is my Rx hi band or lo band ???
- AM Conversion Module?
- 9C mode change (mode1 to mode2)
- BROKEN TRIM SWITCH ON 6EXA
- Worth updating AM radio?
- Un-safe switch design in the Futaba 9C
- R138DP reciever
- Retuning a receiver?
- Two different questions. One servo, one rx
- 3PK HRS and non digital ESCs
- 9CAP Throttle Curve
- FUTABA 6XAS Questions
- 9451 Applications
- new futaba servos
- Radio Set up in H9 33% Sukhoi
- 50Mhz
- 9C idle down adjustment using throttle trim
- Futaba 6XAs plastic covers
- S9151 digitals
- TX antenna for 9C
- 3001 Servos ?
- 3pdf question... is my radio fried?
- mode change on 9Z
- fp-tk fss module and micro rx
- MOVED: Futaba S9152 Servo Questions
- 6EXA and dual elevator servos
- 9C Elevons with 5 channel receiver / delta wing
- Buddy box for T6XAS
- 9C Antenna - What is the Fut Part #?
- Replacement for broken switch on 9Z transmitter
- 9C Trainer Setup Problem Please Help.
- S3103 vs S3108
- problem with futuba 6exa
- Changing Rx Freq.
- Buddy box control switch
- throttle curve
- TX/RX Compatibility
- MOVED: Futaba Servos
- 50 MHz synthesizer
- Using 9C sliders to change top end rotor pitch on heli
- I don't get max throw
- 6 EXA diode question
- FUTABA 12 CH. WHEN?
- Please Help
- Campac 64k
- Dual rates on the throttle channel
- 9C + Spirit 100 & 550 Can
- Is A Regulator Required for 6v Batteries
- Changing Module on 9C
- 9CAP PCM data transmission. *Binary codes & signal etc.*
- 6EXA Programing/buddy box
- Where are the 9351 servos?
- Polyswitch for 9Z?
- TX XTL (FUTABA FP-T4NBL
- Noise Traps/Chokes
- Futaba 6EXA "Buddy box"
- Adding Charging Connector to Futaba Transmitters
- Servo options
- MOVED: Webra Nano S6 Rx
- 9C butterfly/crow/throttle cut?
- MOVED: Futaba J to Airtronics Z
- Futaba 9C GLID2FLP v-tail bug?
- Servo s3050/s3151
- 50mhz to 72mhz conversion.
- Two batteries on large aircraft
- Idle problems
- fried servos
- DSC receiver port / Futaba R149DP PCM
- 9VAP question
- Programming an 8UAFS
- How to Idle up on 9C
- 6exa problem
