View Full Version : Speed - RC Gas Boats
- WHH TEAMPRO RUDDER issue
- Do you remember?
- Just bought a Dragon 24v ghb and need advise
- does anybody know
- Water pump?
- New Pipe and Carb for my BJ55
- cooling issues
- QD singing it's song
- zenoah self destruct
- Couple of old farts and a 90kph boat
- EASY VEE BUILD *NEED MORE HELP* (almost done bare with me)
- Help me find a manifold for a Homelite
- Pro boat water pump
- Expresscraft Mti Cat Bulkhead
- New boat from Proboat
- Coil Relocator
- Engine Identification
- 32:1 too rich?
- battries quest,ion
- New club Cape Town RSA
- Rub-a-Dub-Dub Rio a Sub
- New Pipe new top speed
- Thunderboat turn fin, to scale or not to scale??
- 54 Deep Vee
- B.H. HANSON HEADER PIPE
- carbs
- NVS NEMESIS CAT BUILD
- exhaust wraps
- Rio 51 / Zen g260 throttle set up
- supllies
- CC Powermaster in a BJ55
- rio 51 flex shaft tube
- Rio 51 drive coupling
- my stryker 41
- modified zens
- New To Gas Boating Need help
- Great Pipe Deal.....
- Finally built it up.
- Where to run on LI???
- Miss Geico RC Model - with turbines!
- 73" Scale Cigarette hull
- What Can I Expect?
- REVENGE BOAT
- Rio-51 Re-Power
- need help with rio 51
- could someone help me get information on a motor??
- Strut Bushings
- Help with MHZ Counter Rotating Gear Box
- JR XS3 radio
- Bad Touch Catamaran by PIP
- 47" Falcon Mono by PIP
- New Boat need some advise
- Painting Boat
- QD Hot Pipe
- Best 1/8 scale hydro boats
- MHZ #6 speedmaster not for sale ?
- Where can I buy these air scoops?
- Dreamin Turbine
- gluing deck to hull?
- Spektrum DX3S TX Help!!!!!!
- Engine Dyno
- PROP WORK
- Zenoah 26 oil mix
- Justaddwada''''s Pictures
- rio 51 crashed
- Help pick my new boat
- weedie engine choice
- apache build....south florida
- prop rotation
- Radio???
- Smoother Waters
- Quickdraw 70cc
- My 48" mono build
- my new 6' gasser
- New 2.4 Tower Radio
- XXX outer limits???
- good online shop with gas engines ?
- 2x 26cc Cat
- viper hulls?whats the deal knockoff of other hull builders?
- pulling to the left
- rio 51 upgrades
- Forum Noobie, Electronics Oldie....Wet Exh.
- A couple questions.
- Forabuck Cobra Hull
- zenoah/sikk/model gas engine... v2 twin?
- help with how to grease shaft/cable
- Peter's "Oh Boy Oberto" turbine Flips
- Train of thought
- NEW 2009 ARROW SHARK FIGHTER CAT
- A few gas questions..
- BEST PROP
- Dumas 55" scarab conversion from nitro to gas
- would like to make a boat similar to miss geico
- engine dies after 15min?????
- How am I going to fix this part 2
- Gel build-up in GAS IV bags
- 1/4 scale jet sprint hull
- designing an 80"cruiser
- Question about Fiberglaass layup
- Easy Vee Question
- whats a gas boat kit for no mre than 300 $
- zippkit Rockett done, almost
- First time running Rio51+Zenoah,not a good day
- help boat with a 37cc gas motor will not stay running
- almost ready to go Ballistic !!
- what oil for breaking in
- Let's make my Sprint Cat hit 70mph!!!!
- need plans
- 4 bearing zenoah
- fixing a crack in my avenger
- Aeromarine build quality
- Razor 45 build. BUT ill be asking for lots of advice. :)
- Fuel Line
- merccruiser 6 stern drive
- What oil can I use?
- headers
- PI Generation hydro hull
- what prop to use
- Dry Tune Pipe
- pics of my cat
- what hull is this??????
- maxcat questions
- 37cc gas motor will not stay running help
- ****GAS BOAT DRAWING AND FUNDRAISER !!**** RESULTS ARE IN !!! !!!!!!!!!
- Building a Crackerbox step by step with lots of pics!
- Motor reving high on start up
- BJ55 C/G?
- Why you want full length stringers
- New build started Bluebird K7 1/4 scale
- motor mounts
- Bonzi bzx2 mod
- lead teflon or brass bushings.
- question on pipes(zen)
- Crackerbox boat plans?
- scott harris (boat mod)
- Queenstown gas boat races
- Range for 27MHZ and 75MHZ
- brand new zen leaking half case seal
- Velocity Stack
- RC gas boat racing webcast
- My finished Cat
- need help
- My Dilema
- what prop?
- the unofficial gas outboard / F1 thread
- GAS OUTBOARD guys this is our new home
- Any F1 plans in pdf format, please!
- hitec TX
- fastest hull for a 5m motor
- need help
- WHH Magnum 57 or Aeromarine Apache 56
- How to get started in racing
- Another Web site for perfomance
- KU Jayhawk Maxcat build
- pictures?
- New Chinese motors
- WWH Stingray Enforcer Thunderboat
- CTO3 or MTI and what hydro
- Forabuck hulls?
- My new boat
- "Boost bottle" performance ???
- air vents
- Switch to 1/4" Prop shaft W/O clutch
- WHH XP-2 or a stinger for a mono hull
- Ebay boat hardware
- I hate my Zen
- Soldering brass to steel?
- How to make a mould of my cowl?
- Pipe Length for a Stock 260/2inch pipe
- A thank you ro Toofat,Cheeszz mart and the rest
- 80" size vee hull
- 7ft Catamaran 140cc
- WHH Water Pump
- Attention BJ55 Shockwave 55 owners
- Trailer w/boats stolen from Ft. Laud. FL.
- P1 Class stepped mono??
- witch motor to pick
- Quickdraw carb help
- transmitters
- How am I going to fix this?
- Is this genuine?
- New Comet roundnose hydro
- are lifan any good?
- sikk timing.
- which pipe for my mod zenoah
- Conquest w/RCMK S-254
- Conquest Video
- want to build 72 " weedy Help!!!!
- Hardware for AM Avenger
- Rudder verus prop position.
- Futaba 2.4 GHZ antenna mounting question
- Rio 51 muffler?
- Deep V hull help
- Pipe question?
- Anyone have more info on this Jet Boat? Pics/Vid
- Rio cavatation
- Quad catamaran on board video 121 k's
- For those of you without fullsize boats, how do you recover your RC boat?
- Wild thing questions
- Which Prop
- Up in smoke!
- Noob ?? Miss Circus Circus
- C1 Power boat racing tonight
- Boat turns right constantly
- weedy build
- any of you guys know what make of hull this is ??
- MaxCat 61 My Build.
- cc powermaster pipe question
- Stock Prop vs 3 Blade VooDoo
- Arrowshark products
- New radio
- Weedy Bogging in corners
- Odds and Ins ???
- Water fitting leaking!? ***SOLVED***
- Stalling and a few other questions
- CY and Zenoah Source Coils
- how to shut of boat!
- decals or victory photos
- How to stall engine?
- sikk engines
- sikk timing on a zenoah
- Viper Hulls having fun in Perth WA
- rio 51 prop
- what 1/4 F1 gas tunnel hulls sold in the usa ?
- want to build an offshore style cat, where do i find a hull?
- diet pepsi cyclone
- 6717x3, 230 pitch?
- does anyone know navicraft?
- WHAT TO GET ? RTR , KIT ?
- Reducing Noise of a Gas Boat!
- Should I Switch to Gas?
- rio 51 cooling problem.
- Warehouse Hobbies
- Set-up and Stuffing tube drilling
- HELP, FAST...Which prop to run on stock zen 260?
- another ebay 50 mph race boat
- X-Hydro
- boat stand modification
- RIO 51 TIPS-N-IDEAS....
- A Place to run Nitro or Gas Boat in Metro Vancouver Area?
- Questions, Questions
- Looking for boat shops in Ca or close to
- MHZ Mystic cat
- Proboat hydro short vid
- Is my clutch bad???
- rudder set up position
- 26cc RCMK Stealth
- Easy-Vee Maiden video
- M11 FHSS-2 2.4 ghz radio
- Port angles
