View Full Version : Beginners
- Throttle came on unexpectedly
- new brushless
- Builders near waterford Mi
- Need advice for how to start this hobby...
- Help with new engine
- Tips for cutting out elevator joiner location
- new to charging lipos need help
- Bringing a plane back to life safely
- ok question on flying a top flight 182 cessna
- Inverted engine mounting ?
- Found A Great Plane At A Thrift Store..Need Engine Recommendation Please!
- Building my first wooden plane!
- Dynam HawkSky - nosedive special
- Another Guess this plane post. LOL any ideas??
- Tower Hobbies Starter on LiPos
- Is it better to use seperate BEC instead of the one included with the speed control?
- Flying at a small town park
- Newbie with 10 seconds of flight time
- Doing a weekend aerospace engie project, preferrably a single-spool turbojet, help?
- New RC for a young beginner
- Building Again
- Airplane Recommendations
- help with setting throws on a new plane its shows set up in degrees i use inches
- Beginner 4 Channel Plane recommendation
- yet another prop size question this time for a .91 super tigre motor
- G 20 engine help
- Need help with figuring out how to hinge this arf
- toggle switch
- Restarting Hanger9 Alpha 40 after years in storage, and Hello!
- Is my engine running right?
- what prop size to use on os .46fx on a 40 size ultra stick
- How to loosen seized saito rocker arm pins
- Motorized Sailplane motor/esc advice needed (pics)
- Krylon Flat clear
- ok heres a question about reciver batterys
- First flight on yak!
- new computer
- Parts for my Seagull Spacewalker 120 size
- 3 axis gyro install
- Parkzone Visionaire help!!
- I made my first flight today
- Reversing A Servo
- throws
- Tactic ttx650
- throttle opening at idle?
- Hobbico electric starter question
- flysky fs-t6
- Building in a hot workshop
- help what is this plane I think it was from grwatplanes
- Correct Prop Size for breaking in Evolution 15cc GX gas Engine?
- Receiver Switch
- New plane
- Oh My not another new guy
- Evolution 15GX gas engine for Club Trainer 60
- First time electric flyer needs help on validating motor, ESC and LiPo pack
- phenoix 2000 issue with assembly rear control rods
- thor 45cc
- Nitro rc, cracking sound
- ok setting up a extra trainer i have with skis for winter need help
- Help
- which Beginner plane?
- Too heavy for Sig 4 Star 60?
- New-old stock kit build, Pica RC-38 Corsair F4U
- Sig 4 Star 64 in "kit"??
- Help, I need tips!
- Converting to electric
- NiMH Battery for RX, the achilles heel of your model
- GP Extra 300S .40 Servo & Battery Recommendations
- help new arf cub flying like a kite
- Did I Experience a Tip Stall?
- 3DHS 59" AJ Slick
- Engine break-in stand
- .60 Plane with Flaps
- Evolution 10cc on SIG FOUR-STAR 40?
- Thunder Tiger Pro 46
- wanna see what everyone here thinks happend to my control of a plane w/ expo set wron
- Building Supplies
- Hello All
- Inside components for a Great Planes 60 size trainer
- Help, 1st time radio set-up of FlySky FS T6 radio
- ok now that im done with training i wanna convert my hobbico 60 to wing bolts
- I need help with setting up flaps on ultra stick 40
- stuck in a tree
- Aviation Club at School - Aircraft
- broken piston ring in os max 40 sf
- ok next question is about servos buzzing
- One more question this one about expo
- hangar 9 ultra stick 40 dual rates
- Help with determining flying behavior
- new 8fg super , and the throttle cut seems to be reversed
- Almo9st crashed Smith Miniplane... have questions?
- Lost my SU26M to a stupid gum tree that sits at the end of our run way !
- Pulse XT Classification
- wind speed
- yes im a newb
- Free and easy fuel filler
- Evolution .46 oil drip...
- Landing Gear
- Question about engine mounting
- question about changing fuel type
- Mounting Dubro prop nut
- RC flight simulators
- Just couldn't wait... Broken shaft on Flyzone Cessna 182
- Esc 50 A Hobby King - SBEC
- Which battery charger is best
- New 4star 64 ARF build?
- Should one of my servos be humming ?
- Parkzone 300 extra
- How to mount fuel tank
- How to test batteries ?
- Amazon another option for RC
- Dl 50!!!
- Maiden SU26M Mezj 23x8 bit on the fast side!!!
- Super Cub
- 72 MHz or 2.4
- sig liberty sport with os 91.
- top flite cessna 182 need manual
- Mezjlik 21x11.5n 3 blade to a zoar 23x8 2 blade
- How to tell if fuel is good or bad
- asp 91 stroke throwing the prop
- 35 inch rc plane camera turret.
- Please help with installing glow engine fuel lines and tank!!
- Sig Jenny build
- A silent clunk?
- Blue Prints for Hangar 9 Alpha 40?
- Should I pull tank to check lines?
- propeller hole size apc props
- umx habu questions
- Help with F-14 jet electronics problem
- Kadet Senior engine size
- Question about single white servo cord wire in a used plane I picked up
- Went flying today
- Seagul Ultimate bi-plane arf
- Cracked engine mounting
- Unnionville UVH013 Norseman 63"
- bkeg
- Apprentice: Holes in Bottom of Fuselage
- New RC Flyer Tidbits – Part 1 - Intro
- pro balancer
- biplane flaparons
- Debate on Lipos. To balance or not?
- KS pipe for 50cc engine
- What voltage will burn out glow plug?
- The dreaded upwind turn
- Muffler help
- Nose gear steering
- The Electric Aviatrix is back...!
- Transmitter Trays
- Spinner to cowl gap
- "Big Scare"
- My first 4 stroke
- how to waterproof balsa contruction?
- 1st attempt at building a plane
- Great Planes Extra 300
- Canopy Su26M 50cc
- h9 spit retracts..
- Flying Range DX5e and Apprentice??
- can a single conversion crystal work in a FM-PPM ABC&W Filtering receiver?
- Maiden flight for my Apprentice S15e??
- Securing prop
- pz t-28 battery and cg
- seem on covering doesnt join up!!!
- Saito FA 82b throttle linkage problem
- equalizing elevator and rudder travel
- Mid Air !!!
- setting up flaps on a AR6210 Receiver
- Piper Cub build options
- Old timer airplanes
- Covering over Resin
- How to setup control service horn, elevator and rudder
- Free stuff near Clinton NJ
- gas engine compaired to nitro
- Help with Flaps
- need some advice
- TX programming for a beginner
- trouble landing
- Plane %
- Basic Skils: Turns using rudder
- Hey yall, new here with alot of questions.
- I am forever hooked!!!!!!!
- Receiver wont go to preset failsafe...or will it??? TOTAL NOOB question
- Which plane?!
- Sport plane Power Setup Query
- installed cowl on plane for the first time!!!
- PZ Albatros; control question
- FS 91S 11 "Need a Cover Plate" Cant get one in Aus !!!
- A good second kit
- Peak Models 50 cc Pitts python
- Maiden flight Seagull Extra 260
- Need advise and help on new project
- Lucky Day!
- Construction techniques 1970s and now
- Avistar RTF as trainer
- OS 91 FS Surpass - no compression - what do I do next???
- Help with stripped Hex Bolt
- New member in georgia
- P40E warhawk
- Help with fueling up airplanes with cowl
- esc question
- new to reracts help..
- First bi-plane
- Kadet Senior SPORT taildragger?
- bec problem?
- Hello from Biloxi Ms. / H9 p51 Mustang PTS top speeds?
- DX8 Servo Problems
- throttle on wrong stick
- Antique Plane Kit
- Inquiry about Glow Plug
- Oleo strut quesion
- good kit for a 9-yr old boy?
- Starting Over Again - Starter Plan needed
- Battery help !!!
- R.i.p
- how to hinge a thick aileron?
- Starting out - with no depth perception
- Did I just make a big mistake?
- World Models P47 Thunderbolt
- Converting servo torque in kg to ounces
- 20 year old abandoned trainer VS Beginner
- xoar laminated props
- Parkzone Ultra Micro T-28 Battery Swap?
- Proper way to maintain, store and test nitro engines without installing in plane
- Happy New Year
- Suggestions on where I should set the rod
- Xoar wooden props
- Noob- need part number for carbon cub ss servo epoxy
- Agm 30 good or bad?
- radio question
- Super Chipmunk
- Os 160fx - 0s 200fs p
- Pushrod Housing attachment on Apprentice S
- Seagull Extra 160-180
- Ailerons twitch when throttle is pressed 1/4 and above.
- My Forums
- RC Radio Airplane PC trainers
- Not sure what way to go OS 50SX or 61FX
- TX & Ni-MH batteries
- Side mounted carbie good or bad outside of the cowl?
- Beginner
- Is any day a good day to run in a motor?
- charging a Li-PO
- Seagull Extra 260 160-180 need advice on what sevos would be good for this plane
- jester_s1 I need your help
- futaba t6exhp
- Transmitters
- Beginner needs help with purchase
- Bi-planes
- New to planes Help:D
- First aiplane flight ever...success!
- more power or best prop for Goldberg eagle 2
