View Full Version : Electric RC Helis
- help with optic 6 ?
- part numbers?
- Blade CP questions
- Swash Plate
- Roto Fly Electronics into E-sky Lama 2
- Setting Blade Pitch...
- set wakera 36# with hitec electron6 and JR 6102
- Blade 4 in 1 lights?
- Need help deciding
- Inverted Flight
- Honeybee FP Lipo
- Just my luck
- $129 for Shogun V2, would you?
- Dragonfly #35
- Horizon product support
- Century Swift ARF Sale
- Wrecked Dragonfly 36, What to do?????
- Throttle click
- Trex power supply?
- Trex & 9C
- Adding LED Lights. How To.
- My T-rex 222 and Airwolf fuselage pics
- Hobby-Lobby's Revo CP Heli
- Century Swift - Setup
- Venom outback rescue twin rotor
- CP2 flying problems
- Where can I get a heat sink for my Mega 16/15/3?
- esky lama & hirobo xrb questions
- 2200 mAH... too much for a honeybee FP ??
- PE Blades
- Pinion Attachment on AON 2815-3500
- Best and fastest place for Colco Thunderbird parts
- Plastic blade blades?
- Century hummingbird 3d parts wanted
- SETTING UP 7 CHP FOR BLADE CP
- high elevation blade cp no lift
- Should I have gotten a T-Rex instead? Please help!
- Blade CP Head Speed Dying
- gy240 problem
- T-rex 450 - ARK x400
- Info on z-power rc 480 outrunner?
- Century Swift eCCPM vs Quick EP-8 CNC
- T-REX ASSEMBLY?
- Trucks
- thunderbird Q's
- Charger
- Battery
- T-REX COMBO,WHAT DO YOU THINK?
- TREX Servos
- blade cp usb cable
- JR 8103A
- why does my shogun motor get so warm?
- blade cp: im a bit confused
- Beginner question??
- got a question about the blade cp
- Getting Back Into Flying
- 4in1 fried?
- COLCO 6CH RC ELECTRIC HELICOPTER
- Century BB micro servo CN2023
- blade cp tail wagging up and down.. why?
- Is the Align 430L too much for the TRex?
- correct Setup of blade-degrees
- Blade VS Honeybee CP Electronics
- T-rex Main Drive Gear & one way Bearing info
- NEED HELP!!!
- Common breaking point on a blade CP...anyone else?
- TRex XL CCPM ???
- Show us your micros (pics, pics, pics!!!)
- used gyro question
- Can't change servo
- Help with my Blade CX!
- Movin on up
- CHANGING ROTOR MOTOR ON HBCP2
- Hummingbird V3 or Honey Bee Mark 2
- Cheaper Blade CP Parts?
- Blade CX repair info..
- gyro question ?
- Hirobo XRB Servo stutter
- Making your own heli Blades...
- Hitec HS65HB for Trex 450Xl CDE
- Help!! first heli
- Eco 8 Tail Rotor Trouble!
- Lipo
- Rc-experts-com ???
- walkera dragonfly 35 3d??? is this a good heli
- Receivers ?
- Hummingbird Battery
- Best coaxial helicopter
- intruder 300
- Crossbreeding
- Warning about co-ax heli design limitation - Megatech skirts the issue
- Blade CP rubber tubing things
- Blade CP Yaw problem :(
- Does the motor need warmed up? MX400.
- scale bodie for lama 2
- How many people have these
- GETTING READY TO BUY T-REX 450XL!
- New to heli's How they work ,,and set ups
- i just purchased a dark knight 3-d heli(((HELP)))
- are parts available for blade bell-hiller head?
- My new TREX 450SE
- Brushless cp piccolo
- Blade 4-in-1, red light while hovering...?
- Anyone got any stuffed picoboard/plus`s?
- Outback Rescue twin rotor
- TREX XL Help
- set up Blade CP with Futaba 9CAP transmitter
- E-Flite Simulator?
- Looking for Inexpensive Li Po Batteries
- Ok, First Step Done
- Raptor 30v2
- what tail motor can handle 3 cells
- Blade CP wants to spin right.
- HoneyBee Skids
- New LiPo down to 4 min flight time??
- Can you suggest a DD tail motor /LiPo setup for this
- Quad Blades ? replace flybar with blades ?
- T-Rex RTF Complete Package Cheap
- oh ? GET A T-REX :Problem Solved = the NEW troll post.
- Who has the best price on Futaba servos?
- The new shogun se All cnc
- blade cp faster head speed
- blade CP upgrades?
- how to adjust pitch on honeybee cp2?
- Are my batteries dying?
- Blade CP Blade Grip Replacement Help
- just got my trex 450 together
- Super Small Heli
- Blade CP battery
- 250$ to spend
- Balance Question
- Buying Electric 3-D heli...advice
- How to Roll?
- Blade cp= Good beginner helo?
- Male or female connectors on motor?
- ECO 8 won't lift off
- heli vibrates on start up
- new an confused!
- Tail keeps spinning right... out of controll Blade Cp
- How well do the CP’s take the wind
- T-Rex mixer block too tight on pins
- Help - HB CP2 barely lift off after Brushless upgrade
- ALIGN 420LF in Dragonfly 36!
- HELP --> E-Flite Blade CX Yaw problem
- best scale electric counter rotating heli
- BLACK rubber bands to secure battery.
- IDLE UP?
- Rotor Blades and RPM for Trex?
- Digital or not?
- cant get align gyro to work right
- cant get align gyro to work right??
- CANT GET ALIGN GYRO TO WORK
- dd tail ?
- Shogun Tail Gear Case Upgrades
- Century Hummingbird FP
- blade cp won't hover
- On board 'low' battery power indicator?
- Painting and Visual Mods
- A question for the Forum Moderators About the Blade - CP
- need/want lights and spot light for blade cp
- How to attach training gear ???
- Align 25 amp esc shuts down in flight
- Best electric heli?
- new to helis
- will dd tail motor handle 3 cell lipo?
- temp power loss in blades cp-can you help
- scale bodies for mini heli
- TREX 450 XL
- Honybee 2 6ch
- align ESC HELP!!!!!!!!!!!!
- Help with next heli to buy
- DX6 Spektrum Radio
- E-Flite Blade CX review is now online in the RCU Magazine
- Heli Electronics
- Esky Honeybee setup after crash
- Helimax Rotofly problem
- Blade CP Airwolf
- Blade CP main motor replacement.
- Dragonfly 36B Cable
- megatech horsefly shaft might be bent!
- honey bee (blade) twitches on touchdown
- BCP CNC Frame Issue
- Lubricant
- More stable in higher winds?
- Electronics replacement in Walkera 36
- Heli Electric conversion
- Fun but need help
- Trex instruction manual
- HeliDirect 1300mAH battery for blade cp
- Hooks to pickup stuff
- Anyone using the E-Flight 2-n-1 on their Blade CP?
- good trex deal
- Extra battery for Horsefly
- head button
- Blade CP 9.6V Ni-Mh and 11.1V Li-Po with 9 Tooth?
- Metal tail for T-Rex XL
- Blade CP and brushless motors
- CRASHED HB2 TODAY!
- AeroHawk out of control
- 14.8 volt vs 11.1 volt 2100 Thunder Power battery
- Blade CP body kits
- Walker #36 Barebones
- Check out this radio kit.
- lama2, DF 5, XRB, ECT heli picture/vid thread
- Piccoboard Pro w/HH gyro in Blade CP?
- FMS ?
- DragonFly EM300 esc Question.
- How much vibration is too much
- ESky carbon blades
- Carbon Blades for Helimax MX-400/ark x-400
- Walkera #4 gone, what is a better option?
- FUTABA 9CHFS TO FLY BLADE CP
- Blade CP battery options...
- I got my first heli from e-bay...
- My latest T-REX setup...
- First major crash.
- when do you deem your helicopter DIY fix safe?
- Blade Cx flight time
- lipo balancers/chargers and shogun accessories
- fms sim
- blade cp volt/lipo question
- electric mx400pro
- Blade CP 2 in 1 mixer?
- Night Ranger 3D Thread
- Upgrades
- Walkera -New Camera
- Good Deal?
- More BLADE CP new antenna wire pictures.
- Aplus 300 Heli review
- Pictures of tail rotor modification/improvement.
- Testing upload of pictures, first try.
- T rex manoeuvres how-to
- coco LLama
- E-Flite Blade CP / Esky Honeybee 2 Aluminum Rotor Head
- HBCP2
- honeybee cp2 rotor tracking
- titanium main shaft and gear. BLade Cp
- Bell Mixer Upgrade
- more blad progress
- flying Blade CX...what next?
- NE-KO
- Werid shogun brushless glitch.
- Which batteries for Blade CP upgrade
- Megatech Housefly
- BLADE CP antenna wire.
- HBCP2 CG?
- HB2 FP Vibration
- blade cx video FFF!!!
- Hleimax gear replacement
