View Full Version : Gas Engines
- da-50,no fuel
- Fuji RC Buggy engine?
- Easy start Gasser in 50 cc size?
- Aviomac 85 twin from MacMinarelli info
- Thanks all! G-45 fired
- Webra Bully 35cc - Run on Gas or Glow
- Got my G-45 today NO SPARK
- Amsoil or Other Oil
- I have a fuel/oil question
- Balancing a 1/4 scale size APC prop.
- Whose ground switch
- Reduction gearing.
- MOVED: honda gx25/35 performance parts
- Kill switch installation
- How much is enough ??
- us engines electronic ignition
- 3-w mount
- Custom header / can combo
- Sticky/Stiff BME Throttle Arm
- Prop shaft extension for 3W 60cc
- Zenoah G62 Smoke
- Is the US-41 the biggest rear exhaust magneto engine available?
- Posting engine+parts. Insuranc value?
- Brison 4.2 loading up on the down lines
- Brison 3.2 prop
- Wolf Predator
- Tartan Question
- SACHS 4.2 ENGINE OR G-62?
- ZDZ 80 crankcase cover
- fuel line??
- gas engine question.
- Fox Engine Problem
- 3w -explain the versions/models
- BME 110 Woes continue
- Another "Ralph"
- Ace 4-120 Bipe Ultimate bash
- 3W75 cut out - looking for suggestions...
- Carburetor Flush ?
- Webra Bully-Need advice
- sachs 3.4 rpm & thrust
- who is running a G26
- Brison 4.2 prop?
- ZDZ80 AND 3 BLADE?
- Pennzoil question
- Prop Bolt Failure
- Why no Stickies about Tuning and engine health?
- Someone please help while Ralph is away.
- Sachs 3.2 ignition/sensor problem
- VENT LINE ON 2 CYCLE GASSER!!!!
- Zenoha or ZDZ?
- mitsubishi t140
- Can hot weather change needles settings?
- Oil out front bearing
- 1st Gas engine advice
- fuel line DA50
- What's causing the gurgle on my engine on high speed fly by's?
- carb problems
- Maloney 100 Gaser
- Outstanding sevice from CH Ignitions
- Looking for some WT-257 carburetors
- Gas to Glow
- Priming a Gas Engine By Covering Exhaust?
- Compression Testing a 50cc engine ?
- Derating Thrust at High Alt.
- Points Ignition to CDI
- ZDZ 80rv prop nut size?
- gas engines...where to send
- 3W 100 Tamplete
- Roto, Zenoh, MVVS or Saito ??
- 3W timing Question
- TEXACO OIL?
- left-handed people
- DA has done it again!
- Zenoah G62 spark problem
- Using the ignition battery as ballast weight.
- Location of magnet under pickup sensor on 3W 100
- ZDZ 40BS
- Prop noise
- First BIG gasser... need help
- ZDZ 40cc
- Bme 50 need a little help
- not drawing fuel?
- MALONEY IGNITION GAS ENGINE
- How much power does an MVVS 58 have?
- prop for 3W 200
- Zenoah G-38
- BME 50 IDLE
- Gasser on a glow spec'd ARTF
- Gas engine ?
- 3W 100 ignition timing
- 3W 40cc ??????????
- Muffler bolts loose because of vibration
- GMC engine
- Black Oily-Residue -- NORMAL???
- Gas Engine Questions
- Wilco ignition coil
- Roto 25 - convert to single bolt - need help
- ZDZ80R scoop/411
- ZDZ 50NG versus ZDZ 60RV
- DA fixing DA50 lean carburetor problem?
- Props for a Quadra 100?
- Transition-to-gas plane help
- KROMA ENGINES
- Bought a 2 cycle oil mixing bottle at AutoZone
- What do you use as muffler gasket material
- zdz-40 breakin question? Why not synthetic oil?
- Brison 3.2 tuning
- Pennzoil air cooled oil, where to get?
- Another G 26 running problem.....
- Updated carburetor for DA 50?
- DA-50 STD standoffs thread size
- prop hub question
- bobs hanger 9 cesana 182 95 1/2"
- ZDZ 100 black residue
- Deadstick on DA 50
- Fuel pump for gas
- Engin stops
- ZDZ 160 Champ
- DA 50 concern
- Brison 6.4 prop selection
- BME No top end????
- BME 44 Quits in Snap
- MAH Carbon Propellers
- BME piston pin clip
- Wildcat Props, where can I get them?
- G26 & Eclipse 7 & throttle set up need help got pics
- Carb & prop questions
- G62 Priming
- 3 blade pusher prop for a G-23
- BME 100 or BME 102
- TME Smoke Pump Question...
- How in the world can you drill these???
- DA50-R Problems fixed?
- honing cylinders
- Who know Kroma engine ????
- Bad Rings Give your engine the tuneup it needs
- Additional cooling measures needed?
- CH ignition on g26
- wrap to center header for inverted mount G23/G26?
- zdz short plug
- New liquid cooled gas aero engine !
- ignition problem
- Zenoah engine problem
- Should the plugs be wet when...
- Tygon replacement?
- I need HELP! with my new G45
- Smoke pump Winsheild washer pump ?
- Fuji BT-64A best prop for a Giant Telemaster
- New G26 synthetic oil or not
- Which oil for all around use?
- 46% Ultimate What engine?
- Roto 35Vi Prop Sizes
- ZDZ 40 vs Brisson vs Saito 2.20
- GP 1/4 Scale PW EXTRA + ZDZ 60
- 3W QS cylinder color
- Revo Fuel Flow problem for the 2.5 Engine
- Asking the Conversion Specialists - The ones who really know!!
- MVVS 1.6 Tuned pipe on a G-26?
- Smoke Wich tubing ? Wich Pump ? Wich smike Oil ?
- fuji 32B problems
- Engines suitable for High Altitude?
- MOVED: Homelite 30cc
- MOVED: k&b green heads
- Where do you buy the oil in USA
- Fuel Tank Location
- A big thanks
- ignition battery capacity
- Ignition interference
- G-26 wont run,,,Help!!
- What props for Zenoah G-62's ?
- Dynaflite Chipmunk Kit
- ZDZ-80 Damage?
- MOVED: goldberg ultimate w/ 31cc gas?????
- Tell Me About the Quadra 52
- which gas for y/a zero
- Vortech spinner and adapter advice for Zenoah G-62
- Is this a Quadra 35 or 42?
- Replacement ignition for 3W 100
- ZDZ Casing Cracks (casting failure?!?)
- BME 44 Unstable Idle Setting
- Gas Ignition Problem
- Zeonah G-26 problems
- What parts are needed for a 50cc gas setup
- Need help identiying engine
- DA-50 & KS-1060 Pipe. How do I keep it from slipping!
- Fuel Tank Vent Line Location
- Zenoah gas/oil mixture question
- gas oil mix results
- Why ashless oil for break-in - 3W-106?
- Brison 5.8 single information/experience?
- DA 50 Reed valves (petals)
- MARK M180GAS: Anybody Using this Motor?
- My 106 is Kicking Back
- What's a good sport airplane for the G26?
- Da-50 fuel tank size
- g45 walbro carb problem?
- Repair of crashed Zenoah G26
- Gas and smoke systems
- Effective Muffler for for Zenoah G26?
- Dynathrust props....how do you rate them
- 3 blade prop for BME 110 Extreme?
- 3W60 - zdz ignition - problem
- MACKAY 22CC
- 3W 100 - acts up after 15 minutes
- "OLD QUAD 35" New Flywheel/Remove Points?
- DA50 throttle Q
- First Place Engines 1.3 carb question, can it be rotated?
- zenoah g45 throttle arm
- spark plug cap
- Looking for a small Quiet engine?
- Cessna 182
- Getting started with gas/info?
- Fuel issue
- Ignitions... Which ones are compatiblee ?
- KS headers
- Fuel Inlet fitting on a G62
- brison 2.4 parts illustrated breakdown
- BME 44 Engine Mount
- Changing a 5.5 Briggs over to Methonal
- KS website?
- Best muffler for a g23 in a Taylorcraft
- BME 50 help
- Quadra 50X has the Shakes!
- 3w 157
- RE-CONDITIONED GAS ENGINES
- MVVS 1,6 ¿what 3D plane?
- DA50 stock carb modified
- DA 100 low end problem
- fuel systems
- where to buy gas engines online?
- enough power?
- DA 100/KS 1060
- Muffler Pressure ??
- 2.6 ci Super Hustler
- G-26 Tear down
- Whatizit???
- Nebee to Gas looking for help
- brison 2.4 - wont turn!!!!!!!!
- Ignition powered by LiPo
- 3W70 Twin Cyl Question
- Zenoah G45 extra part?
- modifying props ???
- New QuaDRA LINK
- contacting BME engines
- Questions on DA 50 Ignition.
- 1/4 christein eagle what size engine works good?
- US Engines
- G-26 Props
- DA 150 running hot
- ZDZ 60
