View Full Version : Speed - RC Gas Boats
- motor tuneing
- small tank tray
- Looking for a nice boat!
- What's up with namba?
- silencer for blackjack 55?
- Clutching a full mod engine
- zen octane?
- Deep vee plug and boat build
- fuel tanks or fuel bags
- what gas octane
- 50" Dreamin' CS "The Start"
- short plug and fuel mix
- prop balancer
- Question number 2
- need CG for Aeromarine Donzi
- Corossin X
- drilling out a prop
- proboat 1/8 hydro CG?
- Shaft problem and Clutch Question
- zenoah 26 mod kit???
- Twin Side by Side V Inline
- anyone have experience with this ebay boat?
- Jacks gas boat
- apache pics
- viper hulls 50" &56" hulls vs forabuck hulls 51" cobra max hull ( change of plan)
- whip lash
- which one egine mod
- looking for a hull 50 plus inch no motor...
- The best mild mod Zenoah??
- Taking on water
- Prop Balancing - Need some help finishing it off
- Reducing the engine noise of Shock Wave 55?
- what prop
- How do you join a fiberglass deck and hull
- another thunder bolt build
- gear box
- Anyone...
- ok just bought a 55 inch manta ray...large waves here i come!
- inline twin 260pum
- Speedmaster Hardware on Rio 51
- 55' jet drive
- offshore procat pics needed
- apache 50 setup
- cooling system problem
- Picking this up today for $120
- Rio Replacement Motor
- Deep Vee Header/tuned pipe length ???
- Zippkits thunderboat prop advice
- In Deep
- What's the best clutch for a blackjack55?
- dreamin boat
- J&G 25cc Watercooled Motor info and questions
- need a hull
- Ask Grim a question. RIO 51
- Ohio
- serious cavitation
- BYE BYE SPEKTRUM HELLO FAAST
- homelite clutche
- MHZ USA??
- Zen piston mod
- inline cat
- Ok, this time I mean it - I'll get something
- Best RTR gas boat for under $1000?
- WHH Enforcer grease cone?
- help with friends shockwave, he is at sea
- huge issues
- black jack 55
- Turn Fins
- why only on the right
- R254 Cylider Kit
- jr xs 3 pro synthesized radio
- clutch pads
- Water Pump....Vacuum Pickup?
- can these be steered?
- 6516/3 prop needed
- what cats are out there
- throttle return spring
- help on rudders
- deep vee using sub surface drive
- Latest AMB music video. Check it out!
- New to RC Boating
- Best Gas boat Radio????
- MHZ S6 III questions
- New to gas
- cat or mono????????
- Loss of a great R.I.P Roger Newton
- Futaba 3PM FS Pro...how is it?
- I never thought I'd see it
- Rio running great and turning left really well!
- colored servo box?????
- Looking for pics of Wet Exhaust
- setting the needals
- rio 51
- I Got Wood Easy Vee
- Boat wobbles alot
- Need help tuning.....
- thrust washer
- rudder dings
- THE PINK BEAST!
- aeromarine challenger drive system
- New H.P.R o6 elec
- Servo batteries
- oops!
- Charger Question
- ZEN7 VS BH HANSON HORNET
- china cat !!!
- Battery question
- gas tunnel hull
- homelite 30 cc not starting
- zipkit easy v
- WTB CAT HULL
- Problems with radio glitching
- some new pics of the cto3 floating
- New Products from Zippkits!
- Where can I run my gas boat in southern cal?
- Aeromarine Signature 57' hatch.
- RIO 51 running!.....Finally!
- kos intro video
- A buddies disappointment - What $3000 does not get you
- need a cheep v ish hull
- ONE SWEET HULLLLLLL
- Rio 51 Primer bulb won't fill
- Man O War cowl/hatch
- segad on ebay
- What is the best hydro
- Homelite 25cc. Clutch
- Grim HELP! my rio 51 will not turn left.
- 1/8th Miss Bud Cooling Lines
- New MOD Piston from VXper for Zenoah, CY SIKK
- rio 51 exhaust hop ups
- exhaust header temprature
- 48 challenger pro
- What does everyone thing of the new venom boats?
- makers of 45 to 48 mono style hulls
- Hawaii New Day to Play !
- Gas OB Pipe
- below waterline exhaust
- Update on NW Offshore Championships....
- DPI TUNNEL NEED ENGINE
- Pro Boat 1/8 Formula Hydro
- Where to buy flush mout water pickup...
- Building new 47 mono Deep V help on build please
- Who is the person who has the new Venom boat
- Starting out on the Universe
- two quick questions
- Rotating Zenoah cylinder 180 degrees
- 644 Fuel line rigging
- MOST STABLE GAS BOAT?
- flex shaft tube efficiency
- Where can i get a niceish but cheap gas hull
- Delmarva Boat Modelers Gas Boat Event
- its been a while but im back
- Avenger Pro - Advise needed!
- first v24 expirience,it was a blast!!!!
- Cooling issues for Zen 260
- Rio 51, The saga continues......poorly
- A better Prop for a stock Shock Wave 55!
- Sup
- and the manifold. whatneed advice please
- Mhz drambuie qd ht25 almost finished
- Is this safe?
- big bet
- XHB-450
- Prather Parts
- Want to Race
- pipe mounting
- water boots
- GOT A BOAT~ WHAT IS IT??? Im new and need some help.
- Questin ZEN7 and PK3
- Few noob questions.
- What to do after being capsized!
- sikk 26 in mono what prop
- Sonic Racing built CT03
- rio 51 exhaust?
- budget Gps
- where to buy hull
- M5 Zen, What do I need?
- Were to buy Blata/Polini Clone/Replica
- Carb question
- Please help choosing a Seaducer
- Another Falcon build
- boat pulling
- Give up on Rio 51??
- header pipe stay loose
- sikk/zenoah tune pipe
- chain saw/weed eater/blower
- More Rio 51 woes.
- WHHobbies new race mono name contest
- distance of prop & rudder from transom
- Rio 51 shaft problem
- props for cat
- WTC Stainless Steel Header
- Less noise?
- hull size
- pictures of my 41 falcon !!!
- First Time RC Boat Purchase ????
- BOAT STANDS
- Confused
- Head temp for BH Hanson mod zenoah 230
- Need help on outboard zenoah
- new rio 55 pipe?
- Strudder
- what pipe is this
- Curiosity....
- Zipp Kit's Rockett thunderboat
- MBoat parts
- oops at the lake
- finding used boats- thunderbolt, insane
- zenoah 26 not running propoerly
- The proper measurement for a tune pipe
- Where do I find great boat plans
- I search WINGSHIELD for super G ?
- I just can't start my black 55 with a zenoah 26, please help!!
- Need sonic racing engine mounts for ct03
- ofna fail safe
- Newbie needs alot of help!!
- adj. timing unit for zen.
- Whobbie's Magnum 57
- MOVED: Do we Need a DRAG Boats Forum,Gas and/or Electric
- what do you guys think of the cracker boxes
- Another option for big scale cat
- S-6 DRIVE
- is this what i need to be lookin at
- fastest a whh team pro will go
- Recommendations
- changing batteries ,How often?
- CAT/Zenoah Top Speed
- HeInsane pipes
- I want a Fast Gas Boat!! Help
- Running lights and Stern lamp
- Pics of my new gasser
- cost to build 46" glass boat
- Help needed.
- Come One Come All Ozark Gas meet
- What oil for tuned zenoah?
- Titanium Exhausts
- Dyno Testing
- Rio 51 Tuning
- water cooling for homelite/shaft
- swapping out stock trim tabs for adjustables
- Arrowshark fighter cat.
- Toxic al vs dominator full mod (only these motors)
- blade v hull good or bad
- Dumas Scarab 60 problems
- turn fins how deep
- Deep-V or Cat?
- NOOB needs first gasser advice
- homelite mods and parts
- volvo nimbus broken propshaft
