View Full Version : Gas Engines
- DLE 30 vs. RCGF 32
- DLE 30 ???
- DLE55 Prop Shaft Removal
- carburetor infomation
- Which engine vibrates more! Gas or Glow 4 Stroke??
- BME 2.8 Question
- CH IGNITIONS ?
- Would a 24x8 prop put too much load on a DA-50?
- Ignition hall sensor test kit
- DA/3W/ZDZ RCexl ignition conversion kits
- canisters vs. stock mufflers
- 3w 240 prop size
- Muffler?
- G20EI help
- Flat Six 225cc
- RCXel Ignitions all the same
- Vibration mounts or not?
- Engine mount for DLE 30 question
- Brillelli
- Need help: 15 cc RCGF idle setting on Tx
- DLE 30 high power with throttle closed!
- H&K spring starter for Q35
- Twin 60 CC
- G26 - Which Oil and Prop ?
- 30-40cc For Speed
- another oil ratio question
- RCGF 40cc twin
- a lean mid have do you ??
- JC 28cc exchange program
- ZDZ-180 on Pro Flow Canisters
- Needle bearing of dl-50 fits da-50?
- To big? or not big enough?
- Gasoline Rotary Engine from Thunder Tiger NEW!
- New (to me) internet myth
- MT-70 exhaust options
- DLE 55 that won't start
- CRRC GP26R Gas Engine (rear carb)
- ***SYSSA***
- zenoah G-38 smoke, and spitting oil
- DLE-30 tune chasing issues
- Does a large diameter spinner affect prop selection???
- Manual for a WJ 64 carb
- Zenoah G-62 Run ?
- DL50 idle issue
- DL50 running issues
- Carburetor improvements?
- XYZ 20cc?
- G62 wtih Purr Power
- DLE 20 timing
- DLE 20 timing
- Need rear faceing carb linkage help.
- Zenoah G20 in a TF P-47?
- Which of the current low priced tachs is best ??
- Those of you wanting 40-60 size gassers: HPI has answered your call!!...wait, what?
- Flooded engine cures...
- Something to share with you all
- Saito FG Series 4-Strokes-Cold Weather Running
- Starting gasser after long winter
- ignition
- DA-50 prop extension
- fuel line
- DA-50 clicking noise - Video included - Update II
- QUESTION: does anyone think there would be much demand for an inexpensive magneto rc engine
- Is it mandatory to mount Gas Engines Inverted?
- New ZP Engines from Horizon
- canister or muffler
- Ign voltage regulator
- DLE20 Spinner adapter
- Propeller Thrust Estimator
- Engine ID help requested (was told Quadra 75 is a Sachs Dolmar 4.2)
- Servos in the engine compartment?
- rail mount 30cc motors gas
- Need Help!!! Tygon vs Viton
- C&H ignitions
- Help mounting DLE30 in Slipstream MXS
- hooking up choke
- Fiji Water Bottles for Fuel Tanks
- Prop/Spinner Balancer???
- Gas engine for a four star 120
- PTE-36 3 blade prop size
- using Tygon tubing in exhaust system
- Bisson pitts muffler on DLE 55 smoke.
- align starter
- ZDZ 40 stumbles
- New to Gas'rs
- Quadra 150
- Can Anyone Identify This Gasser?
- Which oil do you use?
- Who has a Roto Motor?
- Do You Think DLE Will Make a 40cc Engine
- Best 15 cc gas engine...
- Name that Quadra! - Test your old engine IQ and help me at the same time
- Sensors
- Motor mount for DLE 20cc
- Gasoline Clunk tube?
- ESM 74" Corsair Engine
- Hall sensor question ?
- BME 44cc Muffles ... Where ... ?
- First Run Help / DLE 30 V2
- DLE-55 on White Gas
- Lightest, most reliable ignition on the planet, Guaranteed!
- installing Gas engine stuff in plane
- New gas engine to think about
- 3W-42i prop set up
- DLE55 thread rotation
- DLE 20 Installed in VQ P-40
- Thor 45cc need suggestions for ignition
- What Kolbenschmidt-based single is this?
- OPTICAL KILL SWITCH
- "Stihl" fuel line - seems flexible - does anyone know anything about it? Pix included
- Idle problem
- Final setup details on my new gas plane!
- Any thoughts about these servos for Gas planes?
- cdi intion
- Best Way to Install Crankshaft Bearings?
- 4 stroke gassers
- Repairing gas engine sparkplug cable
- Smoke System
- What aerobatic prop DA-60?
- Remote engine kill - Switch or Choke
- Gassers-Do They Have to Be Inverted?
- ZDZ80 Ignition Conversion Question.
- 3Wi Ignition
- All day flying on RCEXL on g20ei?
- whats this for?
- Primer on Gas versu glow?
- Would gas engine's influx obsolete glow engines?
- WT 813 Syssa Carb Won't Pop
- DLE 111 demisions-plug to plug
- WALBRO Metering cover upgrade CNC
- Gas tank question
- Fuel tank size?
- Taildragger RC introduces the CRRC PRO gf55cc TWIN
- maybe stupid question but
- DLE 30 Bisson Pitts Wrap Around trade for J'Tec
- New OS 33cc Gasser..any reports yet?
- Source for Pennzoil 2 Cycle Air Cooled Engine Oil in Qts?
- Two engines with one tank?
- Wiring a kill switch on a Zen. G62
- Walbro for DLE20
- MTW header needs welding
- MOVED: need help! Manifold / exhaust qestions
- Favorite optic kills?
- DLE55 won't restart
- Gasoline Fuel tank Stoppers
- RC-XCELL IGNITION RESISTANCE
- Glow to Gas - How Do You Figure It?
- At my wits end with a Zenoah G20ei.....
- DLE-20 fried a piston...
- Taurus engine
- Any engine builders/machinists on here?
- DA60 tuning
- rearmounted carbs.
- Q about gas fuel
- Reed Valve question
- HH 26 cc gas engine
- DLE - 55 Clockwise Rotating Engine
- G-62 cup mount
- DLE 20 gas tank
- Bennet Built Engines... Anything going on?
- DLE55 Rear Exhaust Conversion
- Need some info please; saito 150 glow VS dle 20 gas............
- G26 vs ST 3000
- Varible pitch prop development
- RPM expectations with 3 blade on 3W 55i
- NGH GT9 9cc Gasser!!!!
- DLE 55 Carb Question
- 1300mAh LiFe sufficient for ignition?
- 3 And 4+ Cyl. Engines ?
- dle 30 smoke with canister
- Ignition shielded wire keeps braking
- DLE 20 Ignition & life4 battery question?
- Zenoah G62EI intermittent spark, please help!
- Which 4-blader for G62?
- Best muffler for DA 85
- G-23 spark plug gap setting
- inverted muffler for G-23
- Typical Fuel Line Size? 50cc
- GT-80 and DLE111 Mufflers
- DLE 20 on pipe or canister
- Do Carbon Fibre tuned pipes, in fuse, have to be insulated?
- Gas tank question
- What is the longetivity of carbon fibre tuned pipes?
- DLE 30 for a 4 star 120 Okay?
- Amazing V12 engine
- Looking for tuned pipe DLA56
- Idle problem on CRRC 26cc GFi gas engine
- Help for Ryobi 31cc Ignition Please
- Tubing hookup
- plastic carb spacer too long
- 3W 75iTS question
- ZDZ 80 B2 RV-L question
- MOVED: breaking in a new 3.3 tmaxx engine
- DLE engines shutting down on high G manuvers
- RCGF 20cc : beam mount vs rear mount
- Fuji-Imvac BT-50SA
- Zenoah engines
- Carb sizes
- Headers
- Ignition Ground Wire
- Thrust table
- JC EVO Engines
- Precision Eagle 5.8 GLOW to Gas possible????
- ZDZ 90 or MVVS/Evoluton 80 ?
- 3w 100 rcexl iginition replacement Help
- How to quiet 28cc gasoline engines
- Gas engine on escapade 60
- DLE55 - Which 3 blade 18" prop?
- G23 bearing removal
- Why Gassers are more addictive or better than Glows e?
- Engine Test Stand For a DLE 20 and 30?
- Rear Intake reed problems
- How to plug a Zenoah G62 Bennett smoke muffler?
- Attaching Tygon ?
- Fuel system setup
- OS GT33 v/s DLE30
- DLA-56 front seal
- DLE 30 vs DLA 32 vs AEROVATE 32
- 4 BLADE PROP FOR A DLE 30
- Ok , Ive read the Sticky , Still got a Question .....
- twin spark engine and opto kill
- Buying Opto kill switch?
- Stinger 120 gas engine choices.
- Installing the opto kill device
- Dubros round nose tank has less useable fuel
- DLE30 popong during flight
- RE:Christmas/Holiday season discounts
- Ripped Off
- Hub on DLE30
- I need a G23A crankshaft .
- G-23 prop hub removal
- TBM's PTE-36R 36cc Rear Exhaust Gas Engine
- 3W 80 B2 parts
- Dle 55cc Floating Mount
- G-23 idle issues
- ROTO25V or DLE30
- Tony Clark TITAN ZG 62PCI?, no more, thanks!.
- G62 Vert Shaft with PULL Start (620RC ?)
- RCGF 20cc rear carb.
- Ignition Cap Resistor
- Digital or Analog Throttle Trim
- "blinged out" gas engine heavy duty starter
- Dle 20cc and seagull extra 260 .90?
- New DLE 55 always dies on taxi.
- New for welding
- In need of some help!! thank you
- G38 spring starter installation??
- Fuel Barb Soldering Help Please!
- Saito 57T gas twin
- the best prop dle30 piper 1/4 ?
