View Full Version : Gas Engines
- Novarossi help please
- compression
- Brison 2.4 Fuel Consumption
- Who's flying the Brillelli 46cc?
- 3w 85b2 - what c/f prop?
- mvvs 160 gas on tuned pipe
- Rx / Ignition Electronics Separation?
- Exhaust question for Dick Hanson
- New G-38 owner with questions
- MVVS/Evolution 45 RPM readings
- standoffs
- 25cc gasser shootout? (G26, SPE 26, Brillelli 25GT, MVVS 26)
- Gas Engine?
- BT-64 EIS Kill Switch
- Pro’s & Con’s of three & two bladed Props.
- MOVED: who is sick of the electric power craze???? conspiracy?
- Evolution 26
- New: Webra .91 gas/ignition
- 25cc gas engine for Funtana 60-90 ???
- Props
- Zenoah G62 and Kill Switch
- Bambula Props
- Lightest Engine
- DA-50 Gasket Leak
- 3W 80XI
- what size engine for .90 Ultimate ?
- Firewall clearance?
- BT 86 EI Electric Starters
- Gas Engine similar to a O.S. 0.90 four Strokes
- Desert Aircraft 100 CC Carb Kit??
- Thrustline centered in cowl?
- 3W 75iUS-TS prop sizes
- G62 and custom muffler for TF P-51
- Zenoah GT80
- G45 Intermittently Goes to Idle
- Da 50- Cowl sliced ignition wire
- Velocity stack for 64EI
- Brison 2.4 Muffler Pressure Fitting
- DA50 Muffler Thread/Bolt Size?
- Zenoah crankshaft differences
- cowl during break in?
- Kroma 180????
- 3W 200 timing question
- MOVED: Fuji 43 needs a home
- Fuji 43 needs a home
- CH ign. plug wire?
- Help with fuel tank?
- Which Mejzlik for MVVS/Evolution 45?
- Problem with Jtec mufflers - Please advice
- da-50 stutter problem,help please
- need help ignition kill switch
- Zenoah 20cc Electric Ignition Gas Engine - Any Feedback?
- Small gas dilema..
- Fuji 50
- MOVED: 50-75 cc conversion ?
- DA-50R power loss?
- 3w75 carburators
- 3w 75i help
- When to start leaning DA-50?
- 3w Hall sensor pinout
- New engine
- Prop Drilling/Clamping Fixtures?
- Problem with AW 60 engine
- Glow-to-Gas Scale Number
- rcign1 web page
- g45 rpm
- Regular or Premium
- Care and feeding of a BME-110
- ZDZ 40BS engine problem
- Flexible Headers
- G45 Running Problem
- Plugging the vent, yes or no ?
- DA50 question
- Here's a question for Walbro experts...
- ZDZ 50 smoke??
- da-50 adjustment ??
- What could cause this?
- RCS 140
- Soft mount for DA 50
- mvvs 116
- DA50 difficult to start when warm?
- bme 3.5 57cc
- 3W 80i
- Mounting Fuji BT-32EI
- 3W-55 carb problems
- Will the wildcat or coolpower container hold gas?
- What is the 100cc gas engine to have?
- WOT tuning of a gas engine.
- prop question for 26cc gasser
- MVVS 58 Throttle trouble
- P40-E
- MVVS dealers in U.S.??
- ZDZ 160 Super?
- Sala engine blueprinting
- mvvs 58 /evolution 58 ?
- Da100 back to idle
- DA-50R on its nose?
- Smallest Cheapest Gas Twin?
- MVVS 116
- Interesting tech tips from Walbro site
- DA150 - gas frm carb when fueling
- Length of prop spool
- Mvvs 58 irs pro ?
- Testing one of Ralph's G-62 lite engines
- ZDZ 40RV??
- Gas Tank....???
- fuel plumbing
- Need Walbro Carb
- 3W help
- Zenoah G26 fuel line question....
- I want to build electronic Ignition
- G4500 muffler
- Thrust numbers for DA 50?
- Best Prop for 3W78 twin
- Help! DA150 carb settings
- Can someone id this motor
- Brison 2.4 or DA50?
- Ignition battery charger for the Fuji 50 EI
- 40cc or 50cc?
- MVVS/Evolution 45 sparkplug
- Scimitar props
- 3W 28 vs. Evo 26 vs. Brison 2.4
- MOVED: Moki 2.10
- Canister Muffler
- zenoah G45 firewall !!
- MOVED: Engine Conversion
- Who can identify this engine
- Aircraft International or Cactus Aviation
- Evolution 26
- Quick? about my carb
- spinner ?
- Magento Ignition question
- "Different" Behavior on Brison Engine?
- DA 50 problems
- G62 EXHAUST FOR ZIROLI AT6
- Little fuel out.
- MMMagic.... Anybody
- Cermark Pitts, MVVS 1.6, RCign G-26, or?
- COPY OF PROSPARK INSTRUCTION SHEET REQUIRED
- MVVS/Evolution 58 can or pitts
- CG position for the WM Giant scale mustang
- zdz40 prop drill pattern same as RCS 180?
- Anyone Flying a Brilli 25 sport in a 1/4 Cub?
- Info on Gas Engines
- Mahle or petco RD 502 gas motor
- G-45 prop?
- Zenoah G-38 Kill Switch question?
- hauling your BIG gassers?
- NEW bt-64 eis Won't start
- MOVED: fuel tubing
- Urgen help on shipping issue!!!
- Carb parts for the Fuji 50 EI
- EVO 58 Break in Oil's and Props
- Zinger 7300rpms/NX?
- Aerotrend gas line??
- DA 50 question
- What battery for an Evolution 45GX
- Engine ID?
- 150cc Engine Test Stand
- DA50 Quits running
- G26 or G62 for WM P-51 GS?
- Stihl Fuel tubing
- Throttle / choke linkage
- Evolution 45 mag question
- RCS 180: please help
- G-45 cuts out at half throttle
- H9 Extra 260
- BME 115
- Is Quadra still in business?
- Zenoah G45 !! spinner for P47
- BCMA26
- Propeller Cad Model?
- finetuning 3W50
- RCIGN1 Converted G62 Info
- 3W Needle Settings
- New DA50 install
- where to buy MSC and NX props?
- Annoucement for Toledo Expo
- Flight time w/ Brison 2.4 and 20oz?
- What kind of ignition battery for RCS 140 or 180
- old style G38
- Rito 35 Hand Starting
- BME 50 Or DA 50
- Hey Ralph!!!
- Where can you buy DA-50 spark plug?
- GP kill switch
- Carburetor
- Hubs
- WHERE ARE THE DA50'S
- The New BME G90 Gas Engine ... a .90 SuperTigre on Gas!
- My New EVO 80
- Help! My new ZDZ 50 wont start!
- Canister mounts
- 3W props vs. MenzS or Bolly wood
- What About These Gas Engines?
- ZDZ 50 NG
- DA 50
- the new zenoah G20 elec ignition!!!
- Q100 strange carb problem
- bubbles in fuel lines
- DA 50 mounting
- Whacky Smoke Idea
- Smoke on DA-50
- gas pump
- MOVED: Catalytic converter for you?
- *Top Brand Gasser VS Conversion Gasser*
- 3W80
- doing america :)
- zenoah G26 engine mount
- new project
- Quadra 100
- mvvs 35/evolution 35
- Engine experts - your opinion Please!!
- 3W-56B2 engine in QQ's 85 YAK
- Setting the high speed needle.
- Mufflers for a BME 110 Extreme...
- who's engine is this?
- Questions on RF Interference
- can you identify this gas engine ?
- My Fox 3.2 is Knockin'
- DA-50R RunIn Oil?
- Best Clunk Setup???
- 3W LED
- what size gas engine do i need?
- Header for Brison 3.2
- *Zenoah G-26*
- G-62 Crank shaft
- Carb changeout
- Da-50 sound ?
- RCS 180 Questions
- laser
- Engine ID
- Gas engine Stand-offs?
- Big prop will cost hesitation hence tuning headache? G26
- Slimline Products M1 pump, where?
- 3W 100 Red Head
- Fuel tank setup
- 3W Throttle Arm Attachment
- Gas from fuel can to plane
- mvvs 45 gasser engine
- 3W 150 argfff! cannisters!
- Kroma engines
- What's so great about Lawnboy ashless?
- getting a 2nd gasser,,,
- *UPDATE* Who's using a B&B Smoke System?
- How Close
- Fuel system on a gasser?
- Muffler Paint
