- Dimensions of common parts...
- How do I caculate................
- Decals
- airlon size question
- Looking for Avro arrow plans
- Best place to buy Balsa for major project?
- 40% or larger?
- Inventor Import Problems
- laser line
- Scratch built little trainer.
- Ziroli Taube
- Servo wires in home-cut foam wings
- drawing a line ACAD R-14?
- no plans, just a plane, want to scratch
- Good/Cheap/Simple CAD Software
- Plans scaled ^
- Rutans Grizzly
- Need advice on Wood Selection
- Has anyone used the new polyurethane glue's?
- Kevlar cable
- 1:6 Scale Fokker E.III Turnbuckles Anyone?
- Help with assembling plane in 3D!!!!!
- MOVED: hoverplane powered by brushless motors
- Using CAD to generate ribs for geodetic wing
- Nifty Fifty
- grain types and importance
- Wing rib spacing
- Another ACAD question
- Inventor Help
- Rib Scale up and Re-Sizing Problem
- Please Print me some plans!!
- BootLace
- PDF's and Printing
- Anyone have info on a flying wing?
- Looking for plugsand molds.
- Any RC homemade flying ideas?
- Need help choosing engine size
- Balsa supplier in Australia
- Ultimate 40
- Heinkel 162 ( HE-162 ) Looking for Plans
- Looking for ribs and forms - Extra 300
- 3d Stab sizes
- Tiff files into Acad?
- UC Davis SAE Aerodesign Unlimited Details
- Two possible building tables - neither is straight!
- Making Templates?
- castering tailwheels
- Need Help - Landing gear in foam wings
- Are Cleveland Model plans good and worth the money?
- Foam cutter schematic question
- Monocoupe 110 special
- Foam Delta wing plans??
- Fokker DR1 plan in Australia
- Need Scale Drawings of Composite-ARF Roo II
- Ultra Hots Bill of Materials
- Mixing Glues
- Are ther manuals?
- Putting on Ailerons
- Plans for a Cessna 170
- Lite-ply shear webs
- B1 Lancer
- Flap design...
- Landing gear reinforcement
- 1:3rd scale Piper Super Cub
- Buying balsa,lite ply, and aircraft ply?
- Plans for Pitts, Ultimate or Christian Eagle
- Sudio Max 3D R2
- Question about top wing dehedral on a bipe
- Folding wings
- Custer Channelwing
- Funtana Airfoil??
- H50% reduction of existing design
- *gulp* Here we go! AHHHHH! boom.....
- Engine size rules of thumb?
- wing wire bracing - where do i find this?
- Fairey Flycatcher
- Searching templates Estra 300 (Ohio RC and Goldberg)
- Byron F-16
- What determines...
- keith sparks a-10 or rcm a-10 which one
- Looking for Plans or 3 views for a Extra300
- Iges file of Harrier !!!
- Free
- Drawing Plan Using 3D Studio Max
- Aluminum stock for struts
- Precision Fiberglass Products
- 150" Flying Wing
- enlargements again
- Foam wing structure & dihedral
- LANDING GEAR ATTACHMENT
- Throttle pushrod help
- root & tip template placement on foam block
- enlargeing plans
- GP Super Sportster Airfoil
- interface
- Rocket powered Bell X-1
- Slowstick scratch built wing - control rod setup help please
- Spar location
- foam wing cutter
- Cleaning Spray Adhesive???
- RC plane for security usage
- model for an Enya .09
- How to fix a foam wing block on the table??
- design and paint schemes
- Big Stick Plans
- drawing plan using turbocad
- my new project
- Formula
- Curtiss Jenny plans?
- .46 Trainer Plans
- cardboard as a building material
- New airplane for my engine?
- ME110plans
- Old surfboard.
- Glow engine drawings needed
- "Crimson Skies" model designs from the game?
- $10 FW-190
- Plans of Marchetti F-260?????????????????
- Victory Stik
- Plans for (Gene Soucy's) Ag Cat Bipe?
- Inches to milimeters
- Plans Transfer to Wood
- Conical Wing Tips
- Delta vertical fin area?
- p51d
- CAD Input Devices
- Precise ripping - table or band saw?
- Need help with foam core sheeting boo boo-Anyone???
- Need plans and canopy for Bud Nosen P-47
- Midwest Bipe Stik
- Sukhoi SU-26MX
- laser levels
- Need Help with making my Own Canopy..
- need plans for this glider.
- Beechcraft Staggerwing
- need plans Cessna 336/337 twin push-pull
- what wire for my hot wire foam cutter?
- jet like plans
- All framed up, too pretty to fly. :(
- Need help with full flying canard - Anyone??
- Sheeting Giant fuse and wings???
- Carbon Fiber Reinforcement and Covering Question
- Question about Carbon Fiber and Covering
- Help on DF design
- Question about C/G....?
- Meet Rustik
- wing calc program
- F20 3 views
- Need Landing Gear
- Need prop 3D files / details
- Bucker Jungman Plans..????
- sea plane?
- printing decals
- Plans needed for 60" Pitts or Christian Eagle
- Looking for Tokyo Echo
- Firewall thickness?
- blueprints
- Calling all you Autocad gurus
- Bomber Plans needed......
- Scratch building 35% edge
- Silly Autocad question
- need a cowl for 1/3 Taylorcraft
- Need help designing large model
- Ziroli BV-141
- !@#$%^&* TurboCAD
- Pro Desktop
- Yak 54
- Anyone that has built Wendell Hostetlers 34% 540 Edge
- The Best way to set up a pull-pull elevator?
- Cessna Agwagon
- NEED A FOAM CUTTER
- Flying Wing -- 76" wingspan -- Maiden Flight Today
- Basic Trainer Plans Wanted
- AutoCAD Hatch to draw Balsa and Ply grain???
- TORNADO GR.MK 1
- Beechcraft Starship Design
- newbie tips
- where do I start?
- Need plans for .20 sized Kaos
- To many airfoils
- Blue Max Plans
- Experienced Aircraft Designer & Builder Needed
- Twin Engine Conversion
- Has anyone ever built a Focke-Wulf "Triebflügel"
- What airfoil for glider version of Bell X-1
- The Ravenator flies! Check this out
- New prodject! EDF
- Anyone interested in doing some 3d cad?
- **NEED** Scale R/C Modeler issue with Cessna 195 (Gus Morfis)
- What I've found regarding wood densities.
- Looking for suggestion for model to plan-build?
- Scratch built Stick Problem
- mig-3 1/4 scale
- Templates
- cutting turtledecks????
- looking for an elctric ducted fan for a new project concept
- AutoCad 2004 anyone?
- Anyone seen an F-86 prop?
- airfoil to a EDF?
- Cutting foam wings?
- Wanted GIANT Ultimate 10-300 plans
- Print Plans Off Computer
- My Dads 1/3 Skymaster
- Need help with 3 view
- servo installation
- 1/3 cub scratch build
- stab area calculation
- Mig 29 model "skin hinges"
- RCM trainer need article from july 1968
- 80" Bipe Longerons?
- Scratch Built Superbolt (pics)
- rudder question
- FlyR\C L-19 Problems
- What airfoil for a trainer?
- Molding carbon fibre rotors
- Solar Powered R/C Plane
- Adobe Acrobat Reader Plans
- MAGNUM Field Box Plans
- scratches on plastic canopy
- where to buy balsawood
- Anyone built RCM praying mantis?
- Auto CAD question.
- Design software
- B-25 plans recommendation
- anyone ever bash a SIG4star into an Eindecker
- What Engine?
- .DWG
- A site for small stuff
- How to add 2D airfoils in AutoCAD
- Lookng for 3D Models of Propellers
- Wood Density Question(s)
- Forget Building!!! Just Think It and Fly It!!
- RCCAD worth $50?
- Rudder Travel Question
- Uravitch SE5 73"
- retract help please
- DOUGLAS DC-8 KIT OR PLANS
- parts
- Bob Morse 1/4 scale Cessna 180 windshield
- Spruce vs Balsa spars
- Good Practice wing?
- Landing Gear design help
- 3d model of an airplane in autocad
- DesignCAD for Aero Design?
- Digitizing Airfoil
- Looking for plan to a .25-.30 high wing trainer
- Auto Cad 2d to Solidworks
- a few good pictures
- Fiberglass cowl fabric weight?
- Ziroli P61 Black Widow ANYBODY??
