View Full Version : Gas Engines
- DLE 30 Idle question...
- DLE 20 IGNITION QUESTION
- Hot weather tuning
- Do you have a China made engine you no longer use.
- pop pop-pop pop pop-pop DLE 20
- DLE 55 stock muffler vs wrap a round type
- RED LION engines, how are they?
- DLE 111 Ignitons, who has em?
- Turnigy 52cc...good?..bad?
- DA-85 VS. the new ZDZ90, need info>>>
- Sach 4.2 70cc n prop combo...
- Zeonah twin
- Choking before using the spring starter ?
- JBA 15g operating temps
- Location of batteries for DLE 20
- DLE 20 in Top Flite Mustang-Over heating, help
- DA-85 Upgrade?
- Giant Scale DC-3 without engines (pics inside)
- What cans for a tmm106
- When to replace an ignition
- n/a
- To Wood Or Not
- DLE 20 Header and Can
- 6.6v servo operation
- What engines are these ? (Bizarre)
- Newbie ignition question
- Onboard Engine Starter?
- Any Mods for the MVVS 58?
- NGK plug
- RCG 26cc - best used fuel ?
- SACHS 4.8 TWIN
- MOVED: ASP RADIAL 400 5R
- Bill Carpenter and the Goldberg Award in the AMA mag
- Engine Choice for the Novice
- Anyone running a First Place Engine?
- K & S Fuel line OK for gasser tanks?
- Thanks, Pe
- tach
- Menz 22x8 prop - Can't Balance
- Zenoah GT80 needs help- Who is the best?
- Filling the tank.
- U.S. - 41 Prop bolt ?
- DL-50 Reed Valve Wear Question
- Zenoah G26 hand proping problem
- ST2300
- My Dream Gas Motor, A Twin DLE 40cc
- 3w in-line 150
- DA 120 Cannisters (Which One and Why?)
- reed valve mounting screw RCGF 15
- g20ei, good/bad/best place to buy
- Q52M
- Bill Carpenter honored
- Mounting the Saito FG20
- FUEL LINES
- Zenoah G260PUM will not start.
- DLE 55 Idles fast after flight
- Needles working loose - help!
- Who needs JC engines Area 51 and 102 warrany repairs
- Saito Gas Engine muffler maintenance
- Can anyone straighten crank on ZDZ 80?
- rod noise in a new Braveheart bh50 50cc
- Running up to full throttle ?
- A new Zenoah 20cc gas engine.
- HELP Motor Muffler
- CH Ignition-Hall effect sensors
- JC 60 FLIGHT VIDEO
- G20EI DOH !!!!
- DLE 20 & 30 ignition module
- New statement from JC ENGINE power co.,ltd
- What engines are these ? (ZENOAH clone)
- single battery possible?
- G-26
- DA60
- Kill Switch Set Up
- DLA 56 carbuator ajusting problem
- Leaner or richer when using smaller prop?
- MOVED: 31cc Ryobi, hard starting and dies within minutes.
- G-45 Fuel Line?
- prop failure
- ignition module question
- NGH 17CC Petrol Engine
- Nitro Gasoline Conversion
- Muffler questions
- SV26 Gas Engine Issues
- DLE 20 better exaust
- 3W 220 Four Cylinder Engine
- LOGGING IN NOW
- how long do you keep your 2 stroke mix?
- Anyone tell me what these are?
- Fugi 64 hard to start
- rcs 215
- Pouring R/C Gasoline Into Your Car's Tank
- CANT FIND PARTS!!
- Garolite (G-10) Epoxy board substitute??
- Walker 4.2
- SPARK PLUG GAP
- What is it???
- U.S. - 41 / ( Quardra ) Choke ?
- Best Place to Buy a DLE
- DLE 170 headder problems
- dle 30 with tuned pipe on fun fly
- DLE111 Hard Start
- New to building rc engines
- ZENOAH GT-80 PROP, THREE BLADE
- Let's call it a senior moment
- DLE222 Starter System - The Project
- ZdZ 40 a bit tight at TDC
- Removing ZDZ 60 prop hub
- Starting a ZDZ Super 80
- Small gassers not worth the investment!
- Odd Carb Problem= DLE 30 side carb
- Zenoah G45 Electronic Ignition Conversion
- Spring starters ? ? ?
- DLE 85 ??
- Instant cloning...check this out !
- SPE 40 Rear housing
- Gas Engine Parts and Repair
- Spring in DLE plug cap
- Ignition for Brison 3.2
- Avenger 60 synthetic oil
- I found the Gas airplane I want....
- DA 150 carb is spitting fuel
- Prop for D&B 3.7
- Numbers for a RCGF 26
- RCG 26CC spinner size ?
- Canister to tunnel clearance and cooling
- Bill Carpenter
- RCG Gas Engines
- Field gas can question
- Fuji-Imvac is history
- Evolution radial engine?
- Clear Tanks for Gas Engines
- 3W 28i Information
- Looking for a little more than a DLE 55
- Throttle control problem
- DLE 55 Issues
- YuanDong engines?
- JR G500A - I want one
- OS CM6
- Ralph Cunningham rcignitions
- U.S. 41 ?
- RCG 26CC gas engine from HOBBY KING
- Question for the Walbro/Zenoah Experts
- DLE plug cap/plug mod...yes/no?
- Clunk line too flexible?
- Where to tap for smoke DLE 30 stock muffler
- DLE 20 idle too fast
- Zenoah GT-80 Twin prop choice for a warbird
- Fuji BT24 Hard Starting
- DLE 20 Surging during throttle servo movement
- NEW! DLE Muffler Silencers at TBM!
- Pinch method for fuel mix setting/or?
- SV Gas 26cc Engine issue
- EME 55 DLE's new Cousin?
- Glow to Gas Conversion Chart
- carb questions for chain saw
- CH Ignition Spark Plug Terminal
- Using servos with nylon output shafts in a gasser
- Wanted, DA 100l or Dle 111
- DLE 20cc
- gas engine choke???
- Never thought it could happen to ME !!
- Found a nice air filter
- rcexl optical switch
- Magneto Ignition Ground
- READING THE SPARK PLUG
- Ignition Notes
- DLE 20 muffler mount dimension
- DLE 111 Warranty Issue
- Muffler keeps falling off
- Looking for Walbro WA125 carbs
- anyone care to read my spark plugs
- Black wire syndrome and gas ignitions.
- NGH GT 17
- Fox 4.2 runs erratic
- Thanks for the Stiky Notes
- OS GT33 33cc gasser
- DLE 20 4 blade prop?
- 3 x DLE 30's - cranky
- G62 needs help
- Parts that don't pass muster?
- DLE What?!?!
- Starting Glove
- DLE 20 Twin Engine
- DLE 111- First Run-I'm impressed
- DLE 30 at 12 or 2oclock
- Antique: Broken G26 plug
- Happy Father's Day
- Evolution 40 GX Horse power/thrust information??
- Running without muffler
- Gas Engine's RPM range
- can I switch oil from synthetic to penzoil?
- Holy Crap!
- Where the heck is the Zenaoh 30cc Rear Carb??
- Rubber Spark Plug Boot Assembly
- DLE 20 carb
- Prop Size
- Backfire, Broken Crank
- Tired Old Man or Antique
- Small 3 Pin Deans Connector
- HELP Please!!!!!
- Zenoah Twin size question
- carb setting question
- DLE 20 engine mount?
- Exhaust mounting dimensions DLE-170 vs DA-150
- MVVS 26cc Pipe on Zenoah/Brillelli?
- Z 20 cc Engine
- DA-50R vs DA-100L Vibration
- Prop
- Needle Extenders for Walbro Carb?
- 50cc-ish reasonable $ twin? ISO engine for 12' Tele
- Reqt: Pics of AW YAK 120 with DLE30
- Plane for DLE 30..nonaerobatic...ARF?
- DJ80 from sds hobby or amr hobby
- Please help, tuning question
- Went cheap. bought a DLE 20 and got burnt!!! UPDATE!
- Da 85 or adz 90
- Da 85 or zdz 90
- Stihl HP Ultra-Must be good stuff.......
- DLE 20 or 30 on 90 size Joss Stick
- Ignition battery choice CRRC 26 engine
- us engine 41 electronic ignition conv.
- NGH GT9 Yellow Heli Head ?
- Mounting DA-50 washer type, size and grade?
- 3W-75i Canister Help
- DA100-Spitting problem-Is this normal???
- G-38 crank needed!!
- DA or Us engines?
- DLE 30 won't run after 2 flights HELP!
- Gas Kill switch
- Melody 70cc twin (MLD70) prototype maiden!
- DA-60 Tuning Issues
- Venting Gas tank
- DLE 20 or DLE30?
- Starting Gasoline Engines - Safely
- Fuel Filters
- DA100 spinner bolt size???
- Is this the correct spark plug
- SV TROY BUILT 17 CC GAS ENGINE
- anybody else had this problem?
- For Spectrum/DX-8 users
- Evolution 35GT to RCexl ignition
- DLA 112 3d prop
- DLE 40cc or 60cc twin?
- DLE20 or DLE 30
- dle 20 or 30cc for hangar 9 cessna 182
- DLE 30 Mounting
- Engine operating temperature
- June 6, 1944
- Richer or leaner with cowl on?
