- Carburetor settings for OS 70 SZ
- Raptor 50 blade tracking problem!
- Tail Pitch Rotor Slider Arm Breaking
- TT .39H Pro fuel recommendation?
- Hirobo SCEADU EVO. 50
- Raptor 90 exhaust
- Raptor 30/50 carbon frame CCPM
- Changed muffler...Now it runs like crap. Help Please
- Pitch set up for Auto Rotation..?
- Pitch too sensitive
- Engine poll
- Thunder Tiger Pro 50
- Autos.....
- Would you guys check my list???
- Help Me find a 90 Heli to fly!
- mini stereo
- Which Radio?
- Can an R50 V2 do more then an upgraded R30 V2 to a R50 V2 ?!
- Set up for 50 V2
- Heli Newbie...
- ballet style piroette
- Tail wag & spinning
- fuel dripping from carb when in hover
- Raptor 60 Construction Question
- Website selling raptor 50 with tt50 for USD380
- Starter rubber?
- Serious compression issue
- Scale event at Swartkops Airforce Base.
- Raptor 50v2 flybar seesaw looks offset a deg or two???
- Can I use oil on Big gear wheel ?
- Battery Pack Contruction
- Questions about Raptor 90
- engine boggs down during 3d moves......
- R30 V1 Revision 36A
- Tail assembly lubricants?
- good deal?
- How far can I assemble a Raptor60?
- Raptor 50 V2 Assembly Questions...
- Futaba 7CAP problem
- Construction Help
- Flybar
- Metal Heads ...
- RX Battery for Raptor 50 w/ digital servos
- Used Raptor 30 parts wanted
- What can the R50 V2 do that the R30 V2 can't ?
- Canopy and Tail boom
- Engine Break In
- Great day ends in tears ...
- Raptor 50 swash plate bearings? or what?
- Tail blades/Drive locked up Raptor 30 v1
- Raptor 50 - What optional parts would you recommend?
- metal cooling fan ????
- Hitec HS-5625MG Vs. Futaba S9252 Servo
- main blade covering
- Raptor Conversion Question
- Filthy Exhaust
- Homemade Rear Servo Tray
- West Eurotech .50 heli on the R50 V2...
- Rapter V1 Blade grips slop
- THROTTLE HOLD LOCK OUT
- Which engine for the Raptor 50 V2?
- Hatori 540 tune pipe with the TT50?
- raptor 30 ccpm setup
- raptor 30 maiden flight
- Raptor 30 V2 Blade question
- Raptor 50 v2 Pro vs Raptor 50 High Performance
- To Synthetic or not to Synthetic, fuel is the question
- hovered for the first time
- How often to tighten tail drive belt?
- Clutch problems for a change!
- how is this deal !!
- Newbie here
- My first heli video, Raptor 60
- ive just got a raptor 30 v2
- raptor 50 upgrade parts?
- Custom fiberglass canopy for R50v2
- Gyro setup problem, PLEASE HELP!
- F.glass canopy for raptor60? pref. in AUSTRALIA
- GY401 or 601 for Rappy 90 SE?
- Which Radio?
- velociraptor 50 v2
- Maiden Voyage a winner
- 50 Upgrade Kit
- Right...
- Rachet on throttle on JR Max 66 (JR622 Heli)
- recommended gear ratio for os 91 c-spec,raptor60 ?
- Raptor 50 or 60 ????ASAP
- Finished
- Which SIM?
- Tail Belt and Rear Rotor
- What percentage of nitro should i use for my TT 30 Rap?
- Repairs
- What glow plug for a TT36 PRO?
- Best fist heli for newbie
- 30 and 50 sized mufflers keep stripping
- Blade cover
- V1 or V2
- Bad Start (Raptor 50v2)
- Metal Fly Bar Control Links (Raptor 60)
- Quick question
- onlyraptors.com
- is this real??????????
- WHere to buy RAPTOR 50V2 in Taipei
- Rotor Case, Pulley gear and Drive Belt
- Raptor 30 V2 Engine
- Recommended Radio gear for a Raptor V2 50
- Clutch Liner & Pinion Gear
- New paint for my Raptor 30 V2!
- Throttle/Pitch Tables
- TT 36 Pro engine trouble, i need your help guys.
- Violent shaking in Raptor 50
- Raptor 60 V2 discontinued?
- Am I getting the fan tight enough?
- Problem between hovers!
- Thunder Tiger .50
- TT H39 Engine (Wah) (Tail wagging again)
- Need PARTS in LEXINGTON, Ky
- Spinning Out of Control Raptor?
- drilling drive shaft
- Raptor 50 V2 Engine selection
- Raptor & OS 32
- Tail Wagging
- just will not start
- TAIL BLADES STICKING
- Raptor 60 V2 ....RX battery
- Buying New Rapter 60
- V2 Conversion
- which way should the tail rotor spin?
- What muffler to get?
- antenna question?
- Sticker for Blades
- Exhaust Diverter
- Brocken Screw in Main Frame - Help
- 30 V2 engine muffler blows up !!
- tail rotor
- raptor 50 + os50 engine fuel?
- rattly noise at hover
- minimum gyro/servo for raptor60 for 3d?
- Raptor 60 engine
- Raptor 30 & CSM 540
- wiring question 30v2
- TT 39 settings
- I need some help
- $24 Futaba S3010 servos in R50?
- Raptor 30 - What's a fair price?
- Raptor 30 setup in flight sim
- 30 v2 canopy on v1
- Starter setup
- Anyone using a LIPOLY flight pack?
- Ever wonder how fast a Raptor 50 with a OS 50 goes?
- Raptor 70 gots the shakes
- blade grips flying off?????????
- motor problems
- Raptor 50 Starting Problem
- 3rd raptor 50v2 kit in 3 weeks!
- Tail Boom Vibration
- Rapture 30 scale body?
- raptor 30v2 canopy?
- PICKS OF WIRING 30 V2
- os 50 in a raptor 30?
- .46FX-H in a raptor 30?
- OS 60 in an R50 ...
- Raptor 60 - Tail Vibration / Nodding
- Mavrikk bearing block problems
- How about a Raptor pic thread? Post em!
- Why Stretch a 30 to 50???
- need help with a tt90 and mp2
- Raptor 30 to 50 upgrade, which engine?
- Beginner trying to get back into flying.
- Tail Unit Assembly
- Rap 50 is up
- Raptor 30 V2 High Speed Vibration
- V2 30 Raptor cracked exhaust
- Raptor 50 Thrust Bearing
- Main Blade Bolts?
- Upgrade bearing for V1 starter shaft??
- How long did it take you to build your R50 V2?
- General Raptor info please for a newbie
- flap dampers
- Raptor 30 v2 Radio Gear
- Wagging Tail Raptor 30 V2
- 4 Basic questions for people w/ Raptor experience
- Throttle arm
- V1 or V2
- Glow Plug?
- Can you run standard clutch on RV2 upgraded to 90?
- TT50 or OS50 for R50?
- Should I turn the head around on a Raptor 30 V2
- Raptor 50 v2 heavy vibration
- 95mm tail blades on a 50 V2?????
- Best Raptor for an OS 46FX-H?
- Can I upgrade directly from a 30v1 to a 50v2 Raptor?
- More lifting power with a Raptor 30v1
- Main Flybar!
- Tail rotation in the air at throttle/collective up!
- Servo specs for raptor v2 60
- eRaptor conversion ?
- Gyro question for 50 Raptor
- what goes best in a 30 V2 ?!
- Raptor Manual Wanted !!!
- Receiver recommendations R50
- Raptor 60V2
- Raptor 60 tail failures anyone?
- upgrades
- Blade rotation during startup!
- R30 V1 needs more power for me....
- Got my R60 in the air!
- main shaft
- Strange sound & fuel leaking
- OS 50 in a Raptor 50
- Tail servo
- servos for raptor 30
- Tail rotor not getting enough tourque?HELP
- 401 gyro question?
- Servo Glitching?????
- raptor V2 30 engine mount problem
- R30v.2 Vibration
- Raptor V2 50 build
- Help setting up a TT Raptor 30 ARF
- Balancing Woodies
- whip ant. on a raptor
- big wag durring FFF???
- Raptor 30 metal tail pitch problem.
- Raptor 60 pitch servo problem
- Raptor 60 V2 question
- Raptor 90V2 Manual
- Scale Fuse For Raptor V2?? 30 size
- Fuel tank
- Raptor 30v1 OS 32SXH Leaning Mixture Problem
- TT 39Pro EngineProblems
- Realflight G2 Raptor setup
- 30 V2, similar probs. anyone?
- Best upgrades for 3D w/ raptor 50
- grease on the bearing?
- man.raptor 30 v.1
- Just installed new OS .32 SX-H! [Raptor 30 Build-Up Pics]
- Idle-up1 help!
- BIG SCARE.swaring off training gear.
- tt 39 muffler gasket, needed?
- Raptor 30 V2 Metal head
- Help, I need part from a broken .50 clutch
- Tail spin
- Lost Engine needle
- TT.39 break in
- GEM 2000 on Raptor 50 V2
- Wow what a feeling.
- First Radio!!!! Need Advice----Please Help!!!
- raptor 50 v2
- ok to route gyro wires through frame holes?
- Non-digital gyro servo on R30v2
