View Full Version : 3D Electric Flying!
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18]
19
20
21
- Will order on Hobbylobby tonight,, shockflyer motor etc,,,
- check this out, FOAMTANA
- Flight time on apogee 840mah and AXI 2208 34?
- speed controler
- What foamy and equipment to get?
- Axi 2208-34 / Extreme Yak 55??
- two new 3 d foamies I designed
- TRIBURON BI
- phoenix 35 problem
- Havoc
- What's the best?
- hell raiser setup
- Mini Funtana is Sweet
- Levi & Brooke (3D Foamy Models) has a NEW BABY GIRL!!!
- Shock flyer question
- What am I missing at Columbus OH?
- New Ikurus nenemes,yak 54,and f3a shockflyers!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!
- Which battery to use?
- Hell Raiser First Flight
- Tribute-Reinforce Landing Gear?
- MOVED: Thunder Power or Kokam Li-Poly ????
- Havoc 3d
- Knife Edge?
- new shock flyer is awsome
- g
- Phoenix 25 - e-flight 370 won't throttle up!!!!
- Shock Flyer Motor dead ???
- few shockflyer questions
- Good Transmitter for 3D Flying?
- Right trust for the shocky
- Which Wattmeter??
- **NEW** The Advantage Bipe
- Edited.
- AXI 2204/54 setup
- Lipo question
- Source in UK
- Maidened my 330S Shocky in a gym - ouch
- more crazy eflite ultimate questions
- 3D Foamy
- Just ordered the Edge 540 Shock flyer!
- AXI 2208/34 on 3cell problem, HELP
- Himaxx and Shaft Size
- Carbon control rods
- need help with electric motor choice
- Which shocky
- New ShockFlyer Yak
- any one have the Miracle
- EXTERME FLIGHT YAK-55SP-E ITS HERE!!!
- BPLR Reflex
- Praise Where Praise Is Due!!!
- Shockflyer - should I leave off the landing gear?
- Run time problem with Himax 2025
- Best gear ratio for Himax 2025-4200
- Fairfax County Virginia law on flying R/C Aircraft in county parks.
- Need advice on brushed motor for e-flite Ultimate
- What prop with AXI...
- Don't know what to get
- Gear drive V.S. Direct AXI-noise
- SHOCKFLYER W/STOCK MOTOR - NO GOOD!
- all balsa TRIBUTE
- MINT HILL HOBBY SHOCKFLYER VIDEO!!!
- Weighing with electronic scale
- AXI motor question
- GWS / APC prop use with brushless motors
- 3d Foamy Citabria Review
- Li Poly charging
- shock flyer power setup rookie
- Have you tried this Raven???
- Li-Poly charge rates
- ULTIMATE w/ axi and general question
- Attitude with outrunner???
- Collapesed antenna???
- E-flite ultimate prop selection question?
- elevator install on 3dfoamy edge
- Not enough throws!!!
- Shock Flyer control surfaces
- Gear lub
- curved foam sheet
- E-flite mini funtana when is it coming out?
- New Forum Featuring George Hicks!
- Ultra RC 3D Buddy
- Protech Tojeiro
- What are the 3d prop sizes for electrics like 2025
- Can I use lipo's with a schulze 11.20e ESC?
- My new Proud Bird made with Ultrafoam
- Mini3Dx Test Flight Video
- Troll F3AI over the pool
- raptor
- New or Used? What is best way to get into 3D electric planes?
- Phoenix-10 controller question
- Japanese cover
- Shocky Extra 300S has crooked tail
- which 3D is good for this brushless
- Pigi 3D landing gear
- What electric 3d plane is there for hacher b20 18Lm, schulze 11.20e ESC.
- shocky bipe conversion
- side thrust on foamies??
- How do you keep prop collet on Himax gear box?
- Look@me Evo, Challenger
- 3rd plane...looks really fragile :(
- Shock flyer build tips
- Rounding 3D Foamy Leading Edge
- Flew my ultimate, think I fried the motor :(
- Ikarus Superstar Flies Great
- Raptor
- himax 2015, 4100 or 5400 ?
- 3D SlowStick 2025-53..
- Exponential setup for Shock Flyer ?
- Does this sound like a good setup for my ultimate?
- cells for a e flite ultimate
- Phoenix 10 and AXI 2208/34 Problem
- Where can I get AXI 2208 bearings?
- SERVO CHOICE
- 3D DESIGN CRITERIA
- Learning to hover?
- Yak 55SP-E Anyone?
- 350C RIP need cheap relacement
- insanefoamies help.
- 3D Foamy Extra
- Superstar Shockflyer Motor Help
- New videos---T3DIII YAK54
- Prop Sizes and EPA control
- Depron is here !!
- Raptor Bipe CG
- Hybrid Foamy Katana
- Quique 72" YAK-54 video..Electric conversion
- Radio programming for ultimate
- DIY Variable Pitch Shockflyer!
- PJS 1000 3d (amperage/wattage)
- Servo /control surface hookup question on a foamy
- Stevens AeroModels G-400(Stella)
- finishing my shockflyer without the motor
- Foam Safe C/A alternative?
- Aerotech Foamies
- would this fly?
- Raptor Build
- Sealing Hnge Lines?
- Best Indoor Bipe
- Smoke for my Ultimate!
- Alternative to Hitec 55 servo?
- Video: Dragonfly electric 3D
- MOTOR CHOICE SHOCK FLYER
- shockflyer quick post!!!! Ikarus upgrade? best combo??? What up with that
- Shock Flyer Performance with stock (brushed) motor????
- My Latest Airplane
- Which has the best product?
- MJP Carbon Mounts - Awesome!
- Post Your Indoor Shocky Videos
- Just got the Superstar Shockflyer in.
- Fun-Tastic 3D.
- need plane and equipment suggestions
- E-Flight Tribute
- insanefoamies.com?
- Engine/Airframe/Prop selection calulator?
- Shock Flyer and AXI 2208/34
- Is fan fold foam better then Depron?
- E-Flight Ultimate
- portable planes?
- Finally picked out my new plane :)
- Foamy Factory-Ultimate 30
- battery connector
- Fancy Foam Models 300L
- LiPo battery pack configurations?
- Foamy 3D Staggerwing
- Learning to Hover (gear/prop)
- T3d video !!!!!! lots of fun LOL
- Foamy cost?
- extreme flight yak
- 3D Foamy finished weight
- cutting 45 degrees angles
- Shocky Brushless wiring help
- Receiver for electric 3D
- hangin' out
- SHOCKY VID!!
- shockflyer video
- Plans for POT-03
- triton or astro 109?
- Shock Flyer EXPLOSION carbon fibre pulverized
- Help with amp draw - new PIGI flier
- PIGI - tips? how to build it?
- 16 ozs 3D plane: which motor set?
- Max amp load
- Nice shocky mount
- 3D Foamy Tiburon BIPE Video!!!
- Tribute setup question.
- shockflyer wing problem...need help
- synergy shockie
- RAPTOR BIPE
- CD-ROM Brushless Motor.
- Wild beast battery compartment
- AXI 2208/34 prop adapter ??
- AXI 2204/54
- Shock Flyer Carbon Fiber Mounts
- Eflite Ultimate flight problem
- Foam plane construction>help!
- Electric 3D Planes
- New Raptor
- Potensky Eagle landing gear assy prob, anyone?
- tipover on landings
- Hey Levi
- Mountain Models Panic
- New Norwegian extreme 3D indoor
- Which AXI for shockflyer
- Help select electronics for my E-Flite Tribute
- 3D Foamy Extra!
- Shock-Flyer with Hobby Lobby PJS external rotor?
- How is Ikarus brushless setup for Shock-Flyer?
- Hell Raiser C.G. help
- Recommendations For Tribute setup
- Other than 3D, what other planes or Heli's do you own
- Tiburon Bipe Kits are here!
- 3D foamy in Australia
- AILERON THROW ON EFLIGHT ULTIMATE
- Createx Paint
- Batteries for 3D Foamies
- What 3D plane for Astro 05 motor..?
- Looking for a clam shell heatsink for 2015-4100
- Shockflyer with Geared 370 motor
- AXI 2208/34 2 or 3 Cell Lipo ?
- Levi's web site
- Elevator on Tribute 3D keeps on breaking!!!
- video
- funtanaS 140
- nothing on tv, well then!
- MOVED: NEAT event
- 3d with a wing?
- Hacker Programming box
- 3D Foamy
- Best battery motor combo for Shocky
- Any Inf. in The Blitz Epp , any Videos???
- Fliton ICON 312
- ExtremeflightRC Yak55SP-E...Sweet!
- Foam Ultimate engine
- sanding edges on Depron?
- Flex 3D???
- Desgins
- Prop for Eflite Brushless 370 in GWS 6:6-1 gearbox
- Motor quits when advancing throttle
- BRUSHLESS MOTOR "CHATTER"
- Carbon Fiber rods...
- Anyone Flying The E-flite Mini Funtana ??
- why delete a photo contest???
- 35% Scale Electric Foam Extra 300LX!
- The $100 Picture
- My new "Revoh" by Sirknight
- Hacker B 20/18 vs Mini AC 1215/16
- [Deleted]
- axi 2208/34 rough at low speed
- Im thinking on of the best 3d planes ever!
- Tribute 3D Thread....Here we go...
