View Full Version : T-Rex heli
Pages :
1
2
3
4
5
6
7
8
9
10]
11
12
13
14
15
16
17
18
- OMG! the best birthday present ever!
- Can you loop or roll in normal flight set up?
- T-Rex 500 Pictures
- Servo arm for a 600E
- All kinds of rotor head problems
- Tail Rotor Gear Drive Question
- Thuderpower 2070 extreme lipo question
- a109 fuse
- Night Flying
- Part # for V2 parts
- Horizon Ad Above, click for lower price!
- Night flying blades... are these any good?
- question about the swash plate....
- Flight Power Charge plug
- T-rex and JR 8103 Dt programming
- question about the t-rex head....
- HELPPPP what happens hereeeeeeeeee
- Futaba 6ex fasst radio question.....
- Helimax Pitch Gauge and Trex 450
- 600 E Normal Set-up only ?
- T-Rex se or V2??
- TREX SE V2 Build Log
- Exact Settings with Futaba 7C and 450
- help with blade tracking please
- Trex 450 XL upgrades
- optic 6 / 450se
- Trex450 backup parts?
- T-Rex 600 with Logitech 6100T problems video
- Set Up DX7 and SE V1
- Is this a good deal?
- What to do with all of those wires??
- Trouble installing HS-56 servos into trex 450
- AR7000 receivers placement pics for SEv"
- Anyone using a cc thunderbird esc in their TREX 450?
- why trex?
- WOW! TREX 450 and my First Flight.
- Tail servo randomly becomes non-responsive
- JR 8103 rudder offset in hold?
- Gyro rec.
- A123 batts in a 450
- question on a servo package
- weekend pics
- One-way bearing going or gone?
- This Hobby really is a $$$ hole!!!
- DX7 with AFPD and G3.5?????
- My T-Rex 450se V2
- 33 flights now and I
- question about pitch in normal flight
- Please help me with my battery pack!
- Where can I get custom align stickers from
- Trex Headspeed tuning
- 450SE V2 combo? worth the money?
- 450SA and DX7/6100 question
- Futaba GY611
- DX7 receiver power
- glitch from radio or something
- Better 1-way bearing solution???
- Anyone flying with 14.8 Volt lipos?
- HS 55 servo...
- Jr DS821 on collective
- Trex setup
- My T-Rex 450 won't turn right!
- SE V2 swashplate flawed?
- I need help picking which trex 450
- What happened to the JR Voyager? Compared to T-Rex?
- SE V2 frame threadlock
- HS65HB servos srews??
- Compatible parts to use on the 450S ??????????
- decent servo arms
- trex 450 / dx6 or dx7
- Bent Blade Grip on CNC Head for T-Rex 450 SE
- aLIGN 350L motor case
- Could you suggest a good 400 to 450 electric heli?
- Loctite Blue on T-rex 450?
- Trex 600 battery question
- setting new align 35 esc
- Please drool over my new TREX and then Help me!!!
- Lipo battery monitor
- Dumb question
- Can't get the T-Rex 450SE off the ground DX6-Tx and AR6000 Rx
- TRITON CHARGER QUESTION
- yet another noob question!
- GY401 Double Flash on T-REX 450SA
- zoom 400 head speed
- T-Rex 450se V2 weight
- TREX 450 SE V2 Kit + startup
- Help with Tail
- Need help with T-Rex 450 SE setup ..have AR6000 Rx and DX6 Tx
- is it better on grass or paviment?????
- who owns 2 450's (or 600's)
- question about the fly bar and rotor head.....
- 5.1 V REGULATOR 600CF
- MY Trex 450 Nitro
- What have you done about glitching?
- Problem with New T-Rex 450se V2
- on line manuals
- Ball link sizer ?
- CopterX vs Trex 450SE
- Finally did IT!
- How do you Tach?
- Trex 450 size heli
- Being noisey LHS used a term
- Futaba 6EX FAST Tranamitter question...
- Diablo takes on the T-Rex; the winner is...
- zoo 400 protech , which lipo ?
- 450 Starts out fine then gets "jumpy"
- What are "V" blades
- Best servo choice for Trex 600
- I cant 3D with my 450 SE. no power! HELP!
- Align 430L shaft sheared off in flight.
- Noob with no friends for a trex450se v2
- TREX450 SE V2 Alu case?
- Tail Wagging
- AXI motor long term review
- Tame down the Trexx, how
- Trex problems
- HeliHobby Combo package thoughts
- question about Volts
- Align dealer near Montreal-Quebec ?
- Gyro servo Futaba 9650 or 9257?
- Think im going to buy a t-rex and need advice
- question about this indicator in the DX7
- The worlds most expensive McDonals toy.
- Align 35A set-up info
- Stepping Up!
- new T rex sa owner
- Link to download trexes on flight sim.
- what is wrong with my t-rex rotor head????
- what is wrong with my g401?????
- Trex and JR8103 Programming
- Best trex Carbons: radix or vblades??
- Thunder Power Extreme 2200 Lipo in Trex
- 3-point v. 5-point throttle/pitch curve
- how tight should the blades be????
- Atlanta Hobby
- Copter X
- help here with "autorotation switch" in the DX7 please...
- They said "you will crash"...
- Can a 450SE owner measure something on their heli for me?
- whats the difference between v1 and v2
- cheapest t-rex for RTF
- Best lipo battery, recharger, where online?
- tail pitch control arm
- No Throttle reaction and Jittery servos
- Hover glitch
- what is a CCPM interaction in the swashplate?????
- slight crash.... what happened here??????
- Trex 450 belt needed
- Which [good, digital] Servos for T-Rex 600?
- Trex 450se tail Torque drive
- my t-rex spins too fast!!! help please
- Confused on which tail servo to get for t-rex se v2
- New T-rex 450 and JR XP9303 set-up
- Got me a motor and speed control...will it work for a 600??
- differences between t-rex se and se v2?
- trex 450 settings Futaba 6EX
- Flying at an angle
- Help with this speed control and motor pleaseeee
- Gyros on the elevator and aileron axis...
- JR 410 Gyro
- Tail Drive Gear Assembly
- Crash update...broken tail drive gear???
- Case for T-Rex 450
- 450 spins like a top please help
- First crash wasn't from flying...
- Radio choice for Trex450 SE V2?
- Trex 700
- T-rex and Kickoff Sunday....
- How many Trex 600 models ?
- FAST S9257 EP digital rudder servo!
- TIGHT BLADE
- TIGHT BLADE
- 2 out of 3 HS65's bad???
- DX6 swash setup problems on 450S...help
- T-Rex
- 430L Motor Smoking.. any ideas?
- Need Help with DX6 Gyro Adjustment.
- Trex 450s
- Battery question
- A GOOD DEAL
- What battery for my Trex 600?
- trex frame
- Ebay Batteries. Anyone done the Hong Kong order?
- BEST SERVOS CHOICE ?
- Autorotation Gear Wobble
- rcmachine..ebay,anyone ever use em'??
- what should i get??
- Should I buy this used TREX ??
- tailcase spining and crash
- T-rex 600, Raptor 50 or Hurricane 550?
- 450S Gyro mounting
- FINALLY ASSEMBLING T-REX450SA
- All right! FF flight.
- Got my New Canopy!
- New tail combo alert
- Switching to T-Rex
- DOWNLOAD T-REX ON REAL FLIGHT...
- Tail unit slides forward
- cheap 450 parts
- Too many TRex Models!!
- anybody else fly like this?
- Was considering a Trex 450 for 1st heli, not so sure after trying sim
- Accuracy of Dimensional Info for Setting Up Control Ball Linkages
- Pigeon 450 SE and Trex 450 SE
- 450XL with Futaba 6EX
- One way bearing
- Normal pitch and throttle curve
- Any other TP "extreme" users out there?
- pitch question..yes I searched!! ha ha
- 9,10,11 tooth align pinion gear doesn't fit 450?
- Help a Noob get in the sky
- Anybody from CHICAGO
- My best score was 951
- copterx alum head.very nice except.....
- Tail control rod guides loose...
- Trex 450S tail question
- TREX 450SE V2 Replacement Motor Advice
- simple headspeed question.....damn noobs ha ha
- Payload
- 450S flybar build and question
- LOOKING TO BUY THE T-REX 450SA PACKAGE FROM RCANDME...
- T-Rex 450SE pricing
- Help building my Trex 450se cde
- anyone use cp pro gyro on a trex?
- Anybody have a .12 size nitro bird?
- Ah, please dont be as Dumb as I ;)
- Video: Trex 600 and 450
- T-Rex 450SA vs 450SE whats REALLY the difference?
- Newbie and U Bec
- Is it really Necessary to Have an SE?
- Programming the RCE-BL25X/35X ESC, Align
- Servo Arm Centering, Spektrum S75 Servos
- Need some LiPo help
- A Noob In Need Of purchasing Advise!
- Battery Safety
- Assembling EC3 Connectors
- Rotortech 350mm Blades - DO NOT USE!!!
- newbie...DX-7 and Trex 450xl set-up???
- is the Trex450 XL a good heli ? please let me know
- Trex 450SA Building, What components?
- Trex SE ok with this gyro and tail serv?
- regulator significance
- Who's got the best price on Trex 450 combo deals?
- Trex 450SE V3
- Power Shortage??
- Got my Diablo head and tail on...
- Killer Trex
- Bone Stock TRex450SA doing 3d?!?!
- PULSING MAIN ROTOR
- Nearly had a bad one today
