- are these airplane-only batteries?(just making sure)
- Am I missing something obvious here??
- Tenergy 8 cell nimh 4500 in a VXL
- 3000Mah Ni-cd pack for 25% Yak-54
- Charging LeadAcid batteries with truck?
- trying to order tonite
- how do I balance a 10 cell or 12 cell pack
- Monitoring LiPo discharge voltage
- been gone for years!
- 7-8 year old Hobbico Accu-Cycle Pro series charger Question Please help!
- A123 packs reached 193F and still charges fine
- Li-ion battery charger
- Hyperion LBA10 NET Kong Power harness?
- parallel battery connection
- Profi-home-charger
- what size lipo battery
- Bantam 301DX and 12 Volt 7Ah Battery...
- charge me up.
- Air vs Land batteries
- Ballancing Chargers
- FMA 4S, CX2, Mini-T, E-Flite LiPO's... Make it all work together?
- duralight battery stored 2 yrs
- Triton Troubleshooting
- ANSMANN charger not charging??
- cutoff voltage?
- LiPo question
- LiPo Battery Basics
- Nifty Lipo pack build program...
- Woops!
- Recommend me a budget lipo charger for small lipos
- trickle charge nimh?
- Minimum battery capacity to power servos? (4x3004 & HS55)
- Alpha 4 charger.... Is it still a good charger?
- lipo setup
- Why?
- Team Checkpoint TC-1030
- How long to charge?
- Battery Cycling Question
- How do I make this charger a "BALANCING" charger?
- older ace charger problem
- Reduce Charge Current
- LiPo cell general information and storage notes!
- Please read before posting a thread
- Lipo VS A123
- Using non-standard battery packs
- used batteries
- Welcome Duralite!
- Li-Po started a fire what can I do?
- Need help Locating a charger
- What should I charge at?
- Litco Alpha 4 manual
- Maxxprod?
- Can anyone recommend me a good charger?
- charging AA's
- Bosch Litheon
- Parallel connector glue
- Swallow Battery Charger.
- MH Forming Charge w/Accu-Cycle Elite
- Ofna DigiPeak 3 charger
- INTEGY "EAGLERACING 1600 MAH"
- Dual Gell cell circutry help
- please help me find the right battery charger
- Rule of thumb
- batteries 7 cells have moisture inside heatshrink.
- charge larger than 6 cell A123
- Help, and I'm sorry.
- URGENT PLZ HELP
- fall/winter 2007 best battery mfg poll
- swollen charge...
- A/C power suppy?
- GP2200 in mini
- IB4200's exploding?
- Which Voltmeter???
- Batts been stored for some time...
- capacity per cell
- New Battery
- ace digipace 1 Question
- How big of a battery
- Need more then 1c charge rate charger
- how do I determine flight time
- 2S2P brick pack - pictures please
- A123 Chrager list
- Experts: How does an ESC actually work?
- BEST Li-Po Battery Mfr.
- Building battery packs from Dewalt 36 volt battery
- li po batteries
- two batteries on one switch?
- storing lipos? avoid cold? heat? room temp? refridge?
- LI-PO batteries for GP Yak-54
- Duralite Plus Li Manganese
- increase conductivity and reduce R
- CELLPRO 4S
- FMA Announcing Cellpro 10s Charger
- check balance tab wiring
- Battery Question
- Need help with ElectriFly PolyCharge 4 / Equinox
- Swallow 2 ac/dc charger calibration.
- Upgrade for Heng Long metal Bullbog ?
- a123 build balance tab diagram
- How many and how much battery
- DualSky Li-Po and TP210 – are adaptors required?
- Battery checker question
- BEST Li-Po Balancing Charger
- Wallcharger and 5 cell Nimh
- charging 4 vs 5 cell nimh w/ wall charger
- digital servos & battery
- Tx/Rx charger question
- Wiring 2 5s packs in parallell
- Red: Well, done it again!
- Flight Power Battery
- Sparked a Apogee 3800 3 cell
- voltmeters and voltage reading chargers
- Who sells Saphion packs in the USA or Canada ?
- How to connect Hitec BEC receiver Y harness, and on off switches
- Good source for transmitter and Receiver battery packs?
- Charging on race day.
- 4 2300mAh 5s packs in a 10s 4600mAh configuration
- DuraTrax Battery's???
- I need a good Balancer
- Venon 1200 NiMH in Airplane
- What type of balance tab is this?
- Benefits of Discharging lipos???
- Hobbico EP Select batteries
- What yall think about this charger???
- Swallow 2 ac dc Charger
- Thunder power battery with electrifly balancer
- Orion 4800 li-po
- Battery size suggestions
- A123 2S2P 4600 mAh saddle pack?
- tp 1010
- cellpro 4s
- multiplex charger ln5014
- Large voltage sag under load
- proper charge for a 7.2v
- Charging off 12v gell cell
- Charging Tx & Rx from Hobbico Power panel
- A123 setup help
- charging a 7.2v 5000mAh NiCd
- Just got my Brain 989
- 9.6V 220mAh NiMH
- How do you???
- Parkzone lip and ICE charger
- 7.2V HIGH discharge vs 8.4V batt??
- Chargeing LIPO to spec voltage?
- Discharge power?
- battery & charger questions
- new smaller a123s
- Fast and safe charge for NiCd and NiMH
- new to lipo battery's
- Sub-C vs. C cell
- A little help with simple calculations please
- Batteries
- Orbit Poctetlader
- expanded volt meter defect
- A Round of New Batteries!!!!
- which battery e savage
- Battery/charger question
- Switching leads on charger
- Super Brain 977 connector pin ( noob question )
- Should NIMH batteries be discharged?
- Battery chatter?
- New 1100 mAh A123 available everywhere and no word here!
- Clean up you charger cord mess
- Balancing/Charging 20S li-poly pack?
- Prophet Sport??
- I need a source for NIMH batteries, receiver and Hitec servos
- building 6 and or 7 cell packs//E-maxx info needed also
- How do I charge eneloop battery packs?
- uick Question: Does the fma cellpro 4s come with bannana plugs?
- Which charger?
- 18 Amp hour battery 12V power alternative
- Can I use the Hobbico Torqmaster LC battery for my fma cellpro 4s charger?
- Lipo EXPLOSION due to impact (picture with smoke)
- Tenergy batteries any good?
- Digital Piranha "hop-up"
- Equinox balancer. What the heck I am doing wrong??
- What is the cheap and best A123 charger & A123 balancer?
- best charger
- balancing with blinky
- Two 3s 3200 Li-Po's in series Chg ?
- Hanger 9 sure cycle
- balance tab A123
- Batteries
- Triton2 Low Input Voltage
- Vehicle Charge receptacle/plug
- NIMH Charging/LIPO for RX battery?
- A123 for glow starter
- how to configure A123 set up
- Having major problems with batteries
- what type of 123 should I use
- EP4200 battery and MRC 989 Charger question
- Which Power Supply to choose for DC only charger?
- Duratrax Piranha Voltage Question
- set up for 1/8 buggy
- Need a new battery
- Number of Flights
- a/c d/c swallow
- Forming batteries or cycling
- phoenix 80
- LoPo Pack For 1/10 Scale Brushless Setup Sugestions.
- Way off topic(lead acid batteries)
- Discharging Batteries - Need Help
- A123 2200mah Racing Pack as shown in RC Driver
- IB4200 VS radioshack GP3300
- Dynamite twin peak charger?
- Lipo "Swelling?"
- FMA Cellpro 4S Lipo Charger (call for all users)
- learning to solder batteries
- Discharging SMC 1400 pack
- 123 how to
- Help me select the right charger!!
- Speaking of cheap batteries
- General guidance 977 and 3300 charging needed
- CHEAP BATTERY
- Ruined Lipo?
- Lipo completely discharged
- Losi Lithium Charge converter
- 7.4v 4800mah Batt. In place of a 11.1 2000mah batt???
- Ice Charger Help
- Duratrax ICE - problem with screen
- 1/18 scale A123?
- important information
- Help me...I'm about to buy a hyperion 5i charger off b-p-p.com
- Charging Pb batteries?
- Li-Ion and Triton JR Problem
- Charging NiMH for the first time??
- Servo Twitching Problem
- Homemade discharger.
- Stock E-Flite charger (CX) no workie with Thunderpowa?
- ALIGN LIPO CHarger and Balancer
- Soldring plugs onto reciver batteries... Servo plugs too.
- good chargers for around $150?
- NiMH Battery Draining - Wow
- Battery Soldering question
- Best NiMH batteries?
- Triton problem
- Exploding A123 cell
- AirHogs charged with Alant mosquito charger.
- Best home 20A power supply and best compact 5A road power supply.
- Safe to store lipos in the car?
- are these any good?
- Starter box gel cell charging
- Intellect battery packs
- New e-Station LP-6 Lithium charger!
- Adapter for Parkzone batteries to Thunder Power balancer
- Battery pack soldering issues, Help!
- nimh battery question
- Flyable voltage value for 6v systems
