- 5945 mg servo inaccurate?
- Multiplex Cockpit MM - Combat Wing settings
- Am I stuck with these Karbonite Digitals?
- 5945 version?
- 5995 VS 5955
- New 6635 servo
- Why are my 5745's dying???
- 5975 going full throw
- 5600 Series Digitals
- hs-81 parts
- QPCM receiver and dual battery plugs
- hitec electron VERY unusual problem
- 5645 + Y + Futaba PCM
- HT 81/85 on 4 stroke throttle
- question about servo programer
- Amperage draw on digital mighty minis
- RCD 3000
- Multiplex LN-5014 Multi Charger
- cyclic rings for hitec optic 6
- hitec optic 6 programming
- dead band settings on hitec 5945 servos
- Hitec eclipse 7 programming question
- Glitches after battery charge
- Problems with 2 new QPCM receivers
- HiTec 625 screw
- Electric Glider & crow mix ?
- Tx battery disconnect and memory Question
- LiPo for flight pack
- gear slop already?
- Trainer Cord
- Problem with 645 MG
- 85MG-225MG-5245MG
- New 5945 oscillating
- MultiPlex 3030 Issue Help
- Please Help!!! Optic 6 Throttle Problems!!!
- Which Servo?
- New Hitec Receiver?
- hitec focus 4 needs repair
- Matching Servos With Programer
- Hitec 555 vs newer hitec rx
- Swapped crystal - changed trims??
- 5745 vs 5735
- Disapointment with Eclipse7
- Question about elevon setup on a Flash 5X radio
- Can I use 2 bobbins to shorten antenna?
- glitches aagh!!!
- Compatibility issue with Hitec 56HB servos and FMA M5 receiver
- Hitec Eclipse7 weak in Positive shift mode
- Hitec 635 HB use not as originally advertised
- Hitec Electron 6 Rec Hates my 9z
- Removing SWB servo arms
- Frustrated with EVO mixers
- question about hitec servos and aluminum horns
- how to remove bottom bearing from 5945 gearset
- Small problem with my Evo9
- very noisy 5945 v1.03
- Radio request possibility
- I need a good mixing-Transmitter
- Optic 6 setup questions?
- Current draw for sail serv?
- Hitec Optic 6 V-Tal mixing question
- Lerge scale steering
- 5925 conversion to 5945
- Lost Plane on first flight
- Hitec 5645s and Airtronics PCM??
- Programmer with Version 1.04
- EVO 12 - Servo Jitters
- HS605 dies, model too.
- Hitec question for Mike Mayberry and Tony
- hitec laser 4 using rudder ch4 question
- the correct way to place rx antenna
- Lost Plane
- HS-5245MG
- programmer 1.04?
- Hitec Challenger 720 Receiver Question
- Latest news on 5955?
- hitec optic 6 setup with ucando 3d 46
- Changing from 75MHz band to 72MHz band?
- HItech 5645's wye problem w/futaba pcm
- HItec-HS5645MG smoked on me!!
- My Eclipse 7 Bit it today and bit my plane..
- Hitec 805BB servos and Rx batteries
- Hitec 5745 problem
- Programing V1.04
- Digital hitec servos vs Futaba receiver
- HITEC 8 CHAN DUAL CONV (SUPER SLIM)
- Where to buy multiplex in Asia
- Hitec Service Ignored My Problem -- AGAIN!!!!
- Hitec 3 Minimal Transmitter Range
- Hitec Supreme Receiver Freq crystal range (high/low)
- 5945MG servo-some droop some don't
- Hitec 5245 locked up
- New Qpcm receiver acting strange
- t purchased 3 6775's and 2 of them ar
- Challenger 620 module
- SORRY LADS, NOT GOOD ENOUGH...
- hi tec reciever with futaba digital servos?
- HITEC 15MZ
- FUntana 90 and karbonite servos?
- Hitec 5945 question
- V 1.03 Vs 1.04
- Servo "steps" with Multiplex RX 12 synth IPD
- Karbonite Gears?
- HS80MG Question?
- Peculiar digtal servo failures.
- 225MG??
- 5955 will they ever be available??????
- Servo Programmer question
- split elevator problem
- Eclipse challenge
- Differences Between Multplex 12 EVO & 4000
- lipos in an optic 6
- Wanna use Electron 6 RX with Futaba 9C
- HS 5995 TG in a savage 25?
- How much current I need?
- Hitec 605 failure...twice
- hitec 5995 tg
- V1.04 Programmer update now available.
- 635 HB Bad Amplifiers
- Eclipse Setup for Twin Rudders
- 5645MG consumption
- HS 635 HB issues and queries
- Just wanted to let you know (Hitec Digitals)
- Hitec buddy box
- Mixing Hitec and Futaba Crystals
- Giant scale and 5998
- Spectra Part No for Optic 6
- Hitec servos 4-1
- hitc ranger 2 ch t¿range trouble
- Eclipse 7 question
- Optic 6 - Changing 40MHZ to 72 MHZ
- hs-645 slop question
- Hitec 69** series on a Funtana 90???
- Optic 6 EPA Ambiguity
- 5945 beeping
- need info on charging the hfp-10
- Hitec Service Sucks!!!!!
- Trainer cord from Hitec Eclipse to Futaba 7CA
- Hitec Programmer Battery/Charging
- Optic 6 Programming Lockup
- Follow-up "Hitech 5645mg not working with Y connector?? "
- Multiplex Evo 12
- how to check service
- 81MG Jumps
- Hitech 5645mg not working with Y connector??
- neon ss transmitter chargening
- Optic 6 Upgrades
- Optic 6 Mode 1 and Mode 2
- digital servo failsafe
- Amps through HPD-07RH?
- HELP! Smoked a Laser 4. Now what???
- Hitec Support?
- Expo on Optic
- How much battery do I need?
- EVO 9 LED problem
- HELP 5625
- 5945 v1.04
- Hitech 635HB Servos for Sig Cap 231 EX ARF
- problem with laser and reciever
- 5945 Defective servo
- Optic 6 Slave Channel Behaviour
- Multiplex evo
- When will 5955 servos be available again?
- Is this servo enough power?
- Eclipse 7 gimbal spring lever
- Hitec Karbonite Gear Set
- Gearset compatibility between different models?
- Firmware v 1.04
- Hitec Flash 5X voltage
- Mike, what is Multiplex's position on Li-Ion Battery for EVO?
- Stall current for 635HB
- Seperate Battery for 5945
- Assigning Channels for compatability
- Hitec 645 jitter
- Eclipse 7 flight conditions and idle RPM settings
- Hitec Warranty?
- super slim receiver
- Hitec Eclipse, low throttle trim
- Which Receiver
- Lithium-Ion Battery for EVO
- EVO9 FLAPERON BUT NO AILERON CONTROL
- Servo Recommendation
- Evo 12
- test
- Optic 6 Update Offer
- Optic 6 Design Flaws
- HITEC QPCM receiver question please..
- Hitec Flash 4X, transmitter battery
- Ham crystals?
- Hitec HFS-05MS 5-Channel SC Micro Receiver
- bugs on Optic 6
- Spectra Module clip fastener failure
- Dual elevators without ailevator
- Hitec Service?
- Hitec Programmer v1.03
- Flash X Mixing
- Hitec/Galaxy 8
- Scanner module
- Profi 4000 mixers
- Eclipse 7 mixes
- Optic 6 buddy cord will not work
- General E7 Questions
- Hitec Focus 4 Problem.....Help
- Optic 6 throttle set-up
- Optic 6 flaperon configuration
- Eclipes 7 to Eclipes 7 Q-PCM
- EPA >100%
- Optic 6 firmware version / extra part
- hs-625 locktight
- 5955tg any idea when?
- Hitec Spread Spectrum Radio
- Servo issues with 645MG and 545BB
- optic 6 blue light
- Eclipse 7 - moving channel 3 assignment
- Programmer Question
- Has the 5995 programming issue been resolved?
- Question on 5955TG, neeed template to cut off servo bay
- hs-5245mg servo's
- HS 5945 MG question
- HS 635HB Gear Train
- Hitec Eclipse user's manual online?
- Hitec Eclipse 7
- Optic 6 right and left levers
- Optic 6 Software Question
- my urgent hitec concirn
- HS-50 question
- 5945 V 1.04
- Hitec 5945 not responding on Y
- Optic 6 availability
- Multiplex 4000, 3030, 3010 Synthesizer Rf Module
- Oops !
- Spectra Behavior During Battery Run-Down??
- Optic 6 Battery Rundown Results?
- Optic 6 ADIF/CROW Interaction
- CRX with Futaba reciver?
- Hitec feather receiver charging
- To Mike or Brendon....Optic 6
- 475hb,6635hb,6985hb gear train
- Hitec Electron Receiver
- Antenna Question
- Hitec Feather Replacement Antenna
- Optic 6 Recompile??
- Flash 5X Problems
- Hitec 3500
- rewiring leads to a 5645 from Z to J
- Hitec 555 receiver antenna
- Low Band/High Band
- Hitec Eclipse7 or Optic 6?
- 5945 with Version 1.04 firmware
