- Diesel Plumbing??
- irvin5 15 xr conversion
- Japanese diesel conversions
- Dieselizing the AP Wasp?
- Diesel Newbie
- Another winner by AJ
- Salvaging old fuel.
- SuperTigre 3000
- Diesel ST-4500?
- What is the trick?
- Thunder Tiger/DD .15 performance
- Diesel conversions and baffle piston engines
- Diesel conversions using existing head
- Basic configuration, and fuel blend????
- Magnum .15 Diesel ?
- SuperTigre 3000 diesel conversion
- q40/irvine diesel 40
- Fox .40
- where could I find a disel head?
- Scratchbuilts
- Conversion for aASP/ magnum 61
- First model diesel experience
- Slow Transition
- Irvine 40 diesel alive and well???
- MOVED: auto diesel versus kerosene versus jet fuel
- Transition
- Why Kerosene, not Gasolene?
- Costs of Operating Diesel
- Monokote, solarfilm etc etc agains dieselfuel..
- irvine 40 diesel that never was till now
- Irvine 15XR diesel head and pipe
- NEED HELP WITH COX CONVERSION
- Cub 099 diesel?
- TT 46 No Top End
- AJs other talents
- Throttling behaviuor versus prop size
- Carlson Engine Imports
- diesel in an rc car?
- General Questions on Diesel use
- Engine Exhibit
- Big diesel's
- MOVED: Diesel Fuel??
- CS replicas: Rivers and Oliver Tiger 2.5 - progress!
- ASP91 Ajs head
- Exhaust backpressure
- Good Job AJ
- I should do WHAT?
- irvine 53 zinger wood 3 blade
- OK, here are some test results...
- irvine 40 very low compression
- Even MORE conversion heads...
- EPP foam
- diesel and glow together in one engine
- Why does a Diesel need a smaller carburettor?
- ITS ALIIVVE!!
- Vivell .09 Diesel Finished!!
- 90 diesel twins (almost)
- WHAT SUPER TIGRE G 2300 SWING?
- MVVS .61 good first diesel?
- Davis Diesel Heads for Norvel engines ?
- Diesel Dillema
- OS 60 FP Conversion
- Diesel engine projects
- tuning
- Long distance Diesel?
- irvine 40 diesel
- drone 29
- enya ss.40
- New light weight, compact Webra .91
- Diesel fuel tank question
- os 160 fx
- Better Resolution Photos
- Next Project
- more conversion heads..
- More on PAW 19
- Lookers (Lurkers?)
- Project Photos
- What are the mods for converting to diesel?
- How do you spell Start?
- 4 stroke diesel
- Diesel Vs. Gas Ignition Efficiency
- Flying with a thrill or two
- head shims
- Diesel for a HOB Spacewalker?
- Diesel Power for faster planes?
- Engine collecting
- diesel r/c car engines?
- Good first diesel?
- ENYA CX11D
- Diesel vs glow power and efficiency
- diesel fuel tubing
- MOVED: Ether
- paw 033 post on 1/A site
- New Project
- O.K. Cub .049 Diesel
- too quiet?
- The basics of converting to diesel???
- Is Diesel The Right Choice for me?
- Tuning
- Has anyone used the davis head on a pee wee .020?
- mvvs grrt-nr conversion??
- ST 90 and head
- mvvs 61 break in finally
- Success
- Andrew Coholic
- E. D. Baby
- Thunder Tigre .10 diesel conversion
- Super Tiger 90 conversion
- Elfin diesel
- Ringed vs. ABC/ABN for Diesel
- plane for enya cx11d
- ASP 91 2 stroke
- Magnum .15
- Webra .91
- Diesel reliability
- vmar cub os10 diesel
- PAW 35 and 40 tach readings
- Davis heads
- MOVED: Have info on aroma additives for fuel?
- How big...
- dc sabre performance?
- o.s. .91fx gains?
- 40 diesel performance
- mvvs diesel prop question
- mvvs 61 diesel head
- mvvs getting nasty
- Props for PAW.35 & Aurora .40
- MOVED: NEW TO DIESEL REQUIRE GOOD FUEL FORMULA??
- OS91 head
- To tap or not to tap
- GLOW TO DIESEL CONVERSION???
- MVVS 40 conversion
- supre tiger 90
- site hits
- mvvs 61 diesel
- numbers
- irvine 40 diesel orginal vs davis head
- Converted GMS .47 tach reading.
- MVVS diesels
- Convert or buy?
- Engine ID
- irvine 53 davis head
- Convert Thunder Tigre 61?
- paw 55 loss of throttle
- possible convert to conversions
- Sizing help
- Homemade .15
- Enya .19 conversion
- Throttle for Russian MK-17 .09
- So how do you start your Diesels?
- Irvine 40 diesel (orginal)
- Question abt. behavior with fuel additive
- Diesel UAV
- FOX .15 Diesel conversion numbers ??
- MOVED: red
- bench run on PAW19
- Help with PAW engine/gaskets/sealant
- Questions about breaking in small diesels
- REAR Induction
- anyone interested in...ITS DONE!!
- diesel compression
- MOVED: K&B Diesel fuel
- PAW .55
- just for your interest - fox 35 stunt conv.
- K&B Diesel fuel
- Custom Diesel heads?
- MUffler mvvs/mp 061 mixup
- power options little tiger moth
- ST Diesel conversion
- Replica Diesels
- thunder tiger 10 conversion headaches
- 48 in Lazy Bee
- Old diesels
- amyl nitrate
- GMS 2000 .47 Diesel Head?
- PAW vibration problem
- OS 1.08 conversion?
- If they're so good...?
- what's the advantage
- Who makes a .25 Diesel ???
- enya cx11 diesel test
- What a great diesel conversion!.. Thanks rmteo!
- MOVED: Biodesel?????
- where/who to buy from
- duratrax diesel
- Newbie Diesel questions
- Modifying Tigre blend fuel
- Fox .74
- Feel free to use this as your Diesel discussion home.
- Some question about converting to diesel
- Question moved from glow
- Evolution 46 diesel
- ignition improver
- norvel 061
- Rossi 15
- Perry Carbs
- MOVED: Ether or not Ether ?
- Seeking True diesel Engine
- Diesel 4 strokes
- question for DDD
- Smaller carb
- 3250 tiger conversion
- Norvel
- Paw .19
- Ringed or ABC
- Frozen Contra Piston
- Diesel head availablity & price list.
- Davis muffler weights ?
- Misc diesel questions
- Davis Diesel Fuel Shelf life.
- for a Moki 135? anything......
- Engine Out Characteristics
- Mufflers
- Norvell as Diesel
- Tuning Diesels
- Deseil Vs. Glow
- Diesel Head for Fox 74
- Venturi opening
- diesel fuel availability
- diesel gass
- Have a question about a diesel head.
- irvine 61
- Straight Talk on the PAW .60 TBR R/C Diesel
- Welcome Davis Diesel to the RCU direct support forums
